Fuel Gauge / MPG
Discussion in '2.5 Gen Tundras (2014-2021)' started by Str8up50, Apr 16, 2019.
  1. Apr 16, 2019 at 8:26 AM
    Str8up50
    Str8up50 [OP] New Member
    WL
    S Louisiana “Chasin Redfish”
    2016 Tundra DC
    So I recently purchased a used 16 DC SR5 with the larger fuel tank. I've been monitoring my mileage and fill ups. I usually fill up when the display says 37 miles to empty. However when I'm filing up, it barely takes 20 gallons. Is this normal? How big is the reserve fuel tank? Can it be reprogram Ed?
  2. Apr 16, 2019 at 8:29 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    I got a 38 gal tank and it usually reads empty with 10gal plus in it too..
  3. Apr 16, 2019 at 8:34 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I've got the 26 gallon and normally its about 20 gallon fill up for me. I think its because the truck is designed to keep the fuel pump/sender submerged in fuel.
  4. Apr 16, 2019 at 8:37 AM
    Jrharvey02
    Jrharvey02 New Member
    That whole pump submersion is a myth, our gas lights come on at 20 gallons for the 26er and 30 for the 38er, OP it sounds like you got the smaller tank unless somethings messed up...
    landphil and bdpeelgren like this.
  5. Apr 16, 2019 at 8:56 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    bdpeelgren likes this.
  6. Apr 16, 2019 at 10:16 AM
    Str8up50
    WL
    2016 Tundra DC
    Well I'm looking at my window price spec sheet and it says with SR5 upgrade adds larger 38 gallon tank
    I know I've read on this forum that the fuel guage/display was not in-sync with larger fuel tank as some were saying is "generous" with the term EMPTY.
  7. Apr 16, 2019 at 10:34 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    If you go here:
    https://www.toyota.com/owners/my-vehicle/vehicle-specification
    Register and enter your VIN. It will tell you how it came from factory.
  8. Apr 16, 2019 at 10:42 AM
    Str8up50
    WL
    2016 Tundra DC
    Did that. Just pretty much says SR5 Upgrade Package. No mention of fuel tank
  9. Apr 16, 2019 at 10:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would agree. DCs often have the smaller tank. Email the vin to Toyota and they will email you specs. I drove mine for 50 miles after the light came on last week and it took 30.5 gallons. The miles remaining must have been in the negatives because it would not even display. Most I have put in is 31.5.
  10. Apr 16, 2019 at 10:46 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I'd have to agree with the rest, sounds like you have the smaller tank. I am fairly certain the the bigger tank is an individual add, my SR5 does NOT have the bigger tank so it's not a "package" upgrade.
    On a side note, what MPG app is that you're using and how do you like it?
  11. Apr 16, 2019 at 10:48 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I know on the 2017+ CMs the larger tank comes as part of the SR5 upgrade package. Not sure about DCs.
  12. Apr 16, 2019 at 10:58 AM
    Str8up50
    WL
    2016 Tundra DC
    Medic343. I'm using the car fax app. Hard to tell if I like it until I get this issue resolved
  13. Apr 16, 2019 at 11:19 AM
    Str8up50
    WL
    2016 Tundra DC
    Thanks all. I called Toyota and learned that the larger fuel tank only comes with the 5.7 and not the 4.6. No biggie at least now it's no longer driving me crazy
  14. Apr 16, 2019 at 1:15 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    On the 2016+ SR5's you get the 38 gallon tank when you bump up to the "Upgrade" package. It's standard on the Limited and Platinum.
  15. Apr 16, 2019 at 1:31 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Forgot about that one. I think it applies to tow pkg too.
  16. Apr 24, 2019 at 6:08 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Love my 38 gal tank. HUGE improvement over my old 26
