Help - BDS 7” Coilover Kit, Fox 2.5’s Disaster
Discussion in 'Suspension' started by Acrotalus, Apr 30, 2019.
  1. Apr 30, 2019 at 4:22 PM
    Acrotalus
    Acrotalus [OP] New Member
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    Calling for help here, boys
    @hngo01 @Danman34 @tmart @Spvrtan
    Ever since I got my truck back from the shop, my tie rods have hit the coilover’s. I figured this was just going to scratch the coil, no big deal and I carried on. Today, while going over a cattle guard, my steering wheel jerks hard to the left. I center it, and it pulls hard left again. I get out to check my tires, assuming I have a flat. Tires are good.. keep rolling. Constant hard jerking of the steering wheel to the left. I drive it back to my office and what I see is crazy. My wheels are jacked up! It wore the inside of my tires so bad, I may have to replace them on the front. My determination is that the kit is NOT supposed to have the tie rod pushing into the Coilover. I believe this kit came with tie rods, but are mine factory? I thought the ones included with the kit are black? ... would the tie rod pushing into the Coilover force the lower ball joint to bust? I drive about 150 miles a day, all off road. I take turns, off road. So while this may not be a common problem to the average driver. My driving conditions will amplify any problems. I have included a video of what is going on, as well as a picture.
    https://youtu.be/uwFwHMGm_Rg
    Is there anything that sticks out to anyone as far as installation error? I just had this kit installed less than 2 months ago and had no problems, other than tie rod scratching the coil, until today.
    Thanks for the help!
  2. Apr 30, 2019 at 4:30 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    I have no clue, but...you've got negative camber for DAYS!
    I can't imagine that a tie rod should be rubbing on a coilover at all
    TheBeast likes this.
  3. Apr 30, 2019 at 4:38 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    That’s just doesn’t look good @papasmurf once had a bds 7” kit I believe maybe he can help
    papasmurf likes this.
  4. Apr 30, 2019 at 4:41 PM
    Acrotalus
    It’s definitely not driveable, one second it was driving fine, cross a cattleguard and everything goes to shit.
  5. Apr 30, 2019 at 4:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Tie rods hitting your coilovers has to be adjusted with the alignment.
    Coachbuilder1 and TheBeast like this.
  6. Apr 30, 2019 at 4:41 PM
    Acrotalus
    It received an alignment as the last part of the install, I don’t have the specs however.
  7. Apr 30, 2019 at 4:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Holy shit! I just watched that video. Yeah, that’ll do some damage.
  8. Apr 30, 2019 at 4:46 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  9. Apr 30, 2019 at 4:51 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Holy shit, that should never be happening.
  10. Apr 30, 2019 at 5:01 PM
    AZTundra
    Paul
    Phoenix, AZ
    :eek2: I don't think that is supposed to be happening.
  11. Apr 30, 2019 at 5:01 PM
    Haslefre
    Haslefre New Member
    TN
    Lower ball joint is gone. Thats first that needs fixed. Second I would check to make sure the shock is still good. If the entire assembly is getting pushed over by just the tire, the shock might have broken internally. I had this happen on my tacoma. Third, I don't know what to say about the tie rod. Something on the top of your wheel assembly has to be broken.
  12. Apr 30, 2019 at 5:10 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    your spindle is bent, no big surprise from a BDS spindle. needs to be replaced, they have lifetime warranty on their products
  13. Apr 30, 2019 at 5:13 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I’m in to see what’s wrong with it.
  14. Apr 30, 2019 at 5:13 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    upon further review, maybe both your lower ball joint bent and spindle had to tell. but id replace both of those and you should be ok.. but i would look at ditching that kit for a midtravel setup with stock spindles it will give you better ride and stronger than the BDS kit
    equin, aperezsh, mountainpete and 5 others like this.
  15. Apr 30, 2019 at 5:13 PM
    upload_2019-4-30_18-12-59.jpgGet a tow to nearest reputable repair facility................
