trailer sensing issue 2017 tundra
Discussion in 'Towing & Hauling' started by drsnow82, Apr 24, 2019.
  1. Apr 24, 2019 at 7:58 AM
    drsnow82
    drsnow82 [OP] New Member
    Duke
    2017 Tundra SR5 Double cab 8 ft box
    Howdy. My 2017 Tundra is not sensing my boat trailer. lights work but not the surge brakes on trailer. Not disengaging from a stop. Any ideas? Thanks.
  2. Apr 24, 2019 at 8:15 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    If your trailer has surge brakes, then the onboard brake controller does not have involvement with the brakes, most likely your surge brakes need to be looked at. I have seen them hang up with something jamming the movement.
    incredibillhulk and drsnow82[OP] like this.
  3. Apr 27, 2019 at 7:29 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    As stated above. Surge brakes are activated by the weight of the trailer pushing on the actuator. Has nothing to do with your trailer brake controller. Sounds like your actuator is stuck closed. Also if you have surge brakes you will be using a 5 wire system.
