360$ Out the door a good deal on Northstar 27F?
Discussion in 'General Tundra Discussion' started by Tierhog, Apr 19, 2019.
  1. Apr 19, 2019 at 8:57 PM
    Tierhog
    Tierhog [OP] SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Free ship?
    27F battery terminals on the right side?
    Should cables be upgraded?
  2. Apr 19, 2019 at 9:22 PM
    Tierhog
    Thanks Ron.. Good info.
    Watt maker likes this.
  3. Apr 19, 2019 at 9:58 PM
    Tierhog
    Why does every picture I see have the terminals backwards?
    Thank you by the way.. Im pulling it up now.
  4. Apr 19, 2019 at 11:26 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Watt maker, ColoradoTJ and TRD15559 like this.
  5. Apr 20, 2019 at 5:45 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Bought mine on Ebay from GP audio during a 15% off coupon code.
  6. Apr 20, 2019 at 6:35 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    $340 for a battery? Are you out of you mind. You could of bought an optima which is just as good or better for less. I know batteries are expensive, but that is too much. Forget about it
  7. Apr 20, 2019 at 6:38 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Thanks @Toyotoholic . Just ordered from gp audio. I am still running factory battery, so I fiquired I would be proactive and swap it before it died.
    Toyotoholic likes this.
  8. Apr 20, 2019 at 6:45 AM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    What is so special about this lead acid battery?
