PCV Valve
Discussion in '2nd Gen Tundras (2007-2013)' started by jkoepke49, Jul 26, 2016.
  1. Jul 26, 2016 at 2:58 PM
    jkoepke49
    jkoepke49 [OP] New Member
    James Koepke
    07 Tundra
    Supercharged, flairs and custom wheels
    Where is the pcv valve on my 07 5.7 Tundra
  2. Jul 26, 2016 at 3:11 PM
    Ardnut
    Ardnut New Member
  3. Jul 26, 2016 at 4:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Lol he didn't actually want to show us
    CaptSpaulding and NewImprovedRon like this.
  4. Jul 26, 2016 at 5:47 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Rather than let 7 minutes and 27 seconds of your life tick away, I'll summarize.
    Its like geez I'd love to show you how to do this, but I really can't be bothered, so just undo the widget at the end of this whatchamacallit hose thingy and be sure and like my video.
  5. Jul 26, 2016 at 8:24 PM
    Ardnut
    Ardnut New Member
    what do you mean? Clear as mud now!
  6. Jul 27, 2016 at 6:43 AM
    Ardnut
    Ardnut New Member
    Yeah, right behind the thingmajiggy, duh
    :rasta:
  7. Jul 27, 2016 at 12:11 PM
    jkoepke49
    James Koepke
    07 Tundra
    The reason I posted the pcv question was because occasionally my tundra would belch a cloud of blue oil smoke out of the tail pipes. It would happen maybe once every two weeks or maybe once a day usually at cold startup. The dealer where I bought it said the valve seals were shot and with removing the supercharger and all it would cost me $3200.00 plus to fix. I have a strong automotive background and knew this was bull. I've seen pcv valves stick open before and cause this symptom. I was looking for a pcv in the rocker/cam covers but it's under the intake manifold in the front of the engine. Not hard to change once you find it. Since I changed it, no more blue smoke. Valve seals which are bad stay bad and don't cause occasional blue smoke. On the customer satisfaction email survey I received from the dealership I recommended that the tech who diagnosed the problem be restricted to the wash rack.
    JK
  8. Jul 27, 2016 at 6:35 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Thanks for the follow up. Glad it solved your problem. BTW. We were funnin' on the video. No reflection intended on your post.
    NewImprovedRon and Ardnut like this.
  9. Apr 14, 2019 at 3:17 AM
    Reviving an old thread... I just changed mine on my T100 few weeks ago, when should this be done on the Tundra??? Bought used with 26,000 now I'm at 64+
  10. Apr 14, 2019 at 3:36 AM
    @Roman what's part # for this?
    My VIn#
    5TFDW5F18EX387442
  11. Apr 14, 2019 at 6:16 AM
    It's not really a wear item. I'd start by pulling it off and seeing if you can blow air through it. Give it a thorough cleaning and put it back in if nothing concerns you.
    I only replaced it on my truck because it was 17 years old.
  12. Apr 14, 2019 at 6:39 AM
    Thank you Sir
  13. Apr 14, 2019 at 6:46 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    THAT narrowed it down quite a bit for me!:D
    NewImprovedRon likes this.
  14. Apr 15, 2019 at 10:31 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  15. Mar 28, 2020 at 2:11 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    PCV valves are an inexpensive maintenance item.
  16. Jun 5, 2022 at 12:16 PM
    737fixer
    737fixer New Member
    Wow. So if I say padding and touch it, then say padding and touch it, then say padding and touch it, then say padding and touch it, then say padding and touch it my PCV valve is changed. Cool.
  17. Jun 8, 2022 at 8:40 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    WVI likes this.
