  1. Apr 25, 2019 at 5:02 PM
    #6391
    Outbound
    Aaron
    Northern Alberta
    32 Freedom Units over night, up to 45 maybe 50 during the day.
  2. Apr 26, 2019 at 6:16 AM
    #6392
    Will it be garage kept? I think it would be beneficial to sit overnight but may take longer to remove. Your call on that. You'll want some rough terry cloths if you don't already have them. Did you decide to skip the polish/sealant before waxing?
  3. Apr 26, 2019 at 7:54 AM
    #6393
    Professional Hand Model
    Fred
    Hand Protectors
    Gathered info this morning on these heated mirrors. Still not 100% sure, but I think the mirror plate itself is the only ‘factor’ distinushing between the non vs. heated option. That and a necessary switch assy in lieu of the blank next to Fogs. All the wiring seems to be already in place. Muuuhaaa.
    Maintaining the mirror theme, I scoped the 5-6 tabs necessary to ‘pop off’ the chrome mirror caps to facilitate tomorrows spray paint operation using the rattle can match that was specially formulated for me a few months back as there is plenty left over from the side doink repair.
    NUDRAT and TX-TRD1stGEN like this.
  4. Apr 26, 2019 at 8:07 AM
    #6394
    Outbound
    Aaron
    Northern Alberta
    No garage here. We had frost last night so i may wait till tomorrow morning to do the M7, let it sit till the late afternoon then carry on.
    I forgot about the sealant. I thought the M7 was the polish. What do you suggest for a polish/sealant?
  5. Apr 26, 2019 at 8:09 AM
    #6395
    I'd normally recommend you stick with Chemical guys since you bought their wax but I think something off the shelf would be fine. You could stick with the Meguiars theme. I'm not sure what's available up there for you.
  6. Apr 26, 2019 at 8:16 AM
    #6396
    Outbound
    Aaron
    Northern Alberta
    Meguiars is the easiest to find but still limited. Local shop only has 2 or 3 Chemical Guys products. I'll see what they have for sealants. They do have a product by a company called Sans-Zo. Never heard of them before.
  7. Apr 26, 2019 at 8:18 AM
    #6397
    Outbound
    Aaron
    Northern Alberta
    It may end up being moot and i can order stuff online. Weather report changed. Supposed to snow tomorrow now.
  8. Apr 26, 2019 at 8:38 AM
    #6398
    Dpy
    Dpy New Member
    Drove truck to Augusta Ga and picked up my new single column car lift. suspension on ole Tundra bottomed out pretty much . At least I know the lift is hefty . Crap , I may never go back in the house when I get this lift put together, I be lifting everything in sight.
  9. Apr 26, 2019 at 9:22 AM
    #6399
    TravisT4
    TravisT4 New Member
    Travis
    Hartland WI
    2006 Tundra Double Cab TRD
    I put this little thing in to allow me to play my phone using bluetooth through the factory head unit. So far I am really happy with it. It plugs into the back of the head unit and I routed the cable into the glove box. Super easy it only took 10 min.
  10. Apr 26, 2019 at 2:21 PM
    #6400
    Fred
    Hand Protectors
    Sitting in the garage as a Hurricane Force Storm with 50-60 mph winds passed through. Dead big branch (pictured as landed) fell and broke on impact with the end piece barely missing the truck ending up underneath.
    Any closer and I’d be in the 3rd Gen Section cwying about a wittle scwatch.
    faviles, NUDRAT, bmf4069 and 3 others like this.
  11. Apr 26, 2019 at 3:53 PM
    #6401
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Went up in the hills to pick up some elk antlers, coming down on a section of bad road I heard a massive pop and found this.
    Going to have to snag a cutting wheel from work to cut that damn nut and Allen key stud off because I cannot get that sucker to come off for the life of me.
  12. Apr 26, 2019 at 4:01 PM
    #6402
    seachunk2
    seachunk2 New Member
    2004 Tunda DC V6 4WD SR5 AT
    Yep, same thing happened to mine not long ago. Not an expensive or difficult fix but who needs the hassle???
    Filthyphil likes this.
  13. Apr 26, 2019 at 4:02 PM
    #6403
    Filthyphil
    Phil
    Exactly, I was thinking when I got out that my ball joint gave up the ghost.
