  1. Apr 16, 2019 at 9:06 PM
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    Throttle body cleaner from AutoZone and a steel wire brush. Took about 20- 30 minutes.
    monaco730[QUOTED] and Watt maker like this.
  2. Apr 16, 2019 at 9:08 PM
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Just a clean.
  3. Apr 16, 2019 at 11:06 PM
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    Slapped on a couple coats of metalizer to see how it would look. Really hard to tell in pics. Ended up with a gunmetal finish. For those of you who have removed plastidip in the past (easily), you know that a THICK coat makes life a lot easier. While the wheels dont look bad, I still prefer the lighter look. I'll probably spray a couple more coats on each wheel or whatever remaining dip I have and it'll all come off super easy. Here's how it looks R/N. Photos taken after a quick wash. Love using my powerwash.
  4. Apr 16, 2019 at 11:19 PM
    ‘19pro
    ‘19pro New Member
    Walter
    19 Tundra Pro, black
    295/75-18, TRD intake, CB pro kit.
    So I finally did the CB TRD pro kit, and put the TRD intake under the hood.
    My most recent thing is give it a buddy to pull around! The trailer is empty in this picture, which is 3500 lbs. so when loaded it’ll sag a bit more but just how much remains to be seen. The empty trailer might as well not be there TBH. Until I look at the fuel gauge (gouge?) anyways.
    pitts101, cjmay13, GAknight and 6 others like this.
  5. Apr 16, 2019 at 11:31 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Looks real good!
    Devildawg712[QUOTED] likes this.
  6. Apr 17, 2019 at 12:33 AM
    KingRob22
    KingRob22 New Member
    Rob
    How many coats of base did you do? How’s it matching to the body panels?
  7. Apr 17, 2019 at 2:14 AM
    dochanson
    dochanson New Member
    Gabe
    I used 1/2 pint of base (1 pint when reduced) it was enough for 3-4 coats. Color is REALLY close. It’s a hair lighter but that also may be the way the light hits. I used a standard grey primer. A better painter could add a few drops of tint and get it perfect I’m sure.
    KingRob22[QUOTED] and Watt maker like this.
  8. Apr 17, 2019 at 2:22 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Finished my carbon dash work yesterday and got everything reinstalled. The little wedge shape pieces through center of dash (left to right) were wrapped in 5D (same on steering wheel, climate controls and lower aux. ports) Center dash (silver piece) wrapped in Sott carbon. For one last touch, I disassembled the instrument cluster and added some Sott carbon there as well.
    Opposing weave patterns were alternated with the different parts, toward/ away from center line, and one another.
    I'll take some daylight shots later today.
  9. Apr 17, 2019 at 3:13 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks brotha! I just want to see it all together in daylight.
    Watt maker likes this.
  10. Apr 17, 2019 at 3:57 AM
    TiltedTundra
    TiltedTundra I am become death, destroyer of worlds
    MiddleWest
    2017 White TRD Pro
    I'm going to see how much this will cost to have done locally. This looks great and would help me get rid of the little bit of chrome still on my truck.
    hi_rawb likes this.
  11. Apr 17, 2019 at 6:58 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    Nice! :thumbsup:
  12. Apr 17, 2019 at 7:51 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looks great! Really like that setup.
  13. Apr 17, 2019 at 10:40 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    I like them a lot. They do stick out a little bit but that stops a$$holes from door dinging my truck.
    Blkdmax[QUOTED] likes this.
  14. Apr 17, 2019 at 10:42 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Awesome, I want to purchase them was worried about install was it hard? Mine are plain black.
  15. Apr 17, 2019 at 10:49 AM
    Buckmark1
    Buckmark1 New Member
    2019 Cement SR5 CM - TSS Off Road 4x4
    Any shots head on so I can see how far these stick out? Love these wheels but afraid with width and offset they may stick out too far. Thx.
  16. Apr 17, 2019 at 10:54 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    John I gotta ask. Don't get me wrong, if u look back when u 1st posted I said the truck looked great, and still does with the changes u made. But I gotta ask, does that mean every time u go and plastidip to tweak these that u are removing and adding back those million bolts that come on this wheel, plus having to do them too. Dude that seems like an insane amount of work.
    As much as I like these wheels I specifically stayed away from them just for the fact alone they look hard to clean. Nevermind all ur going thru on them lol.
  17. Apr 17, 2019 at 11:16 AM
    Cthulhu
    Installation for both the mirror caps and the door handles is super easy, barely an inconvenience. There are videos out there that show you how to do it, and they're only a few minutes long. Just be sure to have a set of plastic trim tools (must-have possession for ALL modders!!), particularly for the mirror caps. They will not honor warranty claims on the mirror caps if not installed by the dealership (a disclaimer in the description of the mirror caps on the Sparks site), but again, it wasn't difficult at all.
    KELZ84[QUOTED] likes this.
  18. Apr 17, 2019 at 11:36 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Got rid of the rest of that shiny crap they put on truck from new. Gonna install more lights later today when they get in. Definitely need a RCI skid plate now to finish it off
    matrdguy, porkitt, apbreaux and 13 others like this.
  19. Apr 17, 2019 at 2:27 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I get a strange feeling looking at your truck
  20. Apr 17, 2019 at 3:44 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Replaced the jbl paper sub in the back with a real one. JL Audio 10tw1-2.
    saybng, NWHmoob, Pinay and 6 others like this.
  21. Apr 17, 2019 at 4:45 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    MAN! This right here is gonna look BADD AF!
    GAknight[QUOTED] likes this.
  22. Apr 17, 2019 at 4:49 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    I just completed my set!
    AE6E4A60-2D9F-42E1-9322-FF1132369D5B.jpgThanks to @ajtdesign ! Couldn’t be any happier!
    Yzed608, Pinay, CAM1794 and 5 others like this.
  23. Apr 17, 2019 at 4:57 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    @MER do this!
  24. Apr 17, 2019 at 5:19 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    So it begins...
    The dechroming...
  25. Apr 17, 2019 at 7:07 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I had to pull my back seats out to run a new speaker wire to my sub. Also had to switch the new JBL sub's impedance from 2 ohm to 4 ohm, )luckily on the sub from the tech12volts group buy it literally is a switch on the sub). I did all thos because I will be installing my new head unit and amp tomorrow or Friday.
    Since I had the seats out I decided to put down some noico 80mil sound mat, a layer of closed cell foam and then 2 layers of mass loaded vinyl separated by more foam, on the floor. I had already done the back wall and floor under the rear seats last summer. This time I sound deadened the floor from the back wall to where the carpet splits under the front seats. It should really quiet things down in there. I will do the front some day soon I hope, maybe the passenger side while I have the seat out for amp install. I thought I had taken some pics but can't find them on my phone now. Oh well, I swear I did it though.
  26. Apr 17, 2019 at 7:14 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Installed the ROAM awning today. This thing is bad ass. 1D107A94-3DBA-4BD9-9B59-E2D559D281BF.jpg
    escuzi_me, Pinay, equin and 3 others like this.
  27. Apr 17, 2019 at 7:41 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    How are you gonna post and not say anything about how it sounds?!
    Ok so how's it sound? MLV/Foam is somewhere high on my to do list.
    Pinay likes this.
  28. Apr 17, 2019 at 7:43 PM
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    Today I added a pop n lock, Putco rear led bar, and trd rear sway bar.
    saybng and MotoTundra like this.
  29. Apr 17, 2019 at 7:46 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    How do you like the sway bar?
  30. Apr 17, 2019 at 7:49 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Bath time. After two weeks of consistent rain!! Finally a clean super white.
