Dumb question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Darthinvader48, Apr 22, 2019.
  1. Apr 22, 2019 at 1:04 PM
    Darthinvader48
    Darthinvader48 [OP] New Member
    2019 Black tundra SR5 TSS 4x4
    so I was watching some videos on YouTube about how our limites slip sucks compared to Chevy. I just wanted to verify when I put my tundra in 4 low do all 4 wheels lock and spin at the same speed? I know 4 hi and 2wd don’t but their not supposed to. I have videos of my 07 spinning all 4 wheels in the mud and sand on 4 low did something change?
  2. Apr 22, 2019 at 1:46 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    no, they do not. the only way to lock the wheels together is with... lockers.
    we also don't have LSDs, the diffs are open. Toyota simulates LSD by using the brakes to stop/slow the tire that's spinning, to send power to the other wheel.
  3. Apr 22, 2019 at 2:22 PM
    Darthinvader48
    Wow I always thought they locked up when it went to 4 low...
  4. Apr 23, 2019 at 11:49 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    they used to offer locker but they dont. The LSD is not a true LSD as stated by ChrisTRDpro
    THIS
  5. Apr 24, 2019 at 12:07 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Nope wide open diffs all around. Bummer right.
  6. Apr 24, 2019 at 1:18 AM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Nothing wrong with ATRAC.
    15whtrd likes this.
  7. Apr 24, 2019 at 8:50 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I think it’s application specific.
    1engineer[QUOTED] and Tundyfundy like this.
  8. Apr 24, 2019 at 8:56 AM
    Yep.... and not that great...
  9. Apr 24, 2019 at 10:30 AM
    1engineer
    Appalachians
    Not as good as locked front and rear, not as bad as open diffs. As good as or better than the competition. While I have not off roaded the Tundra much, the 4Runner I had and the Tacoma both did just fine off road and in the snow with ATRAC. I had the Tundra in several snowstorms a few months ago and it did fine.
    What is it you guys want that you think would be better? :confused:
    15whtrd likes this.
  10. Apr 24, 2019 at 10:32 AM
    ATRAC in combination with a real LSD.
    Darthinvader48[OP] and 15whtrd like this.
  11. Apr 24, 2019 at 10:41 AM
    Tundyfundy
    Bay Area, CA
    Don’t quote me but I don’t think the newer tundras have ATRAC. It was my understanding ATrAC is not the system we are running now. I believe we have VSC and AutoLSD. No A-trac if there’s no button.
    RussellVaughan likes this.
  12. Apr 24, 2019 at 10:51 AM
    Tundyfundy
    Bay Area, CA
    ATRAC works in 4-lo but we don’t have any factory traction systems for 4-lo as the truck disables then after 4-lo is engaged.