  16. Apr 30, 2019 at 5:22 PM
    Acrotalus
    Man I just spent a bunch of money on all of this.. I figured if it ran for 120k miles on stock suspension, then surely this kit and fox 2.5’s will give me a good run :(
  17. Apr 30, 2019 at 5:23 PM
    Haslefre
    Haslefre New Member
    TN
    You don't HAVE to switch. But it would be recommended to beef up the spindles that come with the kit. Find a welder and put some gussets on them if you want to run them. But you need to switch out at least those 2 parts.
    equin likes this.
  18. Apr 30, 2019 at 5:27 PM
    Haslefre
    Haslefre New Member
    TN
  19. Apr 30, 2019 at 5:30 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Bad news kiddos it’s very difficult to weld to cast iron spindles not to mention the gussets would have to be custom TC spindle gussets won’t fit
    TRD423, aperezsh, ColoradoTJ and 3 others like this.
  20. Apr 30, 2019 at 5:31 PM
    Haslefre
    Haslefre New Member
    TN
    Figured I would try to help him with some options. I know it isn't the easiest thing to do, and I know BDS is different from stock.
  21. Apr 30, 2019 at 5:32 PM
    TheBeast
    TheBeast The Beach
    seeing how much you drive and on dirt roads. I suggest a quality M/T setup like @M C M or Kings/TC/Deaver.
    BDS won't handle the abuse you are throwing at your truck.
  22. Apr 30, 2019 at 5:33 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah no doubt good call the issue w cast ductile iron used by bds is it’s soft and difficult to weld to it’s an option but this is a ongoing issue w all bracket lifts
  23. Apr 30, 2019 at 5:34 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Exactly
  24. Apr 30, 2019 at 6:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Didn’t you decide to go Icon a few months ago? How did you end up with BDS/Fox?
  25. Apr 30, 2019 at 6:36 PM
    Acrotalus
    @Haslefre and I appreciate it
    @TheBeast @papasmurf @joonbug this is something I considered for a very long time, but ultimately I wanted something that got me more clearance, for function since a lot of my driving is slow crawling- but also for the look. that plus from everything I read and researched- the BDS Kit with 2.5” Foxes was supposed to be one of the better bracket lifts that can handle the abuse. I thought Spvrtan runs this kit and he runs his truck hard too. It appears I have made the wrong decision. I knew the look I wanted to achieve, and I achieved it while still being able to off road it .. I thought.
    But at this point I am not throwing any more money into the truck than I have to. So I’m going to try and make this work. I think aside from the cast iron knuckles, there are some other issues like the tie rod pushing on the coilover, etc.
    As always, I appreciate every bit of y’alls input!
    Some more photos
    joonbug likes this.
  26. Apr 30, 2019 at 7:16 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    So yes he does run the kit but much slower than you think, the one time he came out and ran it at speed he bent a spindle... it’s an issue w them find a good welder and have them build some gussets that should help your tie rod issue is related to the spindle and lower ball joint... also I’ve Bent spindles too w my bds kit... I can be strengthen just find a good fab shop/ welder and work w them I’d be happy to help you anyway I can
  27. Apr 30, 2019 at 7:19 PM
    Acrotalus
    Thanks a bunch for the information man. Are there any beefier spindles that I could buy and still meet proper geometry for the rest of the kit? Otherwise I’ll get a hold of a fab welder out here in the oilpatch to rig me something up. But that scares me too because they’re gonna cowboy something up
    joonbug likes this.
  28. Apr 30, 2019 at 8:38 PM
    Haslefre
    Haslefre New Member
    TN
    To be honest, it can't hurt it. Just get the new spindle from BDS, take both off and have gussets welded up to them. You'll want to look at some pictures to see how they are done on other vehicles, tacomas usually have a ton for the beefier builds. I am sure some people here have finished pictures too if you go to the mid/long travel threads.
  29. Apr 30, 2019 at 8:39 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What does the shop say about this the guys who installed it? I have fox juts a 3.5 inch lift and it’s amazing dude and there service is killer I called them and they answered all my questions. But I would put this on the shop and bds so sorry I totally get it tho spending all that money I know it’s frustrating
  30. Apr 30, 2019 at 8:46 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Hey, now.. I wouldn't call taking a sharp turn at 45mph in a wash and then hitting a 2-foot tall boulder around the blind corner "slow." That shit did fuck up my spindle real good though but did BDS covered it all under warranty for free.
    :duel:
