  1. Apr 30, 2019 at 3:19 AM
    #6511
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    How long did it take y'all to get your Dirty Deeds fuel injectors?
    I placed my order the 21st.and it's still being processed...
  2. Apr 30, 2019 at 3:38 AM
    #6512
    Professional Hand Model
    Fred
    Hand Protectors
    About a month in my case. Sensai taught me to be patient grasshopper.
  3. Apr 30, 2019 at 4:43 AM
    #6513
    I don't think he stocks these. Once someone places the order it sounds like he has them made.
  4. Apr 30, 2019 at 5:01 AM
    #6514
    because_wumbo-truck
    Jon
    Houston, Texas
    I just figured it would've shipped by now.
    Filthyphil likes this.
  5. Apr 30, 2019 at 5:03 AM
    #6515
    because_wumbo-truck
    Jon
    Houston, Texas
  6. Apr 30, 2019 at 5:04 AM
    #6516
    Fred
    Hand Protectors
    This is our Big Gurl conditioning. Order. Pay. 2 days later it is delivered.
  7. Apr 30, 2019 at 5:05 AM
    #6517
    because_wumbo-truck
    Jon
    Houston, Texas
    Nah custom armor is worse.
    Order, wait a week. Pay. Wait another 10 weeks. Lol
  8. Apr 30, 2019 at 7:42 AM
    #6518
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Looking forward to see how these turn out and your review of it! :bananadance:
  9. Apr 30, 2019 at 3:29 PM
    #6519
    because_wumbo-truck
    Jon
    Houston, Texas
    :woot: just got an email that the injectors are shipping. Should be here the 3rd.
  10. Apr 30, 2019 at 3:51 PM
    #6520
    Fred
    Hand Protectors
    Loosened and then lower my transmission radiator about an 1/8” as it was not resting on the bumper pads. It had some swing front to back, but no longer with the drop and retighten of bracket bolts. Its resting as it should on the bumpers.
    Saw that thread where the guys fuel pump resistor was acting up so I went ahead and cleaned up mine. There was some (slight) corrosion on the bottom bracket and the grounding bolt a little loose but not much. The aluminum fins really had mucho corroded loose powder/dust come off with the wire brush. Looks new again and really soaked up the Fluid Film!
    Also, cleaned up a few other grounding bolts and electric greased them as well. Specifically, the engine ground (back of engine) and some other ground? next to the battery ground which I did a few months back.
    This is all is keeping with my theory of many 1st Gen problems are due to bad grounds/corrosion.
  11. Apr 30, 2019 at 6:24 PM
    #6521
    Regarding the first picture. I asked what that part was about a month ago. What is it exactly?
  12. Apr 30, 2019 at 6:55 PM
    #6522
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    :drool::drool::drool::drool:
    Rheywood456[QUOTED] likes this.
  13. Apr 30, 2019 at 8:43 PM
    #6523
    SanDiegoBra
    SanDiegoBra New Member
    Michael
    2003 Tundra Access Cab. Green. 2WD
    3 inch lift.
    I'm trying with very limited success to find pocket rivet style fender flares for my 03 access cab... Any sujestions?
  14. Apr 30, 2019 at 11:16 PM
    #6524
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Even though I just recently got my backup camera working, I wasn't entirely happy with the night picture. I ordered a higher quality camera specced at .01 lux where my old camera was specced at 2 lux. The nighttime picture is far brighter now.
    The top line is about 12 ft back and the bottom line is a couple inches behind my bumper.
    1st pic is a very dark side street, only lit by my stock backup lights with very bright LED bulbs.
    2nd pic is a medium lighted parking lot
    3rd pic is the camera at the top of my shell.
  15. May 1, 2019 at 1:32 AM
    #6525
    because_wumbo-truck
    Jon
    Houston, Texas
    Why would the video appear reversed?
  16. May 1, 2019 at 2:33 AM
    #6526
    SoCalPaul
    Paul
    Backup cameras show a reversed image so that the orientation is correct when viewing on the monitor. This can be accomplished by settings in the viewing monitor / head unit or by clipping or keeping a small wire in the camera's wire harness. My new camera also has a wire to clip to remove the guide lines (my head unit can be set to have or not have guidelines & they can be adjusted) and orientation of right side up depending on the way the camera is mounted.
