2001 JADE MICA: THE BACKEND OF FOREVER BUILD
Discussion in '1st Gen Builds (2000-2006)' started by Prise, Apr 7, 2016.
Thread Status:
Not open for further replies.
  1. Apr 7, 2016 at 2:26 PM
    Prise
    Prise [OP] New Member
    Andrew
    2001 Jade Mica access cab
    Gx470 wheels and 1.25" spidertraxx wheel spacers
    HELLO ALL! I come from the land of T-dubz like many others. I've had a couple tacos and loved them, but I totalled my last one decided they were too rich for my blood and here I am in a 4x4 Limited Tundy. Mainly a BS thread and photo dump area. Looking forward to some good information here like I know the sister site has.
    My whip right now!
    Already changed out the wheels to Lexus GX470 ones PC dark matte bronze and spider traxx off my '12 Spruce Mica Taco. Flashlight mount mod and TRD bling.
    @allpro bed rack get's here tomorrow! And I grabbed this center console from a wrecked '03 yesterday to switch out with mine.
    Also, picked up a S&B cold air intake. Very, very poor quality IMO, but I got plans to make it way better. My buddy is making me a new Aluminum cover with a custom design for it :D
    So yeah that's where I'm at. I'll post up some pics of my past rides later.
    FirstGenTundra and T-Rex266 like this.
  2. Apr 7, 2016 at 2:26 PM
    Prise
    Andrew
    Mine
  3. Apr 7, 2016 at 2:44 PM
  4. Apr 7, 2016 at 3:16 PM
    Prise
    Andrew
    My last two Yota's!
    T-Rex266 likes this.
  5. Apr 8, 2016 at 1:09 PM
    Prise
    Andrew
    Got the @allpro bed rack in today! [​IMG]
    Will have it welded up next week!
    twotrack likes this.
  6. Apr 15, 2016 at 8:58 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    I have a feeling this will be epic!!
    Prise[OP] likes this.
  7. Apr 15, 2016 at 9:01 AM
    Prise
    Andrew
    Thanks Pat I'm sad you sold your icons I think they would have been great for spring under
  8. Apr 15, 2016 at 9:02 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Ohhh that would have been cool... they went to a good home though lol
    GTABurnout likes this.
  9. Apr 15, 2016 at 9:03 AM
    Prise
    Andrew
    Yeah I saw that. Az family ftw!
  10. Apr 15, 2016 at 9:16 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Whats the suspension plans?
  11. Apr 15, 2016 at 9:23 AM
    Prise
    Andrew
    More than likely wait for a used set of kings to pop up and snag them otherwise save up for ads and make it a solid midtravel setup with coils bucket gussets, spindle gussets, box the frame upgrade to poly steering bushings and try to find the 231mm brakes from a 05+ Then resist the urge to throw on the McMfab cantilever rear setup. Relentless fab front bumper and skids and the rear bumper some sort of custom high clearance with a swing out possibly.
    FirstGenTundra likes this.
  12. Apr 15, 2016 at 9:24 AM
    Prise
    Andrew
    And about 50 other small details.
  13. Apr 15, 2016 at 10:00 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Always more details than we can keep track of!
    Prise[QUOTED][OP] likes this.
  14. May 22, 2016 at 9:47 AM
    GTABurnout
    GTABurnout New Member
    And one of these days I will actually install them :(
  15. Aug 4, 2016 at 8:11 PM
    Prise
    Andrew
    Little picture dump
  16. Oct 3, 2016 at 8:23 PM
    Prise
    Andrew
    Finally got around to switching out my center console to one I picked up from a totaled out 03 limited.
    First you empty the console and take out the felt bottom. Remove the four 10mm bolts and she pops right out.
    Then, you take out the two push pin inserts on either side this lower portion pulls out.
    Unplug the two 12 volt plugs and you can toss, sell, or save that old piece. Some jackhole spliced in a 3rd 12volt plug for an ancient Sirius radio setup. Left it all behind.:smack:
    Test fitting, lines up pretty nicely for going on an older model tundy.
    From the totaled truck came 3 brackets and two air ducts. The air ducts don't line up right at all so I'm not gonna use them. The front most and middle bracket you have to cut away at the carpet to mount them to the transmission tunnel. The front most one I'm not gonna use because I'll be cutting away that section of console to mount a CB (more on that later). The middle bracket I lined up to the holes on the console but didn't cut away the carpet it seemed pretty sturdy and is more for support rather than securing it down.
    Rear bracket uses two of the existing holes (rear) from the old console. I didn't have sound deadening material and didn't want vibrations so I used electrical tape for now.
    The front holes of the old console aren't used at all and so it just leaves two holes to the ground. So I put the bolts back in.
    From there it was easy, it all slides in and bolts up nicely. Matches all the stock limited trim from 01 perfectly. Very pleased with how this turned out, soon I will cut some of the center console so I can mount my CB radio up.
    FirstGenTundra and TheBeast like this.
  17. Oct 3, 2016 at 8:42 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    Nice work man! Much better.
  18. Oct 4, 2016 at 9:16 AM
    Prise
    Andrew
    Thanks man!
  19. Oct 4, 2016 at 3:19 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Great first gen project! I always had wanted to do that center console mod to mine but could never find the parts. Keep us up to date. We are picture whores here.
  20. Oct 4, 2016 at 5:04 PM
    Prise
    Andrew
    Thanks man, I always have plenty of pictures. I spend most my time on tacomaworld the AZ crew is super active. I just found a totaled 03 at a pick and pull and went and got the parts for 50 or 60 bucks
  21. Apr 18, 2017 at 4:09 PM
    Prise
    Andrew
    Anyone wanna trade me my 03 limited full console for a limited half console, going with a manual 4wd J-shift transfer case and gonna need to cut a hole in the transmission tunnel. Even trade no money on top!
  22. Apr 29, 2019 at 10:48 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
Thread Status:
