  1. Apr 28, 2019 at 6:27 PM
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    Damn that looks nice. I would NEVER want to get my Tundra dirty if I went through all that trouble! ;)
  2. Apr 28, 2019 at 7:11 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I just did this a few hours ago and saw the same video. The only way it’ll fit is if you push that little lip past the fender hole. Once you do, it’ll look weird, but it’s the only way to line up the lower filter box bolts.
    The main problem with how it fits is that it feels like the opening is pushed up against the fender once it’s inside there and all buttoned up. I’m wondering if there’s enough of a gap to properly suck in enough air like it’s supposed to.
    mgm16trdpro[QUOTED] likes this.
  3. Apr 28, 2019 at 8:28 PM
    kim_89
    kim_89 New Member
    Kim
    2016 SR5 TRD Off-Road
    Lift 3"
    Starting to get rid of the croms!
    Rim's had some oxidation but buff some of them out.
    Side chrome got plasti dipped, good weather weeknd = working on truck..
  4. Apr 28, 2019 at 8:48 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Not at all. Pretty much the same.
    There’s a thread on here that someone tested it in a more rural area and it still works pretty well.
    Tundra17Tom[QUOTED] likes this.
  5. Apr 28, 2019 at 9:43 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Easy install. 1 point I think is worth mentioning is the only way it'll fit is if u push the rubber ring into the fender wall. The rest was piece of cake. Even with trying a couple times both ways it still was an easy quick install.
    This way it won't fit.
    Once u push that ring in too you're good to go.
    It's a shame that last pretty red tube is covered by the engine cover, but oh well, still looks great.
    Now, time for those massive power gains lol.
  6. Apr 28, 2019 at 10:41 PM
    mgm16trdpro
    Northern NJ
    Oh yeah, just in case anyone was interested. The dry afe pro aftermarket filter u see in pic will fit inside the trd cai. Not dyno tested on mine, but none the less dyno tested to be proven as 1, if not the best, air filter for what little gains u can get from them. I used that in place of the red trd filter.
  7. Apr 29, 2019 at 4:31 AM
    N DUB 15
    N DUB 15 New Member
    Northern Colorado
    2019 Crew Max Limited Cement
    Bed Liner, Topper, Nerf Bars, Remote Start, black mirror caps, Front window tint
    I began my dechrome process with the badge overlays and added black side steps. Not a bad start in the first week of ownership.
  8. Apr 29, 2019 at 8:30 AM
    equin
    Ed
    DFW, TX
    Excellent posts and thanks for the pictures. That TRD CAI looks great. I also went with the aFe dry pro filter, but I kept the stock intake/filter housing. I did add the TRD air flow accelerator and installed it like you did, with the lip inside the hole.
    Like I mentioned in my earlier post, I fear the accelerator's opening may be jammed up against the fender without a sufficient enough gap to let the proper amount of air to get sucked in. Only reason I say that is because upon install I could feel it hitting something as I pushed it in and was trying to line it all up. Did you notice the same?
  9. Apr 29, 2019 at 9:36 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20190429_121037.jpg 20190429_122657.jpg Added the TVD vinyl decals to the letters on my radio. Not an expensive mod but i think it looks better.
  10. Apr 29, 2019 at 9:54 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    link? also...how is install? i've thought about doing some simple color mods like this to tie in my blazing blue with the interior, but want a couple small things, and not look like a can of blazing blue threw up inside the truck. lol
  11. Apr 29, 2019 at 9:59 AM
    NCTundra18
    Jeff
    Candler, NC
    https://tvdvinyldecals.com/collecti...dio-insert-decals-for-2014-2018-toyota-tundra
    Install is fairly easy. Just dip the letters in soapy water and do your best to get them straight. Not bad for $10 bucks.
    Fotnot[QUOTED] likes this.
  12. Apr 29, 2019 at 1:12 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Installed Leitner ACS. Decided to get Bak Flip Cargo Relocation Brackets and keep the factory side rails. Word of advice if you want to do the same, put the tie down cleat on the rack before mounting it. The D pillar gets in the way if you try to put it on after.
  13. Apr 29, 2019 at 3:20 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Got the new wheels Fuel Vapor
    Before
    After
  14. Apr 29, 2019 at 4:02 PM
    woah62
    woah62 Resident Evil
    2017 Sunset Bronze Mica Tundra SR5
    2123F058-8328-4510-A97D-D136BDCC6728.jpg 12677CBC-29B6-422A-9CE3-5A559D69FA34.jpg Installed the 2019 TRD Pro headlights. Before and after.
