Shifting in/out of 4wd
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1794Paul, Apr 10, 2019.
  1. Apr 10, 2019 at 9:19 AM
    1794Paul
    1794Paul [OP] New Member
    I just got a used '17 Tundra. I didn't really want 4wd but it came with it. I've never had 4wd before and don't plan to do much off-road, but I'd like to take advantage of it in adverse road conditions. Should I always be parked to go into 4wd high or low, or can I be moving? If so, what would be the max recommended speeds?
    Thanks from a newbie.
    TokerJoker likes this.
  2. Apr 10, 2019 at 9:23 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Look at your drivers sun visor..all the 4WD info should be there.
    15whtrd and TokerJoker like this.
  3. Apr 10, 2019 at 9:23 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    4wd high is on the fly so meaning u can b moving and switch over 4lo u must stop put in neutral and turn on
    bamfkyllo, 15whtrd and TokerJoker like this.
  4. Apr 10, 2019 at 9:25 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW :worthless:
  5. Apr 10, 2019 at 9:38 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    4wd hi you have to be below 60mph, or you might break something or the truck will downshift hard because you didn’t follow instructions. 4low you have to stop, put it in neutral then switch. As far as I know you can go as fast as you want in 4hi, 4lo you can feel it, it won’t go any faster past a certain limit I believe it’s 15mph, only for maximum traction situations where you need all the torque that’s why 4lo is slow speeds.
  6. Apr 10, 2019 at 9:41 AM
    Tmcush75
    Tmcush75 New Member
    Thomas
    19 Cement limited
    If it's anything like the nissans. 4lo had a less sensitive throttle also. So less spinning when you give gas
  7. Apr 10, 2019 at 9:54 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    or when you're going down steep slopes
    Samoan Thor[QUOTED] likes this.
  8. Apr 10, 2019 at 9:59 AM
    15whtrd
    15whtrd Mr. Blonde
    4 lo won’t go past fourth gear.
  9. Apr 10, 2019 at 10:00 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I never used 4lo. Unless your pushing a snow plow.
    15whtrd likes this.
  10. Apr 10, 2019 at 10:02 AM
    15whtrd
    15whtrd Mr. Blonde
    But it’s really fun to use LOL the truck transforms into a tank.
  11. Apr 10, 2019 at 10:08 AM
    Racingjohndeere55
    Yep, a slow tank:rofl:
    Also if your in a slippery condition, you don't want to be spinning the wheels. You could experience a loud CLUNK. Loud clunks can be expensive $ when in doubt, come to a complete stop. Shift into 4hi and slowly pull away. You will feel and see the light in the dash. And please don't be that person that thinks 4x4 are like driving on a dry road. You may be able to take off, but stopping is not much improved. We are smarter here;)
    15whtrd likes this.
  12. Apr 12, 2019 at 4:03 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    One thing I noticed when in 4WD with my 2015 SR5 is that the 4HI would flash even when I put it back to 2WD.
    At first it took slowing down to almost a crawl or a dead stop to get 4HI to stop flashing and go back to 2WD.
    What ALSO works is gently pushing down on the accelerator to increase the speed slightly. THIS also helps 4HI go to 2WD and not cause it to hang up in 4WD and not go back into 2WD! Give it a try!
  13. Apr 12, 2019 at 4:35 PM
    Aerindel
    Aerindel New Member
    Montana
    You guys are funny.
    Black Wolf likes this.
  14. Apr 13, 2019 at 6:47 AM
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Also no 4WD on dry roads, as it stresses the system!
    I plow a lot snow here in Maine and the only time I use 4 lo is after I get stuck.
    Bear likes this.
  15. Apr 13, 2019 at 6:54 AM
    Haggis777
    SW Michigan
    I will run mine in 4WD on dry roads but ONLY on a straight, several-mile stretch of country roads and then only about once or twice a month merely to keep the transfer case lubricated.
    Anyone else?
    15whtrd and NewImprovedRon like this.
  16. Apr 13, 2019 at 7:27 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I use 4H for my driveway so I don’t tear it up in 2. 4L for the occasional knucklehead I’ve dragged out of ditches this winter...oh, and when I pulled the boat out of the back yard before the ground “melted”. :mad: Gotta love Maine
    15whtrd likes this.
