  1. Apr 14, 2019 at 9:38 AM
    #1081
    Racingjohndeere55
    Racingjohndeere55 New Member
    ^^^^^^^^^^^^ Does not have OCD! Try sleeping now:p
  2. Apr 14, 2019 at 9:52 AM
    #1082
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    My father lost the use of his legs while battling stage 4 esophageal cancer last May. Not only did he beat that awful cancer with flying colors (beside the removal of his stomach completely) but using lawns and yard work as rehab...outside of medical PT at the VA. Yesterday was the first time, since the cancer hit, that he mowed both front and back lawns 100% himself. He uses the mower as a walker for balance.
    One more reason he's my 72 year old hero
  3. Apr 14, 2019 at 9:53 AM
    #1083
    CaptSpaulding
    Jake
    2010 White DC 4x4
    And the lawns look great!
  4. Apr 14, 2019 at 9:55 AM
    #1084
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    This is correct!
    Stroke250[QUOTED] likes this.
  5. Apr 14, 2019 at 10:02 AM
    #1085
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    All switch and recpt screw slot must always be vertical, it make more volts 221, 222 whatever it takes , lol
  6. Apr 14, 2019 at 10:09 AM
    #1086
    Omohundro
    Jody
    McMinnville TN
    #teamvertical
  7. Apr 14, 2019 at 10:19 AM
    #1087
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Thanks Ron, much appreciated!
    As he says....he's a tough old bird
  8. Apr 14, 2019 at 10:22 AM
    #1088
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    As an electrician, i found that 220-221 scene very funny since resi switchs and recpts are 120v nominal.
    NewImprovedRon likes this.
  9. Apr 14, 2019 at 11:12 AM
    #1089
    Racingjohndeere55
    My father had an electrician that worked for him that had a hard time distinguishing between 110 and 220. He would just grab the wires and had no effect on him. My old man walked up behind him one time and put his hand on his shoulder to ask how he was doing and got thrown across the room. The guy had ahold of a 220 line. Pop said he never put his hand on him to ask how he was doing again!:rofl:
  10. Apr 14, 2019 at 12:16 PM
    #1090
    I do the exact same thing! All slots are vertical.
  11. Apr 14, 2019 at 12:17 PM
    #1091
    :yes:
  12. Apr 14, 2019 at 12:18 PM
    #1092
    No sir if they're vertical and they get moisture in the middle it will drain out. :D
  13. Apr 14, 2019 at 12:19 PM
    #1093
    :facepalm:
  14. Apr 14, 2019 at 12:20 PM
    #1094
    That's great!
  15. Apr 14, 2019 at 1:01 PM
    #1095
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Is this an OCD trigger? It makes my daughter crazy.
  16. Apr 14, 2019 at 3:56 PM
    #1096
    Installed my first ceiling fan :)
  17. Apr 14, 2019 at 3:59 PM
    #1097
    :muscleflexing:
    :bowdown::bowdown::bowdown::bowdown::bowdown::bowdown:
  18. Apr 14, 2019 at 4:42 PM
    #1098
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Looks great!
    You might say....
    ...I'm a fan of your work :rimshot:
  19. Apr 14, 2019 at 4:44 PM
    #1099
  20. Apr 15, 2019 at 6:19 PM
    #1100
    Trooper2
    JR
    Houston, TX (Suburban South)
    50" LED on the back patio, sounds big but pic doesn't make it look very big.
  21. Apr 16, 2019 at 5:06 AM
    #1101
    Omohundro
    Jody
    McMinnville TN
    Better watch out, home mods are more addicting that truck mods.
  22. Apr 16, 2019 at 5:54 AM
    #1102
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    300 watts of solar energy for powering my deck lights and radio shack.
  23. Apr 16, 2019 at 5:59 AM
    #1103
    Yes!
  24. Apr 16, 2019 at 6:00 AM
    #1104
    :thumbsup:
    Racingjohndeere55 likes this.
  25. Apr 16, 2019 at 6:00 AM
    #1105
    Racingjohndeere55
    Are you storing the energy?
  26. Apr 16, 2019 at 6:01 AM
    #1106
    That's a job that really blows!
  27. Apr 16, 2019 at 6:01 AM
    #1107
    Nice!
    Trooper2[QUOTED] likes this.
  28. Apr 16, 2019 at 6:06 AM
    #1108
    Racingjohndeere55
    What took ya so long? White to white black to black and a lot of swearing when you keep dropping that screw!
    Cfincke and Pudge like this.
  29. Apr 16, 2019 at 6:06 AM
    #1109
    P-Factor
    P-Factor New Member
    Yes, I have two, 100ah, gel cell batteries.
  30. Apr 16, 2019 at 6:07 AM
    #1110
    Racingjohndeere55
    Very nice. You out for hire? My garage needs straightening out lol
    P-Factor[QUOTED] likes this.
