Just some TRD brake caliper porn...
Discussion in 'General Tundra Discussion' started by airosey, Apr 20, 2019.
  1. Apr 20, 2019 at 8:54 PM
    airosey
    airosey [OP] 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Did a little refresh on the brakes since they had to be disassembled for powdercoat. I installed new boots, seals, etc. painted the caliper bridge bolts black and added the black TRD logo. Finished up with a couple coats of ceramic coating. I’m very happy with how they turned out!
    69C67517-5869-4A24-BEAE-8162BDABEC43.jpg 3BCB3F80-9D26-4F96-B149-9FA54AD85ADE.jpg C42A94C7-6311-4A34-8359-60DD96634614.jpg 4A741EA0-DB53-4649-9447-E988DFBD8CA2.jpg 654AAA1E-2B50-44A1-ABB0-04B80D40D7DA.jpg 9DD34878-86E9-412C-9825-1300841FC786.jpg
    Beesta, mtntop, Texas Bandit and 13 others like this.
  2. Apr 20, 2019 at 8:57 PM
    Redbeard87
    Redbeard87 Machinist Extraordinaire
    2016 Tundra Crewmax SR5 4X4
    Amazing job!
    airosey[OP] likes this.
  3. Apr 20, 2019 at 8:58 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    That's a little different and funny. That equals... u know...
  4. Apr 20, 2019 at 9:04 PM
    airosey
    Incredible stopping power? :notsure:
    gosolo likes this.
  5. Apr 20, 2019 at 9:52 PM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Nice work! I’ve been wanting to do the same but I’ll have to figure out how much work it involves. I’m a bit hesitant in having to tear apart my breaks to do a good paint job.
  6. Apr 20, 2019 at 10:34 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Wow, you painted those yourself? Wanna do mine?
    Black Wolf likes this.
  7. Apr 21, 2019 at 5:07 AM
    airosey
    No I had a shop powdercoat them. I just did the rebuild.
    Sas[QUOTED] and Black Wolf like this.
  8. Apr 21, 2019 at 5:11 AM
    Came out looking real fine!
    airosey[QUOTED][OP] likes this.
  9. Apr 21, 2019 at 5:17 AM
    cslax35
    cslax35 New Member
    Liverpool, NY
    2018 Super White CrewMax TRD
    They’ll look awesome! Was driving home yesterday from our River House when the wife and kids were sleeping and was thinking about how I would do mine.
  10. Apr 21, 2019 at 5:44 AM
    airosey
    Here’s a pic from last year comparing the size of the original brakes with the TRD big brake kit. For those of you wanting to paint, I used the G2 caliper paint on my original calipers (in gold below)
    07 Tundie, Toyotoholic and Black Wolf like this.
