6112/5160.
Discussion in '2.5 Gen Tundras (2014-2021)' started by MEGALODON18, May 2, 2019.
  1. May 2, 2019 at 6:33 PM
    MEGALODON18
    MEGALODON18 [OP] New Member
    Kyle
    2018 tundra crewmax 4x4 5.7 v8 MGM
    None yet.
    Can anyone show me 6112 1.9 setting. 5160 rear. With 1inch shackles and just 1 driver side shim. Running on 285/70/18. Thanks guys.
    ColoradoTJ likes this.
  2. May 2, 2019 at 7:22 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    I also would like to see this... for research!
  3. May 2, 2019 at 7:28 PM
    MEGALODON18
    Kyle
    None yet.
    Ya me to. Since I’m getting this setup.
  4. May 2, 2019 at 7:47 PM
    Blueknights75
    Ron
    Clayton, NC
  5. May 2, 2019 at 7:56 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    There is a thread for this it has a ton of photos with the bilstein setup. Search for it and go through it you will find everything you need
  6. May 2, 2019 at 9:16 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Do you want fries with that?
    Thank you for your order. Please drive through.
    :boink:
    cmiller219 likes this.
