Pic Request - 255/80R17 on Stock Wheels
Discussion in '1st Gen Tundras (2000-2006)' started by pollymath, Apr 19, 2019.
  1. Apr 19, 2019 at 9:56 AM
    pollymath
    pollymath [OP] New Member
    2006 Limited DC 4x4 "Chunky Salsa"
    Anybody running 255/80R17 on Stock Wheels with or without lift? I highly doubt you could get away with running this tire without a lift, but post pictures either way.
    Please don't post pictures of trucks with non-stock wheels or 16" wheels or anything other than STOCK 17's.
    Why? For example, the black truck posted below, I've had those pictures saved on my machine for about two years now. I don't need to see them again.
    speedtre likes this.
  2. Apr 19, 2019 at 1:09 PM
    Professional Hand Model
    Fred
    Hand Protectors
  3. Apr 19, 2019 at 1:10 PM
    Fred
    Hand Protectors
  4. Apr 19, 2019 at 1:11 PM
    Fred
    Hand Protectors
  5. Apr 19, 2019 at 2:10 PM
    pollymath
    Hmm...those wheels don't look stock.
    Anyone have pics of 255/80R17 ON STOCK WHEELS
  6. May 1, 2019 at 11:00 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Here is my truck on 34x10.5x17 BFG on stock wheels. Basically same measurements as the 255. I like them a lot and give me the height without the power loss I experienced with 285/75/17’s.
    95377250-07D6-4C30-B9DC-FD25A087E7C1.jpg 0BA5CE3B-1C45-4904-9AE4-F5FE388577D9.jpg
  7. May 1, 2019 at 11:24 AM
    pollymath
    Perfect, thanks!
    I wanted to see how they looked inside the fenders.
  8. Oct 10, 2019 at 8:02 AM
    chrifishtopher
    chrifishtopher New Member
    Huntington Beach, CA
    04 Tundra DC 4WD
    IMG_20191007_200909_768.jpg Here's my '04 with 255/80/17 coopers
  9. Jul 23, 2020 at 10:44 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    Are you lifted or stock height? Do you rub at all?
    04TundraTRD likes this.
  10. Jul 24, 2020 at 9:13 AM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Also interested in this ☝️
  11. Jul 24, 2020 at 9:53 AM
    chrifishtopher
    04 Tundra DC 4WD
    Bilstein 5100s on all 4, second highest setting (cant put highest setting in 4wd), there is 99% no rubbing. I don't notice rubbing physically when driving but the UCA (stock) has some dust rubbed off so there must be a small amount of rubbing if that's happening. I offroad often and go full articulation sometimes so that's probabaly when it happens.
  12. Jul 24, 2020 at 10:15 AM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Awesome, I was pretty set on 285/70/17 but the 255 you run seem to be better in speedometer correctness and let's face it, a taller and skinnier tire does well in 75% of situations. Most RTW vehicles choose this type of tire with good reason.
  13. Jul 24, 2020 at 10:37 AM
    Looks good! Those are BFG KO2, or another model?
    Seems like every truck I run across with KO2s causes me to double-take. Yours is no different.
  14. Jul 24, 2020 at 11:07 AM
    chrifishtopher
    04 Tundra DC 4WD
    Here's a good angle with view down along fenders. (El Capitan in the background, Yosemite NP)
    Cooper Discover ST Maxx 255/80/r17
    funny enough I'm looking at 285/70/17 for my 2nd set. Currently running 265/70/17 KO2 pulled off a taco and they're a little small.
    highcj5, SharkDog, Levy and 2 others like this.
  15. Jul 24, 2020 at 1:04 PM
    fighthedude
    fighthedude New Member
    Was your power loss because of added weight of wider tires? I am debating between 285/70 17 or 285/75 17. Or the 255/80 17. Need to pull trigger soon
  16. Jun 12, 2021 at 8:12 AM
    huntsonora
    huntsonora New Member
    2006 Toyota Tundra DC
    255/80/17 on stock wheels on 2006 DC with Old Man Emu suspension
  17. Sep 30, 2021 at 7:13 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    That looks nice! Any rubbing? Stock uca? I have the same size tires on my Tacoma. But it's a prerunner and I want 4wd. Looking at 1st gen tundras.
  18. Sep 30, 2021 at 9:04 PM
    huntsonora
    No rubbing at all
    des2mtn and dirtnsmores like this.
  19. Oct 1, 2021 at 11:01 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Pizza cutters are the way to go IMO. I'm running 33x10.50R17's and it's the perfect combination.
    huntsonora likes this.
  20. Oct 13, 2021 at 12:44 PM
    dirtnsmores
    Southern CA
    Do you have any pics from the front?
  21. Oct 13, 2021 at 12:51 PM
    huntsonora
    with no wheel spacers….. I’ll post another pic of mine with wheel spacers
    dirtnsmores[QUOTED] likes this.
  22. Oct 13, 2021 at 12:53 PM
    huntsonora
    With spidertrax wheel spacers, same suspension
    shifty` likes this.
  23. May 11, 2023 at 10:18 PM
    yotak00k
    yotak00k New Member
    2002 AC Tundra 4x4
    What psi are you guys running these tires?
  24. May 12, 2023 at 12:00 AM
    1stGtundra06
    1stGtundra06 New Member
    06 DC White Tundra
    Bilstein 6112 7/5 clip Front/5100 rear; 255/80r17 Toyo R/T Trail
    I recently got Toyo R/T trail 255/80r17 on stock rims and shop put about 42 psi. Lowered to 25 psi when off-road.
    bmf4069, shifty` and Elevatorguy like this.
  25. May 12, 2023 at 5:44 AM
    Got any closer pics of those?
  26. May 12, 2023 at 7:16 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Also what lift setup are you running 1stG? Looks great!
  27. May 12, 2023 at 7:33 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    That's a sharp looking 1stGen. Something about the picture angle/tires/wheels/stance just makes it look perfectly proportionate.
  28. May 14, 2023 at 6:20 PM
    1stGtundra06
    06 DC White Tundra
    shifty`[QUOTED] likes this.
  29. May 14, 2023 at 6:24 PM
    1stGtundra06
    06 DC White Tundra
    Have Bilstein 6112 front with 1.6" lift (based on 7/5 clip location) and rear is 5100 with no lift.
    Elevatorguy[QUOTED] likes this.
  30. May 15, 2023 at 2:31 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    You have only 4 lug nuts...that can't be good!
    bmf4069 likes this.