  14. Apr 26, 2019 at 4:05 PM
    #6404
    Fred
    Hand Protectors
    I remember that distinct ‘pop’ sound when mine busted about 7 years ago. Wonderd what the heck? Kept driving and didn’t think twice about it until a few days later when the handling felt sloppy.
    Filthyphil[QUOTED] likes this.
  15. Apr 26, 2019 at 4:20 PM
    #6405
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That whole part is missing on my truck. :D
  16. Apr 26, 2019 at 4:27 PM
    #6406
    Filthyphil
    Phil
    I thought about saving the $30 for a new end link and just taking the sway bar off haha but I’m not sure how that would make the truck drive.
  17. Apr 26, 2019 at 4:33 PM
    #6407
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You're half way there right now. It would lean quite a bit on stock springs but nothing that would feel dangerous. $30 isn't too bad, there are heavy duty versions that look very stout but I think they run around $150 a pair.
  18. Apr 26, 2019 at 4:40 PM
    #6408
    Fred
    Hand Protectors
    I got used to teetering around corners and slow lane changes at speed. Speed bumps felt better, but overall I disliked it for the years it was busted. Not even sure of when the other link busted (years later?) and didn’t notice until last year when getting serious about restoration.
    Just cut the other link and run it hanging like mine was. You might enjoy it on those bad roads. Street not so much.
  19. Apr 26, 2019 at 5:19 PM
    #6409
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A lot of times if you can get a pair of vise grips in there you can clamp down on the boot and get it loose.
  20. Apr 26, 2019 at 5:27 PM
    #6410
    Outbound
    Aaron
    Northern Alberta
    Putting the M7 on right now. Hood is done. Pretty happy with it so I dont think I need to let it soak over night.
  21. Apr 26, 2019 at 5:29 PM
    #6411
    Dpy
    Dpy New Member
    Not tundra related but first car on my new lift .
    abcinv, NUDRAT, TX-TRD1stGEN and 7 others like this.
  22. Apr 26, 2019 at 6:14 PM
    #6412
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Went to the salvage yard today and got all the parts for my rear disc brake conversion and a j shift 4Runner transfer case for my manual case swap. Has anyone on here done a full manual transfer case conversion? If so what case did you use?
  23. Apr 26, 2019 at 7:11 PM
    #6413
    Casper421
    In the woods
    06 DC
    I’ve been contemplating a rear disc conversion so this is perfect. Be sure to keep us posted.
    There might be some info on the T-case over on tundrasolutions. @Darkness should know.
    ethan1911[QUOTED] likes this.
  24. Apr 26, 2019 at 7:12 PM
    #6414
    Outbound
    Aaron
    Northern Alberta
    Got the entire truck Nanoskinned and M7 applied/buffed except the roof then the weather started rolling in. The Woman took over the M7 job while I used the Nanoskin mitt. That really helped speed it up.
    Hopefully it clears up tomorrow and we can do the wax.
    Here's the difference the M7 made. Front panel has the M7 and the door panel is just Nanoskinned.
    abcinv, NUDRAT, TX-TRD1stGEN and 3 others like this.
  25. Apr 26, 2019 at 7:17 PM
    #6415
    From what I can tell it already looks a lot better. What do you think? Cool of your wife to help.
    Outbound[QUOTED] likes this.
  26. Apr 26, 2019 at 7:25 PM
    #6416
    Outbound
    Aaron
    Northern Alberta
    I think it looks really good. Pretty happy with how it turned out.
    Yeah, The Woman is the best. I poured her a glass of scotch as a thank you. :D
  27. Apr 26, 2019 at 7:45 PM
    #6417
    Filthyphil
    Phil
    I ended up taking a skinny wheel and just taking the bolt head off and replaced it. Easy fix..
    NUDRAT likes this.
  28. Apr 26, 2019 at 9:47 PM
    #6418
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    20190426_213937.jpg Went had some fun out in our beuatifull PNW in the ol' beauty 20190426_191840.jpg 20190426_175524.jpg
  29. Apr 27, 2019 at 4:23 AM
    #6419
    Took a closer look this morning. You're right. Make sure you get a coat of wax on it today and you'll be G2G.
  30. Apr 27, 2019 at 6:35 AM
    #6420
    I read up on it. There's a thread in TS where a dude put sequoia stuff on. IIRC you have to upgrade the master cylinder since ours want designed for the pressure rear discs need. I could be wrong on that though. I'd be interested in both of those mods though. Definitely start a new thread if you take on that headache!
