Let's talk pressure washers
Discussion in 'Detailing' started by HBdirtbag, Dec 4, 2017.
  1. Apr 17, 2019 at 1:51 PM
    #181
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  2. Apr 17, 2019 at 2:07 PM
    #182
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    http://www.ramteq.com/en/
    If you want one built here. These are pretty much bulletproof. I have a 4200psi one. Belt drive.
    Bama and Watt maker like this.
  3. Apr 17, 2019 at 2:34 PM
    #183
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    So...I'd like to use this de-ionizer with a pressure washer.
    https://www.amazon.com/CR-Spotless-...coding=UTF8&psc=1&refRID=YFE3B8CWBAFBCDAJJ4AV
    For anyone who may have both, which would connect to the water line? Like, what order would it be?
    1 - Water line + de-ionizer + pressure washer? OR
    2 - Water line + de-ionizer + pressure washer? Or should I use one first over the other? Pressure wash clean, use foam cannon, rinse with pressure washer and or de-ionizer? :help:
  4. Apr 17, 2019 at 2:55 PM
    #184
    Sas
    OKC, OK
    I was looking at this as well (until I saw the price and cost for recharges). I was planning on only running the final rinse thru the de-ionizer w/o the pressure washer TBH and just using a regular hose and spray nozzle for it.
    Pinay[QUOTED] likes this.
  5. Apr 17, 2019 at 2:57 PM
    #185
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah, it looks like the more you use it the faster you need to recharge. Makes sense for the final rinse.
  6. Apr 17, 2019 at 2:59 PM
    #186
    Sas
    OKC, OK
    The PPM (or whatever metric that was) apparently plays a role too.
  7. Apr 17, 2019 at 3:01 PM
    #187
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I know Jason War Machine got the de-ionizer for xmas and was using it a lot, until he got ceramic coated and backed off since beginning of the year.
  8. Apr 17, 2019 at 3:02 PM
    #188
    Sas
    OKC, OK
    I think a pressure regulator may be needed as well for some of those units if the pressure coming out of your spigot is too high. I think mine comes out at 115 or so the last time I checked. One of the units I was looking at had a max operating range of 90 PSI.
    Pinay likes this.
  9. Apr 17, 2019 at 3:04 PM
    #189
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Makes sense! I've had plumbers comment on the great water pressure from the Water Co, never checked what it is so maybe washer with less PSI would be fine. Are regulators or PSI measure instrument in hardware stores?
  10. Apr 17, 2019 at 3:04 PM
    #190
    Sas
    OKC, OK
    Makes sense. That coating is really slick (pun intended).
  11. Apr 17, 2019 at 3:06 PM
    #191
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah, he was washing his truck and the family's other vehicles so not sure if it's getting more use on the other vehicles cuz the Tundra is the only one that has ceramic. I'd like to consider that but no way anytime soon...getting new suspension and that's eating me dry!
    Sas[QUOTED] likes this.
  12. Apr 17, 2019 at 3:06 PM
    #192
    Sas
    OKC, OK
    Yeah, you should be able to pick up both at Home Depot, Lowe's or just about any plumbing store.
  13. Apr 17, 2019 at 3:07 PM
    #193
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Ok, I wasn't sure, hadn't thought about it before now lol
  14. Apr 17, 2019 at 3:08 PM
    #194
    Sas
    OKC, OK
    Lol, I hear ya. I'm still recovering from mine.
  15. Apr 17, 2019 at 3:14 PM
    #195
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I work in a water dept and I'm guessing that the ppm stands for parts per million. So it's basically saying how much of a certain type of shit is in your water, the higher shit, the higher ppm.
    Pinay likes this.
  16. Apr 17, 2019 at 3:15 PM
    #196
    Sas
    OKC, OK
    It does. I just can't remember if they were using ppm or another metric.
    mgm16trdpro[QUOTED] likes this.
  17. Apr 17, 2019 at 3:16 PM
    #197
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Is that something an average homeowner can test on their own? Or specialized analysis?
  18. Apr 17, 2019 at 3:17 PM
    #198
    mgm16trdpro
    Northern NJ
    Are u on well or city supplied?
  19. Apr 17, 2019 at 3:20 PM
    #199
    mgm16trdpro
    Northern NJ
    If ur not sure, I can ask this way. Do u pay for water or never get a bill?
  20. Apr 17, 2019 at 3:21 PM
    #200
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Not so much city but a water system that I believe gets from wells. I seem to think they put out annual reports, just not sure now if it’s quality analysis now that I think about it...
  21. Apr 17, 2019 at 3:22 PM
    #201
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I pay but I don’t think they are city agency..
  22. Apr 17, 2019 at 3:23 PM
    #202
    mgm16trdpro
    Northern NJ
    Ok so u have a private water co supplying ur water. They're required by law to do sampling every so often. U can call them up and ask what they got in their past sample. It wont be your house but it will be from an area near you.
  23. Apr 17, 2019 at 3:24 PM
    #203
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Ok. I seem to think they may have the reports online. I’ll have to check.
  24. Apr 17, 2019 at 3:27 PM
    #204
    mgm16trdpro
    Northern NJ
    We do weekly sampling so if u called us we could tell u what we got for the week from a house in your area. Besides that we only post results online for like annual reports or if we were to fail something.
  25. Apr 17, 2019 at 3:28 PM
    #205
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Nice! Thanks!
  26. Apr 17, 2019 at 3:28 PM
    #206
    mgm16trdpro
    Northern NJ
    Anytime. Ur best bet is probably to call them and just ask. They can tell u exactly what ur looking for.
    Sas and Pinay[QUOTED] like this.
  27. Apr 18, 2019 at 5:00 AM
    #207
    War Machine
    War Machine SSEM # 5 3MW
    I’ve slowed down due to weather, but still wash all of them when I can. You still have to wash with ceramic, it’s just easier.
    I’ve actually come to the conclusion that the guy who did my Ceramic did a shitty job. Without Hydro2 and Beadmaker, it’s really not as slick as it’s supposed to be. I also don’t have the “wet look” that others do. I just don’t have the results that others have. Either my expectations were too high, or the guy half assed it.
  28. Apr 18, 2019 at 5:00 AM
    #208
    War Machine
    You can get a little kit at the hardware store to test it.
  29. Apr 18, 2019 at 5:43 AM
    #209
    mgm16trdpro
    Northern NJ
    Yes this too. But that's why I was asking if on well or not. If well that's only real option to get quick results. If paying for water a phone call, without spending money can get immediate results.
  30. Apr 18, 2019 at 5:58 PM
    #210
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
