Minimum lift to fit -76 with 20x12 and 35s??
Discussion in 'Suspension' started by CamaroSsToTundra, Apr 17, 2019.
  1. Apr 17, 2019 at 5:15 AM
    CamaroSsToTundra
    CamaroSsToTundra [OP] New Member
    Ohio
    2018 Tundra
    I am trying to figure out what is minimum lift I need to fit -76 offsets wheels 20x12 size and 35x12.5R20 without too much trimming? Is anyone here running that offsets?
  2. Apr 17, 2019 at 5:38 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  3. Apr 17, 2019 at 6:28 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    This is my old setup where I was running 8" readylift and 22x14 on 37.13.5s. Due to the offset, I had to push the bumper forward but at the time I didn't have the BMC. if you did the BMC, trimmed AND pushed your bumper forward, you should be able to clear on a 6". Any lift smaller than that and you'll most likely be rubbing the actual truck wells.
    CamaroSsToTundra[OP] and Berdine like this.
  4. Apr 17, 2019 at 6:36 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    16” or 17” diameter wheels would be a better choice for lift kit with big tires.
    CamaroSsToTundra[OP] likes this.
  5. Apr 17, 2019 at 6:49 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    So with 6 inch lift or 7 inch lift and 20x12 wheels I can fit -76 with little bumper trim? I don’t care about bumper but I am trying to avoid body mount trim with minimum lift. I am good with little bit rubbing on full lock.
  6. Apr 17, 2019 at 6:59 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Well a 20x12 will be a -44 offset and is much more common.. Only real degenerates, like myself, would run a 14 wide :rofl:
    But to answer your question, you will rub on a 14 wide with no BMC, unless your running an 8" with adjustable coils cranked up to 10" at least... BUT, once you get use to driving it that way and you know the limitations of the truck, the rubbing goes away. With my 8" and 22x14, I wont lie the rub was pretty bad. If I ever got my truck washed the guys would not understand and would just cut the wheel as much as they could to park. Literally everyone in the establishment would look to see what the hell was going on cause it was not a pleasant sound lmao.
    If you choose a 20x12, 6" should be plenty, may have a little rub, but nothing crazy.
  7. Apr 20, 2019 at 6:56 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    The BMC is so easy and inexpensive to have done though. I spent $30 on the plates and $180 at a local fab shop. Was done in a couple hours.
  8. Apr 21, 2019 at 8:05 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    I don’t not feel comfortable to mess up with body frame part.
