  1. May 1, 2019 at 1:48 PM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    I’m guessing you have installed this? When I cut the holes out of the template, should I remove the entire black line, leave the entire black line, or somewhere in between? Maybe this is all covered in instructions. Admittedly, I haven’t even opened the box yet.
  2. May 1, 2019 at 2:08 PM
    Blueknights75
    Ron
    Clayton, NC
    I have completed the install...was one of the first mods I did and absolutely love it. It did take about 6 beers for my balls to grow big enough to cut a hole in my 40k dollar truck but glad I did it! I cut the template with scissors directly on the black line. Then once you lay the template and trace it out just remember to cut inside your marked line on the carpet.
  3. May 1, 2019 at 3:32 PM
    tundradownsouth
    tundradownsouth New Member
    New Orleans
    19 tundra crewmax
    It wasn’t too bad to use. I learned I had to repeatedly shake and spray small sections at a time. Used up 2.5 cans for the grille. i should have looked into the wheel kit that’s cheaper then the trim kit + 3extra cans I bought. Sign up for their discount code to save. I saved like $10 from it
    Only prep was just washing it and then spraying it with their “prep solvent” it smelled like alcohol to be honest and wipe it dry. l It’s just like plastidip. Think I probably sprayed like 7-9 coats of it then about 2 coats of their high gloss.
    Tundra_Dawg likes this.
  4. May 1, 2019 at 3:33 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Incase anyone else with the tech12volts Fortin one remote start has my same issue:
    I installed mine the other day and was having issues with intermittent starting. Only worked like half the time over a few day period.rr I contacted James at Tech12volts today and he told me the '18 is sensitive to the speed at which you push the lock button. He said to try pushing it slower. I gave it a solid 1 second gap between each press and it seems to work every time now. Just FYI to anyone else going to buy one.
    brad.bateman and mgm16trdpro like this.
  5. May 1, 2019 at 3:36 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Awesome, thanks for the feedback!
  6. May 1, 2019 at 4:28 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Did another 1000lb load at Lowe's. Pavers and mulch.
    Watt maker, NAFlash and mgm16trdpro like this.
  7. May 1, 2019 at 4:32 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Is there a slight color difference idk if that’s my eyes or my OCD...what’s your opinion on that?
  8. May 1, 2019 at 5:14 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Picked up the fuel beast 18” +20 offset yesterday, had them mounted today. Will be upping the tire size soon.
    JoshuaA, Ostrich, equin and 5 others like this.
  9. May 1, 2019 at 6:37 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    thanks to wife not checking mirrors and assuming nothing was behind her I got free pass for new tail lights.
    cjmay13, xando, GAknight and 18 others like this.
  10. May 1, 2019 at 6:50 PM
    :rofl::thumbsup:
  11. May 1, 2019 at 6:56 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Picked one of these up
  12. May 1, 2019 at 7:02 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    [sweating] girlfriend has my tundra at the gym rn while I have the van full of kids from hockey practice.
    I’ve never let anyone take my truck. Usually we trade for practice and she comes straight home. NOW THERES AN EXTRA PARKING JOB. AND BACKING OUT. OMG.
  13. May 1, 2019 at 7:03 PM
    mrburns05
    Jacob
    Menifee CA.
    I’m dead. I died. I’m dead
    mojojo, Blueknights75 and Deafmate like this.
  14. May 1, 2019 at 7:27 PM
    TomC843
    Tom
    Charleston, SC
    I hear ya!
  15. May 1, 2019 at 7:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    More information please
    AZTundra likes this.
  16. May 1, 2019 at 7:46 PM
    tundradownsouth
    New Orleans
    19 tundra crewmax
    There’s definitely a slight difference. It looks more like a matte finish to me when standing close but the truck has some dirt and pollen so hopefully it matches better once i give it a wash. Probably gonna try to smooth it out and spray a few more coats of the white and few more of their brand high gloss coat lil bit later down the road
  17. May 1, 2019 at 8:11 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    Apologies in advance for the picture heavy updates. I’ve been such a slacker!
    It all started with black powder coat for my new @Victory4x4 @brimy311 sliders. Which quickly apparently went into a free fall of powder coating Oprah car giveaway. You get PC!! And you! And you! You too!! I have a problem.
