2014 Tundra 10 MPG is this normal
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Jamerican, Apr 17, 2019.
  1. Apr 17, 2019 at 11:31 PM
    The Jamerican
    The Jamerican [OP] New Member
    Springfield, MA
    2014 Brown1794 Edition
    BullBar with lights
    My 2014 1794 Tundra gives between 9.6 to 10 mpg. Is this normal. How do i improve. 50k+ miles
    Coolhardy likes this.
  2. Apr 17, 2019 at 11:36 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Lighter foot on the pedal. That's all I got. I have been averaging between 13 and 14 lately. Lots of highway miles though. If I'm in town all week and fighting traffic... I'm getting around 10 mpg.
    RoujePN and Coolhardy like this.
  3. Apr 17, 2019 at 11:41 PM
    The Jamerican
    Springfield, MA
    BullBar with lights
    I am light with the pedal. My comute is very short in traffic most times and that is my reading normally 9.6mpg. I thought it was normal until I saw thread today persons saying they get 13mpg. On the highway today I was doing 65mph to 70mpg it went up to 10.1mpg
  4. Apr 17, 2019 at 11:43 PM
    The Jamerican
    Springfield, MA
    BullBar with lights
    This was today on the highway
  5. Apr 17, 2019 at 11:54 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I get around 13 combined. On short drives I’ll get 10 or so. On longer drives with highway driving I’ll get 14-16
    OR18TRD and realtorblake like this.
  6. Apr 17, 2019 at 11:54 PM
    realtorblake
    Traffic mileage sucks... no way to sugarcoat it. It is what it is.
    RoujePN, 15whtrd and Watt maker like this.
  7. Apr 17, 2019 at 11:57 PM
    realtorblake
    That's pretty true to what I am seeing.
  8. Apr 18, 2019 at 12:33 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Disconnect the negative battery cable for about 10 minutes, this will reset the computer. It will relearn your driving habit and the mpg should go up. I'm getting 15.3 mpg, 22 miles to work one way, 50/50 highway and city.
    hitech and Watt maker like this.
  9. Apr 18, 2019 at 2:22 AM
    cslax35
    cslax35 New Member
    Liverpool, NY
    2018 Super White CrewMax TRD
    Try putting a can of Seafoam in it before your next fill-up. For me, I saw a 3mpg difference...
  10. Apr 18, 2019 at 3:23 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Keep it stock, or get used to crappy mileage. Pretty simple. I am stock, drive the speed limit, and this is what I get:
    SSFTundra, Eric32444, Pinay and 2 others like this.
  11. Apr 18, 2019 at 4:44 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Very short commutes in traffic are going to translate to lower MPG for sure. I think you'd find yourself on the low end of fuel efficiency in any vehicle, it's just the nature of that type of driving.
  12. Apr 18, 2019 at 4:51 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Short trips are considered ‘heavy service’, as well. Oil change intervals need to be shortened due to the engine not getting up to operational temps for extended periods. The moisture in the oil will not burn off.
    In general for any vehicle, long highway miles are good and short trips are bad. These trucks are not good on the MPG.
    15whtrd likes this.
  13. Apr 18, 2019 at 5:24 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Depends on your tires and lift bro
    Pinay likes this.
  14. Apr 18, 2019 at 5:26 AM
    Mnorris1206
    08 tundra
    I say do the math. Depending on a computer is not always a good thing .
  15. Apr 18, 2019 at 5:40 AM
    tundraty
    tundraty New Member
    Fort Worth, TX
    2022 Celestial Silver SR5 CM 4x4 TSS Off-Road
    I would hand calculate it as others have said. Also, try resetting the average fuel economy when you get on the highway next time to get a better idea of your highway mpgs specifically. Check what it reads as soon as you exit the highway and hopefully you have better results.
  16. Apr 18, 2019 at 5:44 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I recently upgraded to my Tundra from a Z71. Drove Chevy's since '99. Needless to say, I was in MPG shock when I got the Tundra. Much research and lurking on forums and realize that the Tundra is what it is. Had to stop comparing to a Chevy before I really started to love my truck. Computer is anywhere from 9.3 to 13 city driving. I live 19 miles from work. Some city and rural roads on drive everyday. When I shut the truck off I usually get around 15.5 (computer) on my commutes. Overall tank average (computer) averages around 15.5 Recently took it on a trip to B'ham AL, around 459 miles to destination. Filled up before I left and pushed it until around 20 miles to empty (computer). Almost 31 gallons to fill up, average around 15. We had an infant with us so we had some stops and idling time. Truck only had a little over 5k on it for that trip.
