Radio only shuts off when door is opened and shut
Discussion in 'Audio & Video' started by BOBONTUESDAY, Apr 19, 2019.
  1. Apr 19, 2019 at 9:44 PM
    BOBONTUESDAY
    BOBONTUESDAY [OP] Grocery Getter
    2016 Limited Trd
    Truck got stuck I did some hard winching. So the radio only shuts off now when the door. Is open and shut the truck has never done this before kinda freaked out. Is this a new entune update or am I having issues is this a setting I can change or am I having a new electrical gremlin
  2. Apr 19, 2019 at 9:53 PM
    Engine running? On accessory or?
  3. Apr 19, 2019 at 9:54 PM
    BOBONTUESDAY
    2016 Limited Trd
    Key pulled out engine off
  4. Apr 19, 2019 at 11:12 PM
    BOBONTUESDAY
    2016 Limited Trd
    Little update if I open and shut my driver side door it'll shut off. Then at times I'll have to slam the drive door to get the radio to shut off.
    Stock factory radio, 2016 limited
  5. Apr 19, 2019 at 11:44 PM
    BOBONTUESDAY
    2016 Limited Trd
    I suspect it to be the ignition going bad. Will update when I figure it out for info for others who have this issue.
  6. Apr 20, 2019 at 3:24 PM
    BOBONTUESDAY
    2016 Limited Trd
    New issue now my door locks won't lock and my radio won't turn off at all. I gotta get through the rest of the day before I can get back home to mess with it.
  7. Apr 21, 2019 at 4:45 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    You say you got stuck? Is there water or mud in the wiring or relay box?
    BOBONTUESDAY[OP] and Black Wolf like this.
  8. Apr 21, 2019 at 4:52 AM
    This^^^^^^I don't believe in coincidence. Some weird stuff going on and progressively worse...
    BOBONTUESDAY[OP] likes this.
  9. Apr 21, 2019 at 12:40 PM
    BOBONTUESDAY
    2016 Limited Trd
    It was pretty bad that's why assumed it was that I actually broke my winch cable I had my truck and dump trailer stuck but we got both of them out.
    So if I slam my door it turns the radio off turns out it's actually the steering wheel that needs a hit. After hitting the steering wheel I realized it is something in the steering wheel or column.
    I took the covers off blew all the dust out and now it looks like it went away I can't get it to come back lol
  10. Apr 21, 2019 at 12:46 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Black Wolf likes this.
  11. Apr 21, 2019 at 2:21 PM
    Kool. Whatever works!
  12. Apr 26, 2019 at 8:42 PM
    BOBONTUESDAY
    2016 Limited Trd
    Well it came back truck won't complelty shut off again I'm gonna go to the dealership in the am and have then see wtf is wrong with it.
