Need opinions
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Apr 24, 2019.
  1. Apr 24, 2019 at 9:23 AM
    FirstGenVol [OP] Recovering mangler
    @Casper421 @Darkness @Brown Bear @Rheywood456 @Swalters @because_v8 Calling all those that have lifted.
    Now that the front ICON's have arrived and the rear are arriving today I'm unsure what I should prioritize next. Obviously there is only so much money to fork out in a short time period.
    My plan was to run the OEM UCA's for a while and try to catch a black Friday deal. I was going to order the wheels and tires first and then deal with the UCA's later. I'm expecting to have to do something with the CV axles as well. They are fine now but I don't know how long those boots will hold up.
    Do you think I'll be unhappy driving around with the stock UCA's for another 7 months? Should I go ahead and get new UCA's and put the wheels and tires on hold?
    Should I just donate some plasma and open my wallet for all of it?
    Gracias!
  2. Apr 24, 2019 at 9:42 AM
    Casper421
    In the woods
    06 DC
    I’m not sure if you’ll be able to get your alignment in spec with oem uca’s. I personally would get all the suspension parts first and hold off on the wheels/tires. That way your alignment would be in spec and you can keep an eye out for a deal on wheels and tires.
    Sell a kidney, you have two and they’re worth more. ;)
  3. Apr 24, 2019 at 9:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    from what I've heard, the OEM UCAs are good to keep alignment in spec up to about 2.5-3". I have a 2-2.5" spacer lift up front and the shop was able to get everything dialed in.
  4. Apr 24, 2019 at 10:24 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I ran stock uca at 3.5" of lift for almost a year without alignment problems, but they were clacking hard on speed bumps. If you are staying in the +2" range you should be okay that way, but keep in mind you'll be paying for alignment twice.
    lsaami likes this.
  5. Apr 24, 2019 at 10:29 AM
    I think the ICON's should be around 2.5" of lift. I'm I'm running an inch lower than you I might not bottom out on the speed bumps. Maybe I'll do the install and see how close it looks.
  6. Apr 24, 2019 at 10:54 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If its temporary you can adjust your driving habits to be mindful of bumps for a while. Then your only concern is tire clearance.
  7. Apr 24, 2019 at 11:09 AM
    Professional Hand Model
    Fred
    Hand Protectors
    @FirstGenVol after install day.
  8. Apr 24, 2019 at 11:27 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
  9. Apr 24, 2019 at 3:33 PM
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    I would get an alignment and go from there. If it's able to be aligned and your upper ball joints look good, keep stock uca and get tires at least. I ran a full 3" king lift with fucked up stock uppers on my 4runner for awhile before I got some camburg uppers haha
    Darkness likes this.
  10. Apr 24, 2019 at 3:39 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Need opinions
    If you need to have a license to drive, hunt, fish, etc then you should need to have a license to breed.
    Trooper2 and Darkness like this.
  11. Apr 24, 2019 at 4:49 PM
    bmf4069 likes this.
  12. Apr 24, 2019 at 6:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Casper421 likes this.
  13. Apr 25, 2019 at 8:04 AM
    I wouldn't mind some feedback on different UCA options. There isn't a ton of price difference between SPC($640), Total Chaos($765) and Camburg($664).
  14. Apr 25, 2019 at 8:53 AM
    Casper421
    In the woods
    06 DC
    Are your Icons the normal or et version? Et co’s recommend Uniball uppers to achieve the advertised travel.
  15. Apr 25, 2019 at 9:10 AM
    Standard travel.
  16. Apr 25, 2019 at 10:42 AM
    Casper421
    In the woods
    06 DC
    SPC is a good option but $640 seems high. The oem balljoint design requires almost no maintenance while Uniballs need to be lubricated and cleaned periodically.
  17. Apr 25, 2019 at 10:57 AM
    Ya I remember reading that the SPC's were closer to $500 but I can't seem to find any for that price. Thanks for the feedback. I'll keep looking.
    Casper421[QUOTED] likes this.
  18. Apr 25, 2019 at 12:05 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    They can be found.
    https://www.ebay.com/p/Alignment-Ca...Front-25485/174950238?iid=372293304647&chn=ps
    FWIW I've had mine on now for almost 2 years and the ball joints are still tight. I throw a couple pumps of grease into them every oil change and that's it. Alignment was still good at 1 year and I'll have it checked again this summer.
  19. Apr 25, 2019 at 12:55 PM
    Nice! I watched a video on installing these and the guy mentioned that these didn't originally have greasable ball joints. He said to make sure the ones you receive do. It's been a few years now so I'm thinking the chance of receiving old inventory has to be low. Did you have issues with the install? It looks easier than I realized.
  20. Apr 25, 2019 at 2:09 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Nope, hardest part was figuring out what adapters I needed to press out the old ball joint.
    Even with that I think it took all of an hour for both sides.
  21. Apr 25, 2019 at 2:55 PM
    Swalters
    Sam
    Arizona
    My total chaos arms required me to trim the coil bucket a little. But other than that I love them. I have camburgs on my 4runner and I love them, too. I've heard good things about SPC, I'd rather just spend the little extra on uniball. Cleaning and lubing them isn't that hard.
  22. Apr 25, 2019 at 4:00 PM
    Casper421
    In the woods
    06 DC
    Interesting, did you have to trim both coil buckets?
  23. Apr 25, 2019 at 4:16 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
  24. Apr 25, 2019 at 4:20 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not for the 1st Gen trucks they don't.
    FirstGenVol[OP] likes this.
  25. Apr 25, 2019 at 6:09 PM
    Swalters
    Sam
    Arizona
    Yes
