Suspension Advise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Myhobbes25, Apr 14, 2019.
  1. Apr 14, 2019 at 10:53 PM
    Myhobbes25
    Myhobbes25 [OP] New Member
    Jeffery
    Western Washington
    2014 Toyota Tundra Platinum
    Rigid fog Lights, 35x12.50x20 BF Goodrich KO2 Tires, 20x9 Fuel Trophy Wheels, Pro Comp Stage 2 Full Suspension Lift 6 inches, K&N Intake, Magnaflow Muffler, Husky X Contour Floor mats, Pina Colada Scented Tree
    Hopefully this is on the right place. I have a 2014 Platinum That came with a stage 2 pro comp 6 inch lift. Part Number: EXPK5069BPX
    I am not a huge fan of how high it is. Also running on 37s for extra tallness. I am going to swap out the wheels and tires to 35s and looking to reduce my overall height. I'd like to be about 4in over stock. I was hoping to just swap out a couple of components to do that and leave the rest of the lift. (ie front struts and shorter blocks in the rear). Will there be complications running the rest of the lift on shorter shocks? I was looking at the icon 3.5 coilovers. Any other recommendations?
  2. Apr 15, 2019 at 4:41 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Your best bet, imo, is to pull the old lift out and install a proper 4” lift kit.
    Don’t know if that lift is that adjustable as it doesn’t give a range of lift - only says 6”
  3. Apr 15, 2019 at 6:07 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm not exactly sure on this, but I think you can adjust your current ProComp coils down to approx 4 1/2. You would have to get the 35's on before adjusting it though..
    Myhobbes25[OP] likes this.
  4. Apr 15, 2019 at 8:19 AM
    Myhobbes25
    Jeffery
    Western Washington
    That would be great.
  5. Apr 15, 2019 at 8:54 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Definitely! Then you don’t have to mess with anything else.
  6. Apr 15, 2019 at 9:07 AM
    TXTundra2722
    2015 Black Tundra
    Well let's not steer him wrong now. That kit is not adjustable. The front end is not adjustable. The rear is a different story, because I believe that kit uses a combination of a block and add a leaf to get the lift. You would have to add the stock components back on the truck to bring the front down. I'm guessing here, but most bracket lifts(this lift) requires material to be cut off the front of the truck, so you might not be able to go back stock without work(fabricating).
    texasrho83 likes this.
  7. Apr 15, 2019 at 9:24 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep! Front crossmember is cut for the driveshaft. Unless ya have a 2WD...
  8. Apr 15, 2019 at 1:21 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    adjustable coils
    Here you go,
  9. Apr 15, 2019 at 9:36 PM
    Myhobbes25
    Jeffery
    Western Washington
