DIY OEM Fender Flare Brackets
Discussion in 'Wheels & Tires' started by Myhobbes25, Apr 25, 2019.
  1. Apr 25, 2019 at 3:35 PM
    Myhobbes25
    Myhobbes25 [OP] New Member
    Jeffery
    Western Washington
    2014 Toyota Tundra Platinum
    Rigid fog Lights, 35x12.50x20 BF Goodrich KO2 Tires, 20x9 Fuel Trophy Wheels, Pro Comp Stage 2 Full Suspension Lift 6 inches, K&N Intake, Magnaflow Muffler, Husky X Contour Floor mats, Pina Colada Scented Tree
    I picked up a used set of fender flares that did not have the "Clips." I figured, that was no big deal and I could get some from the dealer. WRONG!
    After taking a look at what they were, I figured I would make make own.
    Buy these from your local hardware store, straighten slightly and remove rubber piece.
    locate hole for mounting bracket
    place bracket in hole and push flare tight to fender. Mark where you are drilling new hole
    Drill 1/4 in hole and add screw. DONE!
    These were $1.30 per pair
    This may work with other aftermarket flares as well.
    Ricos, bhuff92 and GAknight like this.
