Replacing roof molding?
Discussion in '2nd Gen Tundras (2007-2013)' started by Cmaccullen, Apr 15, 2019.
  1. Apr 15, 2019 at 10:14 PM
    Cmaccullen
    Cmaccullen [OP] New Member
    2022 Tundra Limited
    Has anyone ever replaced the roof molding? Is it difficult? Where can I purchase? Any help is much appreciated. Thanks
  2. Apr 16, 2019 at 10:44 AM
    minter66
    minter66 2007 TSS CrewMax
    2013 Tundra TRD 4X4 and chugs like this.
  3. Apr 16, 2019 at 4:04 PM
    gilgawrath
    gilgawrath New Member
    2012 Tundra TSS 4.6
    Mine always blow off when I go through the car wash. I was told it’s a common problem. I’ve used some e6000 to keep the on and it seems to be working for now..
  4. Apr 16, 2019 at 4:38 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
  5. Apr 16, 2019 at 4:41 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    i just got mines replaced under warranty both side were peeling up mines a 2016
  6. Apr 17, 2019 at 11:18 AM
    shadzima
    shadzima New Member
    2007 Toyota Tundra Double Cab Limited 5.7
    Replaced mine, got it from ebay:TOYOTA OEM 07-18 Tundra DOUBLE CAB Roof-Drip Molding PASSENGER SIDE 755510C050
    SHAYNDRA likes this.
  7. Apr 17, 2019 at 12:20 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The attached file may or may not be of help. It is a Tech Service Bulletin specifically addressing problems with 2013-2015 Tundra roof moldings, but I expect the installation procedures are the same, or at least similar, for all Tundra roof moldings. Use what's helpful, ignore the rest. BUT...Be sure to verify correct part numbers for your application.
    RaginTxn, gscamman67 and MELA 2016 like this.
  8. May 19, 2019 at 11:19 AM
    MELA 2016
    MELA 2016 New Member
    2016 Tunda xspX
    Factory with additional lift
    Thank you!
    JohnLakeman[QUOTED] likes this.
  9. May 19, 2019 at 2:07 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I replaced the drivers side on my 2017 after it getting ripped off in a car wash and cracked the front clip on the way off. I put some extra 3m double sided tape on it when I installed. Also the replacement clip in the front didn't have any adhesive or anything on it, not sure if it was supposed to, but used some double sided tape on that too.
  10. Jul 29, 2019 at 7:25 PM
    Mikeylud
    Mikeylud New Member
    Carson City, Nv
    2013 White Tundra Dbl Cab
    6" pro comp lift, 37x13.5r20 nitto ridge grapplers, mayhem wheels, custom exhaust, s&b intake, bullydog tuner, wrapped roof, chrome delete, debadged, aftermarket headlights & tail lights, remote start, aftermarket grille.
  11. Jul 29, 2019 at 7:48 PM
    minter66
    I still haven't bought mine - I feel bad...I don't think it's adhesive, I think they snap into place, which is why they fly off. Maybe use some 3M adhesive after cleaning the channel to make sure it stays put?
    OR18TRD likes this.
  12. Jul 30, 2019 at 5:16 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I think it might come with a few small patches of tape, I forget. There is a clip that it snaps into on the front and it sits under the rsar window trim in thr back. I bought a new clip since it cracked the original when it came off. I THINK this clip is supposed to be held on with adhesive, but mine was not sticky at all (It almost felt waxy, so I actually heated it up to see if it was supposed to 'melt' into place, it just charred). I bought some 3M outdoor rated double sided tape and used that to install both the clip and the trim piece, putting the tape on most of the length of trim. It has withstood a WI winter so far...
    A drive through car wash is what took mine out originally. I think I've been through it once after the new install.
    NewImprovedRon likes this.
