Towing
Discussion in 'General Tundra Discussion' started by MEGALODON18, Apr 29, 2019.
  1. Apr 29, 2019 at 7:49 AM
    MEGALODON18
    MEGALODON18 [OP] New Member
    Kyle
    2018 tundra crewmax 4x4 5.7 v8 MGM
    None yet.
    I’ve seen different number on line. What’s the most towing capacity for 2018 tundra crewmax 4x4 iforce v8 5.7 help be great thanks.
  2. Apr 29, 2019 at 7:54 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  3. Apr 29, 2019 at 8:02 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    The Tundra CAN pull a lot more than it's rated, it has the power for it. The payload is going to be your limiting factor. The brakes, frame, and suspension just don't want to deal with large loads.
    Personally I'm not going to pull over 7k. That's a 4500lb trailer, loaded, and some gear in the bed. This is a safe, comfortable combination.
    I previously pulled a toyhauler for a year, 6-8 trips. That was 6600 empty, I was somewhere around 9k loaded. The truck handled it, but ultimately it didn't feel safe and wasn't fun on long trips.
    My point is that simply asking for the rated numbers is not your best bet, if you run it to the limits you're not going to be happy.
    landphil and Broncobroke like this.
  4. Apr 29, 2019 at 8:06 AM
    MEGALODON18
    Kyle
    None yet.
    Thanks guys.
    Faht Nocker likes this.
  5. Apr 29, 2019 at 8:17 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Hitch weight against your payload rating is often the bigger limiting factor, not just the tow rating.
    OBXTundra likes this.