    Victory 4x4 sliders. Initially came out of PC glossy and slipper AF. Usually that’s my cup o tea but not on these. Sent them back and he redid them with a matte texture. No busted asses on these. Also in this shot traded in my 275 KO2s for 35 KO2s.
    Red red red red!
    Spider trax spacers was blue now red and matches
    Pulled the letters out so we could black PC the TRD Pro skid plate. I love it can’t lie about it. Oh you’re doing a batch of TRD red powder coat? Don’t mind if I just chunk in these tow hooks
    And might as well do these bed rail cleats. Don’t want any powder to go to waste after all
    And my @sdhq_offroad abs protectors. I’m really doing my powder coated a favor at this point. A @Victory4x4 LCA skid plate and @Coachbuilder1 steering arm sighting too
    And my @Victory4x4 rear diff skid. Which came in handy this past weekend and now needs to go back to powder coat. You might have spotted a red rear diff breather mod too. Guess I should take those part stickers off my gear...
  18. May 1, 2019 at 8:16 PM
    phabej
    phabej New Member
    My wife refuses to drive my truck, she said it's too big and might got something lol
    Deafmate likes this.
  19. May 1, 2019 at 8:20 PM
    escuzi_me
    William
    Nashville, TN
    Well post reply and upload file was close for my fat thumbs so heres more!
    Added VLED blue footwell lights which casts a nice hue over the @james@tech12volts jbl amp, door, center, and sub group buy I took advantage of a couple months ago. James was phenomenal as per the yoozsh and helped me dial it in. It bangs so hard I rarely go above 10 on my volume.
    Special edition TRD pro weather mats thanks to inserts by @Achuop
    My hood also got some love today after my installer stripped away some other ceramic coating that wasn’t performing and reapplied Ceramic Pro 9H and Ceramic Pro Glass.
    I’ve got some interior chrome delete done too but that’ll have to come later. Gotta pack for a work trip!
  20. May 1, 2019 at 8:33 PM
    Squatting Pigeon
    Holden
    North Texas
    Looking good William!
    escuzi_me[QUOTED] likes this.
  21. May 1, 2019 at 8:37 PM
    TomC843
    Tom
    Charleston, SC
    Her Prius, my Tundra.
  22. May 1, 2019 at 8:38 PM
    escuzi_me
    William
    Nashville, TN
    Thanks, homie! I dub her Princess in the streets, freak in the creeks!
    Watt maker and HappyGilmore like this.
  23. May 1, 2019 at 8:43 PM
    Squatting Pigeon
    Holden
    North Texas
    Nice! :thumbsup:
    Now it's time to use those skids and break that powder coat in!
    :mudding:
  24. May 1, 2019 at 9:43 PM
    AZTundra
    Paul
    Phoenix, AZ
    Not sure what this is...can you fill us in?
  25. May 1, 2019 at 9:55 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    46gal gas tank, from longrangeautomotive, looks like
    GAknight, TheBeast, equin and 4 others like this.
  26. May 1, 2019 at 11:42 PM
    Paulskie
    Paulskie New Member
    Paul
    Correct. Thanks, man.
    Got LRA tank, going to have it LineXed, than installed at the same time as getting some body work done at the shop.
    Should have the truck back in a week and report back to you guys!!!
    GAknight, mgm16trdpro and Watt maker like this.
  27. May 2, 2019 at 6:11 AM
    mrburns05
    Jacob
    Menifee CA.
    [Update*] I’m alive. Truck made it home in the same condition I left it.
  28. May 2, 2019 at 6:16 AM
    Squatting Pigeon
    Holden
    North Texas
  29. May 2, 2019 at 6:44 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I used AutoDip which may be SuperWrap now as it’s the same kind of labeling. A stone chip would go through all the layers and I’d see a chrome speckle, drove my OCD a little too the coating didn’t match the rest of the truck.
    I must have redid the whole thing 3x over a few months of periodic chipping. A full day process of prep, netting the coat, multiple coats, dry time in-between. I gave up and bought an OEM bulge and grille/surround.
  30. May 2, 2019 at 7:07 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Yeah I just have the front and rear bumper caps left that are chrome and that’s was my fear with stuff like that on the front end....may be fine for the rear caps but sounds like a futile effort for the front end parts. Appreciate the update! My OCD would not do well with that either