    Black Wolf and bvia like this.
  17. Apr 18, 2019 at 5:52 AM
    The Jamerican
    Springfield, MA
    BullBar with lights
    Thank you all for responding. Appreciated. In winter I do warm up before so now i understand that effect. I also realized that my short commute and traffic contribute. I do service often. I am at Balise at the moment as I am typing this having just done 2500 between service. Just schedule service. Oil is synthetic so no change. Tire rotation.
    One thing for the forum. One of my tire had to be pumped twice within 3 weeks. They just check and told me the tire-pressure sensor o-ring was the faulty point. Replacement is $120. if anyone experience the same thing they know that possibility. I
    driverdog likes this.
  18. Apr 18, 2019 at 6:08 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Where is that data info in the system?
    Major and wipfel like this.
  19. Apr 18, 2019 at 6:10 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    Unless you reset it while you're driving the trip computer is not instantaneous readings. It's a calculation based off your total mileage/economy since you last reset it. So if you hadn't reset it in 3000 miles and only drove 50 miles on the interstate it's going to have little or no effect on changing the output.
    TomyTun and xanderpope like this.
  20. Apr 18, 2019 at 6:30 AM
    xanderpope
    xanderpope New Member
    2014 TRD OffRoad
    My '14 averages about 15 on the low end and 18 highway. That's unloaded not towing with the tonneau down. I usually drive right at 70 hwy.
  21. Apr 18, 2019 at 8:27 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    What screen are you on to display that information? I am not sure I have seen that one.
  22. Apr 18, 2019 at 9:26 AM
    conditioning2
    conditioning2 New Member
    Tacoma TRD off-road
    One of the reasons why I've got rid of my 1794 2016 tundra was I was only getting between 10 and 12 miles to the gallon. I downsize to the Tacoma and I'm waiting for them to do a refresh on the tundra and I'll buy a new one
  23. Apr 18, 2019 at 9:37 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    If you had a big lift and beefy tires, then yeah I could see 10mpg being normal. It seems low for a stock truck. Mine's a 2014 with 3" lift and 33" tires and i'm getting a little over 14mpg.. granted it's not a 1794, but I can't imagine that makes a difference.
  24. Apr 18, 2019 at 9:41 AM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    Hold the disp button on your steering wheel to reset when you’re on the mpg screen
    TundraDude18 likes this.
  25. Apr 18, 2019 at 9:45 AM
    Kungfuamp
    Kungfuamp New Member
    2010 tundra Trd 4×4
    I get 10 -11.5 pulling a 7000lbs trailer but i take it easy i agree with resetting computer than easy off the pedal
  26. Apr 18, 2019 at 10:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You are getting what I get towing my 5000 lb Champion Bay boat. Short trips will kill the MPGs. Cold weather hurts too. A 40 degree day will drop mine about 1. Wind is another factor but not so much unless you are trying to do 75 on the hwy.. Mechanically, old/dirty plugs will hurt. I have never noticed any difference with a new air filter.
    Fastestcolor likes this.
  27. Apr 18, 2019 at 11:54 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    12.3 MPG here. 2014 CM 5.7. My carbon footprint is huge!!!
    bvia likes this.
  28. Apr 18, 2019 at 12:49 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    10mpg is what I get on a 3 inch lift with 35s and a supercharger. The vehicle computer reads 15mpg while the hand calculations And Bully Dog shows 10.
    67A56DD2-D710-4812-A2AA-2BD0E8C2F016.jpg 82044E4F-9217-4830-8D5D-2F841238199B.jpg
    Pinay likes this.
  29. Apr 18, 2019 at 1:00 PM
    Blueknights75
    Ron
    Clayton, NC
    Got to love these people that talk about getting awful gas mileage in their Tundra...what a joke! Keep your foot off the gas and driving it like a sports car and you can get great gas mileage out of the Tundra! This discussion is getting old! Averaging 18 mpg and couldn’t be happier with that number considering the size of the truck.
    Ronin73 likes this.
  30. Apr 18, 2019 at 1:02 PM
    Blueknights75
    Ron
    Clayton, NC
    texasrho83, Black Wolf and 15whtrd like this.