  15. Apr 29, 2019 at 5:04 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Do you have any pics of tire near UCA? Any rubbing issues? That’s the size I’m looking to go into. Still doing more research.
  16. Apr 29, 2019 at 5:25 PM
    FOREx4
    FOREx4 New Member
    St. Charles, MO
    '21 Crewmax Sport - Black
    ReadyLIFT 3"/2" Lift Fuel Vector - Bronze 285/75r18 Nitto RG's Oh-so-neccessary console tray Tri-fold tonneau cover Murdered-out badges LED Light Mods All weather mats AJT Interior mods
    20190429_171017.jpg 20190429_185111.jpg 20190429_172537.jpg 20190429_170817.jpg Fun day of cheap mods...
  17. Apr 29, 2019 at 5:40 PM
    Nice retro look.:thumbsup:
    FOREx4[QUOTED] and KELZ84 like this.
  18. Apr 29, 2019 at 5:44 PM
    Cthulhu
    Nice! Please excuse my ignorance...what's that last mod, with the hose clamp?
  19. Apr 29, 2019 at 5:47 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Tail gate anti theft clamp
  20. Apr 29, 2019 at 5:47 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Keeps sticky fingers from stealing your tailgate :thumbsup:
    Cthulhu[QUOTED] likes this.
  21. Apr 29, 2019 at 6:03 PM
    Tundra17Tom
    Tundra17Tom Passin Thru
    2017 4X4 Tundra SR5 Double Cab 1G3
    HR LED interior HR LED Cargo Light HR LED Backup Light Raised black TUNDRA letters on tailgate Rear and Front bumper painted black Bilstein 5100s front and rear Method NV305 Matte Black Blacked out badges Debadge Iforce and SR5 AVS window vent visors TRD Pro Headlights Auxbeam LED headlight bulbs Driver side Oh Hell Handle
    Liking the blue
    Ostrich[QUOTED] and Hammerdog like this.
  22. Apr 29, 2019 at 6:14 PM
    Tundra17Tom
    Finally had a warm dry weekend to install some AVS window vent visorsIMG-2059.jpg
  23. Apr 29, 2019 at 6:25 PM
    FOREx4
    FOREx4 New Member
    St. Charles, MO
    That's not ignorance, that's a common sense question! I didn't know what it was either until I got on this forum. It's a super duper cheap way to keep someone from walking up to my truck and opening and the stealing my tailgate. Without something on the right side joint it's a simple - open, lift, unclip twice, and off you go with the entire tailgate. So, 1 dollar and thieves have to work a bit harder for it. I've owned three trucks before this one. Never had my tailgate lifted, but at $50,000, I definitely dont want to ride dirty back there, LOL!
  24. Apr 29, 2019 at 6:33 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Took it to the dealer for 30k maintenance. While I was waiting I walked around the lot to kill time and they had a 18 on the lot with a dealer "upgrade package" that had different wheels, tires (285/65r18), and what looked to be a 2/1 lift (above coil spacer and leaf blocks). I can't believe what a big difference the small lift and tires made, looked so much bigger than I thought it would have with those specs. It was interesting to see they actually cut the front fender liners to prevent rubbing, I would have thought that size would be ok (don't know the wheel offset).
    Deafmate likes this.
  25. Apr 29, 2019 at 6:46 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Installed the tech12volts remote start today. Pretty simple, used the instructions on Fortin's website. Even though its only 1 wire, i still cringed when i had to cut and splice it.
    Myhobbes25, darkknight2014 and Fotnot like this.
  26. Apr 29, 2019 at 7:47 PM
    Cthulhu
    Thanks, I see yet another mod in my future!
  27. Apr 29, 2019 at 9:17 PM
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    I just keep my tailgate locked all the time...
  28. Apr 30, 2019 at 4:58 AM
    rockcipher
    rockcipher New Member
    2015 Supercharged White CM
    BBK, 3" ADS, Deavers, TRD Exhaust
    New Black Rhino Tembes (20x9 +25) on 35x11.50 ridge grapplers.
    D3Tundra, hudrock, JoshuaA and 12 others like this.
  29. Apr 30, 2019 at 6:29 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    So I cleaned the hell out of mine, and took the Methods off. I put the factory wheels back on for a while, just not digging the black wheels for some reason. Seems like they always look dirty. D837BDB8-F963-4AAA-ADEE-6E5CF7943E8C.jpg
    ardnutoz, NAFlash, JoshuaA and 7 others like this.
  30. Apr 30, 2019 at 6:30 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    do you need my address to send those methods to? i don't want them taking up room in your place;) which ones ya got?
    escuzi_me likes this.
