DIY Spring Compressor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cdorman, May 1, 2019.
  1. May 1, 2019 at 12:05 PM
    Cdorman
    Cdorman [OP] New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    **advice please**
    Installing my 5100’s next week. Pretty straight forward getting the coil over assembly off with the OEM shock. My question is, should i try to compress the spring and do the swap myself or take it to she shop? I’ve watched videos on shops using the two clamp compressors and seems relatively simple, with a hint of danger obviously. I’m just unsure of a good quality brand of compressor and possibly tips that I’m not seeing in the videos. Any comments are much appreciated.
  2. May 1, 2019 at 12:16 PM
    TXRailRoadBandit73 and Fotnot like this.
  3. May 1, 2019 at 12:20 PM
    Cdorman
    Oklahoma
    Yeah I’m sure you can, just wondering if it’s worth doing myself? Shop in town said they will swap the shocks for $40
  4. May 1, 2019 at 12:24 PM
    incredibillhulk
    incredibillhulk New Member
    My personal opinion, let the shop do it versus trying to use a compressor that wraps around the outside of the spring. From what I recall when I was building my suspension last fall, the store-bought compressors would not properly fit the spring on the Tundra and felt unsafe. Ended up taking the whole assembly to our local shop who had a wall-mounted unit and they were kind enough to do it for free, and it was just overall safer for me.
    LarryDangerfield and Smoofers like this.
  5. May 1, 2019 at 12:24 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Dude, pay the $40.
    I had a spring compressor let loose on me once. No bueno!
    Rocko9999, Oey12, Blue By U and 2 others like this.
  6. May 1, 2019 at 12:25 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Pay, $40 bucks is cheap insurance so you don't die. (Seriously if something goes wrong you could easy be seriously injured). Unless you have no other choice. I was lucky and had a wall mounted spring compressor here at work I was able to use. (three points of contact on the springs)
    Not worth the risk in my opinion.
    pyrite808 likes this.
  7. May 1, 2019 at 12:49 PM
    You can do yourself, helpful vids on YouTube
    ColoradoTJ likes this.
  8. May 1, 2019 at 1:13 PM
    motod6
    motod6 New Member
    2015 White TRD
    The title of this thread could be its own Faces of Death VHS series
  9. May 1, 2019 at 1:16 PM
    Jrharvey02
    Jrharvey02 New Member
    These worked for me, no problem. You only have them compressed for like 5 min while you swap struts. It wasn’t that bad. Just use hand tools not power tools. Tho I got a quote for $200 for 4wheel parts to swap mine. $40 is a steal and seems way too low...OEMTOOLS 25550 MacPherson Strut... https://www.amazon.com/dp/B000CMDPLM?ref=ppx_pop_mob_ap_share
    Darkness likes this.
  10. May 1, 2019 at 1:18 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    $26 off of Amazon. Never used 1 before. This was the first one I did20170901_153856.jpg
    TheBeast likes this.
  11. May 1, 2019 at 1:18 PM
    I used the ToyTec method......I pay.......they do the rest.
  12. May 1, 2019 at 1:20 PM
    Berdine
    Frank
    Binghamton, NY
    Same with me the 2nd time, and my last! No more crappy RC coilovers!
  13. May 1, 2019 at 1:23 PM
    Jrharvey02
    I like the use of the pins even know they’re useless for our fatty springs, haha, shrapnel if that thing let’s go! Your original post w that same pic gave me the confidence to do mine.
    Berdine[QUOTED] likes this.
  14. May 1, 2019 at 1:26 PM
    Berdine
    Frank
    Binghamton, NY
    Yeah too fat for the pins, had to force the others in between the coils to fit. It was tight fit, no movement when I started tightening them. Just went slow and steady
    Jrharvey02 likes this.
  15. May 1, 2019 at 1:27 PM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    This. Back when I had an S-10 that was the way everyone replaced springs. They don't have a combined spring/shock assembly to pull out. I got a Tacoma and everyone flipped out when someone mentioned the no compressor method saying you'd kill yourself by not using a spring compressor lol
    Watt maker and Pudge like this.
  16. May 1, 2019 at 1:32 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    for $40 pay the shop, its one thing if you are just swapping the shock out and need to hold the spring in place, its another to try and compress them...i.e. installing a bilstien on a taller collar setting. i am not scared to do just about everything on my truck and have done this before...and it was unsettling. loosing an eye or finger is not worth saving $40
  17. May 1, 2019 at 1:34 PM
    I personally think spring compressors are easy to use (if used correctly), depending on comfort level.
    On the flip side, paying some money to the place that also does the alignment is never a bad idea.
    Guess it all comes down to "what's your time worth?"
    Berdine likes this.
  18. May 1, 2019 at 1:34 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    $40 is cheap and worth it IMO
  19. May 1, 2019 at 1:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Pay the $40 or do the no spring compressor route. I did that twice without issues, easy to do, safer and works well.
    Watt maker likes this.
  20. May 1, 2019 at 1:40 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    Im doing mine currently using a spring compressor and it works pretty well. You do have to put some ass behind them if you dont have any impacts available. Its also free. Pay the deposit to autozone and receive all money back when i return it.
  21. May 1, 2019 at 1:42 PM
    Jrharvey02
    See, now you’re talking crazy, I don’t think power tools are recommended regardless if you got em
  22. May 1, 2019 at 1:45 PM
    Jrharvey02
    I don’t see why the danger is anymore than simply being under a truck on jack stands changing your oil. End of the day if the metal fails, you’re done...suck it up buttercup. I reconcile my differences by at least coming out of these jobs with a new tool and mo’ first hand knowledge.
  23. May 1, 2019 at 1:50 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    I'm very happy i have power tools with spring compressors. makes it so much easier to zip that long ass bolt down so then you can torque it with a wrench.
  24. May 1, 2019 at 2:05 PM
    Jrharvey02
    That’s one deep socket, lol.
  25. May 1, 2019 at 2:09 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    The nut portion of the spring compressor never moves...
  26. May 1, 2019 at 2:11 PM
    Jrharvey02
    You’re right, my eyes were nearly closed the entire time, like that face you get when somebody points a rubber band at you, that was me for 15 min doing this.
  27. May 1, 2019 at 2:17 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    Darkness and Jrharvey02[QUOTED] like this.
  28. May 1, 2019 at 2:19 PM
    Pay the $40.
  29. May 1, 2019 at 6:47 PM
    Cdorman
    Oklahoma
    Thanks for the all the input! Gonna pay the $40 :oldglory:
  30. May 1, 2019 at 6:59 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    It will be the best $40.00 you ever spent, trust me. I did mine myself and wish I could have just taken them somewhere. It is simple, but with a large spring compressor and 10 minutes, someone else can do it for you. Wise decision.
    Pudge likes this.
