Trailer Lights Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Craig.50, Apr 24, 2019.
  1. Apr 24, 2019 at 4:45 PM
    Craig.50
    Craig.50 [OP] New Member
    Craig
    2016 Tundra
    I think I have a ground issue but I'm not for sure hoping someone knows. My trailer lights flicker when the trailer bounces,doesn't do it when loaded. What is causing this?
  2. Apr 24, 2019 at 4:47 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    The trailer is likely to bounce more when empty, so it sounds like there may be a connection or maybe a bulb loose enough to break continuity when the trailer creates enough jostling.
    NewImprovedRon likes this.
  3. Apr 24, 2019 at 5:20 PM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    On trailers, it's seems to always be a ground.
  4. Apr 24, 2019 at 5:25 PM
    Jrharvey02
    Jrharvey02 New Member
    X 1 million
  5. Apr 24, 2019 at 5:29 PM
    cslax35
    cslax35 New Member
    Liverpool, NY
    2018 Super White CrewMax TRD
    Rust on the ball? Maybe not getting good contact... take some steel wool to it first before digging around
  6. Apr 24, 2019 at 5:38 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If it's grounding through the ball you already have an issue.
    A multi tester to check voltage and continuity through the lighting is the way but if it's intermittent it may take a few tries.
  7. Apr 24, 2019 at 6:54 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    + another
  8. Apr 25, 2019 at 9:12 AM
    davescarp
    Massachusetts
    '18 DC TRD OR
    what kind of trailer we talking about? On my boat trailer, I use a self tapping stainless steel screw for my primary ground and use LED lights that have a dedicated ground wire (also connected with a self tapping stainless screw). The lights that ground through their post/attachment bolt are lousy and frequently with a tiny bit of rust will lose ground. I've run my trailer like this for nearly 10 years now in and out of saltwater every week for 4 months during the summer without a single issue. Shit, now i've jinxed myself.
  9. Apr 25, 2019 at 7:42 PM
    Craig.50
    Craig
    2016 Tundra
    It's a Karavan snowmobile trailer that I use for my four wheelers. On my Dodge it was fine but with my tundra I'm having the issue,once the trailer comes off the ball they go out and once back down they come back on.