  17. May 1, 2019 at 3:46 AM
    #6527
    Fred
    Hand Protectors
    I believe its a fuel pump resistor.
    faviles and Filthyphil like this.
  18. May 1, 2019 at 3:48 AM
    #6528
    Fred
    Hand Protectors
    Who is installing them for you?
    Hope its not an arm and a leg charge!
  19. May 1, 2019 at 4:41 AM
    #6529
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It is indeed the fuel pump resistor. My limited knowledge on it seems to be that it slows the pump during idle and cruise where the pump doesn't need to run full speed. Kind of working in conjunction with the pressure regulator but on the electric side instead of the flow side.
  20. May 1, 2019 at 6:02 AM
    #6530
    because_wumbo-truck
    Jon
    Houston, Texas
    Not sure yet. Probably won't be a for a bit. I gotta find a replacement at work so I can get off nights and I need some days off that are on the actual days the rest if the world gets off (fri-sun), as opposed to my current Wednesday or Thursday off.
    Or I need to buy a DD.
  21. May 1, 2019 at 6:05 AM
    #6531
    because_wumbo-truck
    Jon
    Houston, Texas
    I want a nice touch screen and a backup camera so bad. I went from an older touch screen in my taco to a factory 6 disk/tape combo in my tundra lol
    SoCalPaul[QUOTED] likes this.
  22. May 1, 2019 at 6:53 AM
    #6532
    NMTundra
    NMTundra New Member
    Jensen VX5228. All in, think I have $350 in mine (installed it myself). Going to install a $40 backup camera off Amazon tomorrow.
  23. May 1, 2019 at 8:47 AM
    #6533
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    Ordered an Iron Bull Bumper a week ago. Delivered yesterday. Can't install it until I upgrade the front suspension.
  24. May 1, 2019 at 12:32 PM
    #6534
    SoCalPaul
    Paul
    This is the new camera I installed. It is far superior to the $20 camera I originally installed. You can change the orientation for whether the camera is hanging, or as they say, "sitting"
    https://www.amazon.com/gp/product/B07QBMNVVB/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
    speedtre likes this.
  25. May 1, 2019 at 1:48 PM
    #6535
    The joys of an aging truck. I've been hearing thunks from the rear when I go over bumps. Whatever it is is new, and not normal.
    The only thing that's catching my eye is the overload spring being cockeyed.
    Is this normal? Definitely appears to be worse on the driver side.
  26. May 1, 2019 at 2:43 PM
    #6536
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Can you hammer it back over straight and then double check that your ubolts are torqued?
    NUDRAT and ethan1911 like this.
  27. May 1, 2019 at 2:46 PM
    #6537
    I'll try that. I'm wondering if my silencer pads are gone. I think @Professional Hand Model had the same issue.
  28. May 1, 2019 at 4:30 PM
    #6538
    Fred
    Hand Protectors
    Mine were way more splayed than yours pictured. I jacked up the rear at the pumpkin just enough to allow the rear tires to sag just off the ground. Put jacks on frame just in front of rear tires.
    Fabbed up a vice and hammered and torqued the leafs as best back into alignment as possible. Slipped some u-bolts over so they don’t splay again. Wished our springs had decent quality keepers on them as the OEM ones are subject to bending with lateral forces leading to splay.
    The silencer pads are toast on mine. My jimmy rig shims are working good, but a small ‘clunk’ has returned as one of my shims has slipped out. Clunk only happens on 90° slow speed turns when incline/declining.
    These springs are still strong. Just the pads are toast and the only way to really fix is to totally dismantle and in that case might as well install new springs.
  29. May 1, 2019 at 5:06 PM
    #6539
    Fred
    Hand Protectors
    Gas pedal feeling real good today. Resistor cleaning?
    Exercised the 4lo 4hi buttons today. The front has a noticeably different sound when activated.
  30. May 1, 2019 at 6:19 PM
    #6540
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    C5F740F7-0A8D-4103-B1AE-FDE033CAD3EB.jpg I started to do my disc brake conversion today and found out my axle is trashed from getting filled full of water from a wheel seal that I recently discovered was leaking. I guess I’ll be doing a 14 bolt swap now instead of just brakes.