  13. Nov 20, 2019 at 12:21 PM
    gscamman67
    gscamman67 New Member
    GOES
    2008 Blue/gray Tundra 5.7L Limited
    Thanks for all the info. My roof mouldings have just worn out over time (not attacked by vultures). I'm going to give a shot at replacing them myself. Just hope I order the right ones!TundraRoofMoulding.jpg
  14. Nov 20, 2019 at 1:40 PM
    gscamman67
    GOES
  15. Nov 20, 2019 at 3:33 PM
    JohnLakeman
    With or without the sunroof, the molding part numbers are the same (See link below. Items 10 and 11 conspicuously absent from sunroof parts list because they are the same). Better to run this past @Roman to make sure you get all the attachment clips you need.
    https://parts.toyotaofcoolsprings.c...a--sr5--5-7l-v8-gas/body--roof-and-components
  16. Nov 20, 2019 at 4:31 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I’m not one to fix something that isn’t broke, but is it feasible to remove the trim, add double sided tape, and reinstall as a preventative measure? Or is it one of those things that are destroyed during removal? Thanks,
  17. Nov 21, 2019 at 6:50 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yep, they're the same part numbers either way. Here's a link to the clip, in case you need it:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-drip-molding-clip-7556102020
  18. Nov 21, 2019 at 7:03 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I
    Used the same stuff! And took some pliers and pinched the metal bracket together a little tighter. I only used that glue on the rubber where it meets the bracket though.
  19. Nov 21, 2019 at 7:04 AM
    TruckyTruck
    Gary
    I also used some 303 to turn the rubber black again. Cheap and works well.
  20. Nov 21, 2019 at 7:08 AM
    Racingjohndeere55
    Mine blow off in the carwash, so I dont think they will be destroyed
    focal[QUOTED] likes this.
  21. Dec 17, 2019 at 10:21 AM
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
  22. Dec 17, 2019 at 12:10 PM
    Roman
    Roman
    Franklin, TN
    The clips snap in. There's a small pad on one side, but it does not have adhesive on it.
  23. Feb 3, 2020 at 11:26 AM
    tothinator
    tothinator New Member
    Forum newbie here but thanks for all the info, I have been having one of these fly off of my 2012 CrewMax in the car wash lately and can't figure out how to get it to stay put. Will try what that technical bulletin suggests, or maybe some adhesive
  24. Feb 3, 2020 at 11:30 AM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    Wow! My silver 2013 CM has been kept outside in the Mississippi and Hawaii sun since it was new and it looks fine.
    I wonder if they used different manufacturers at some point?
  25. Feb 3, 2020 at 3:40 PM
    I think my 2013 is fine as well. Now I have to look.
  26. Feb 18, 2020 at 5:07 PM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Both sides are missing on my '14 CM. My guess is blowers in carwashes but who knows.
    MPG_LOL likes this.
  27. Feb 22, 2020 at 3:56 PM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    I replaced my driver side just the long rubber strip, clips were still there, and the pass side was still there. Took about 5 minutes cause I had to open it. Super easy to do just went to Toyota and bought.
    rznhales likes this.
  28. Feb 23, 2020 at 9:24 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    On 2007 CM front side is just some simple clips and rear is with double sided tape. Mine were faded so I pulled them off, rubbed them down pretty good with some mr clean sponge to take off the haze then quick coat of black trim paint. put on new heavy duty 30 lbs double sided tape for the rear and put them back on.
  29. Jul 14, 2020 at 11:15 AM
    JBOT
    JBOT New Member
    Quick question regarding the molding. Is there any harm in not having the molding at all? I plan to replace my missing driver side molding, but the local dealership is charging $72 for this small piece of rubber/plastic. Online is 52 and I hope they will price match when I pick the part up.
    I am just curious if water can infiltrate the roofline or windshield if the molding is not installed. My tundra currently resides under a carport so this is only exposed when I am driving in the rain.
    Thanks.
  30. Jul 14, 2020 at 12:58 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    i think its aesthetic more than anything else. its where the spot weld runs between your roof and door sills
    Rex Kramer likes this.
