SQUEAKY REAR SUSPENSION? ICONS? SWAYS?
Discussion in 'Suspension' started by Macreggg, Apr 20, 2019.
  1. Apr 20, 2019 at 10:41 PM
    Macreggg
    Macreggg [OP] TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Finally took the truck off road today and to my surprise I think my ICONS are squeaking in the rear? Could it be AAL? Could it be the sways rubbing? Overall the truck performed amazingly but that squeak is annoying...
    Anyone else have these issues?
    Btw these were just installed last week...
    escuzi_me likes this.
  2. Apr 20, 2019 at 10:45 PM
    Sunnier
    Sunny
    San Diego, CA
    Usually remove sway bars for off-roading. By his I mean, sway bars are good if you want it to turn without rocking in corners, on pavement, but they limit articulation needed for off-road performance. Based on what I've read on here, squeaks at the back seem usually to be leaf packs. Tighten em up and see how it sounds.
    Bigboitundra likes this.
  3. Apr 20, 2019 at 10:48 PM
    Macreggg
    Mel
    Los Angeles, CA
    Yes def remove the sways next time. Kind of a spontaneous trip with the family so had no chance to get them off.
    I’ve looked at Tacoma and 4Runner boards already and it seems to be a common issue fixed by a monthly lubing of either Tri-Flow or Lithium Grease.
    Sunnier[QUOTED] likes this.
  4. Apr 20, 2019 at 10:50 PM
    Macreggg
    Mel
    Los Angeles, CA
    Also need to get all the bolts re tightened next week since I’m approaching 500 miles with the new suspension on so this problem is gonna get solved one way or the other.
    Sunnier likes this.
  5. Apr 21, 2019 at 4:52 AM
    timsp8
    NY
    I had a squeak on my 10. I sprayed white lithium grease on my leafs every month or so to make it stop.
    Black Wolf likes this.
  6. Apr 21, 2019 at 5:05 AM
    Yep.....I use "Blaster" white lithium. Costs only $5 a can.:thumbsup:
    TheBeast likes this.
  7. Apr 21, 2019 at 11:53 AM
    Macreggg
    Mel
    Los Angeles, CA
    I got some CRC white lithium today sprayed a coat on the leafs we will see if it works.
  8. Apr 21, 2019 at 12:16 PM
    Macreggg
    Mel
    Los Angeles, CA
    Went under the body and bounced the rear a little from the bottom and that squeak is super annnnnoying.
  9. Apr 21, 2019 at 12:36 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    They’re garbage. Send em to me :cool:
  10. Apr 21, 2019 at 2:53 PM
    M C M
    M C M New Member
    If it's the ICON expansion pack, they are usually missing the sliders for the main leaf of the expansion pack and it rubs metal on metal and makes the squeak.
    Macreggg[OP], 831Tun and TheBeast like this.
  11. May 25, 2019 at 5:24 PM
    2chains
    2chains New Member
    Southern Ablerta
    Did you find the source of the squeak?
    How are you liking this setup at this point?
  12. Apr 15, 2021 at 6:20 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    I have the same issue with my icon suspension. Did spraying the leaf pack work?
  13. Apr 15, 2021 at 6:22 PM
    I dress up my leaf packs with Fuid Film and it works quite well. I used the straw thingy on the can and spray liberally between each leaf.
  14. Apr 19, 2021 at 3:31 PM
    Macreggg
    Mel
    Los Angeles, CA
    It works but temp fix. Still squeaky but I just got used to it.
  15. Apr 19, 2021 at 4:10 PM
    Sitting Sideways
    Beaverton, Oregon
    I have sprayed it down twice now and the squeak still persists. I will just have to get used to it I guess. It was worth a try though
