  1. Apr 9, 2019 at 5:28 PM
    #1051
    Racingjohndeere55
    Racingjohndeere55 New Member
    Nice work, even if your wife questioned you. Dog approved!
    Mnorris1206[QUOTED] likes this.
  2. Apr 9, 2019 at 5:31 PM
    #1052
    Racingjohndeere55
    Could you show me how you did your steps? I need to build a set off the front porch and I think your front set might fit the bill (or build).
    Mnorris1206 likes this.
  3. Apr 9, 2019 at 5:33 PM
    #1053
    Mnorris1206
    08 tundra
    Thanks now that she sees the finished product she has approved as well lol. Not time to do some bbq.
    JMB likes this.
  4. Apr 9, 2019 at 5:37 PM
    #1054
    Mnorris1206
    08 tundra
    I will have to get more pics in the morning but here is kinda one. They where done with 4 step treads from lowes. Got 4 of those then 2 deck boards on each step with the post on bottom in the ground with concrete. Screenshot_20190409-203642_Gallery.jpg
  5. Apr 9, 2019 at 5:40 PM
    #1055
    Racingjohndeere55
    I have to figure out where the concrete pad will be then build the steps.and they probably will be 8' wide to match the width of the porch. I'm not sure if I will narrow it down and then fill in the sides between the front post and the house.
  6. Apr 9, 2019 at 5:49 PM
    #1056
    Mnorris1206
    08 tundra
    I want to see what your doing. Make sure you take some pics.
  7. Apr 9, 2019 at 5:51 PM
    #1057
    Racingjohndeere55
    Ok. May be a while. Boss said my truck would be done this weekend:crazy: so might be going back to work soon.
  8. Apr 9, 2019 at 5:58 PM
    #1058
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Looks great. For the bottom it looks to me like you could leave it open and plant some low flowers or bushes maybe? Or I've seen vertical and horizontal boards. Even a lattice refresh would work, but I really don't like lattice. Whatever you do, looks good.
  9. Apr 9, 2019 at 6:10 PM
    #1059
    Mnorris1206
    08 tundra
    Thanks yes been thinking vertical decking their but others say you want more air flow also so idk
  10. Apr 9, 2019 at 6:11 PM
    #1060
    Mnorris1206
    08 tundra
    But not so tight together.
    Fishman57 likes this.
  11. Apr 9, 2019 at 7:14 PM
    #1061
    Looking good Mike.
  12. Apr 9, 2019 at 8:10 PM
    #1062
    JMB
    Chesapeake, VA
    Yep, leave about 2" spacing between them. If you have a side that's not really visible you can leave it open, or use something like chicken wire to keep debris and most critters out.
  13. Apr 9, 2019 at 8:40 PM
    #1063
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Looks fantastic. I like the color and you did a nice job.
  14. Apr 11, 2019 at 11:38 AM
    #1064
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    My concrete is all done and I’m about to pull my electric cable this weekend. Can’t wait to get the inside going. B68BF4D9-8C01-4A42-BEEC-B83D12333474.jpg
  15. Apr 11, 2019 at 11:40 AM
    #1065
    Omohundro
    Jody
    McMinnville TN
    I edged all the concrete, I’m happy with it. By “I” I mean I asked someone else to do it. 8CA9C329-3B8D-4EDA-82F2-2BB1731986C5.jpg
  16. Apr 11, 2019 at 8:52 PM
    #1066
    Slayer
    Slayer Member
    Slayer
    nice job...
    wet that concrete down daily for a couple weeks.
    it helps in the curing process.
  17. Apr 12, 2019 at 8:24 AM
    #1067
    Racingjohndeere55
    The center legs on my cheap bed gave out. Replacements
    aperezsh, CaptSpaulding, JMB and 2 others like this.
  18. Apr 12, 2019 at 8:30 AM
    #1068
    Looking good!
  19. Apr 12, 2019 at 8:31 AM
    #1069
  20. Apr 12, 2019 at 8:31 AM
    #1070
    This^^^^^
    NewImprovedRon likes this.
  21. Apr 12, 2019 at 8:41 AM
    #1071
    Omohundro
    Jody
    McMinnville TN
    It’s been raining pretty regularly here, almost daily so it should be plenty hydrated.
    Prostar 190 and NewImprovedRon like this.
  22. Apr 13, 2019 at 7:14 PM
    #1072
    Omohundro
    Jody
    McMinnville TN
    Concrete nice and wet all day today, now it has muddy foot prints all over it. :facepalm:
    Guess what I’m doing tomorrow?
  23. Apr 13, 2019 at 7:17 PM
    #1073
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
  24. Apr 13, 2019 at 7:23 PM
    #1074
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Installed this programmable switch for the outside lights.
  25. Apr 13, 2019 at 7:45 PM
    #1075
    Pudge
    CT
    2015 Blue Ribbon Platinum
    My OCD is getting to me. I always make it so all the screw heads have the screwdriver slot going the same direction. Anyway I like that switch, might pick one up. How much ? if you don't mind me asking
  26. Apr 13, 2019 at 7:46 PM
    #1076
    Omohundro
    Jody
    McMinnville TN
    Please fix the screw heads
    757TUNDRA, AZTundra, Bama and 9 others like this.
  27. Apr 14, 2019 at 7:28 AM
    #1077
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    Hahaha I have OCD as well but this for some reason doesn’t bother me. My buddy told me the same thing, “I can’t believe your OCD is okay with that.”
    Honeywell Home ECONOswitch 7-Day... https://www.amazon.com/dp/B004AP92N2?ref=ppx_pop_mob_ap_share
  28. Apr 14, 2019 at 9:27 AM
    #1078
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    @Pudge
    Just for you.... lol
  29. Apr 14, 2019 at 9:33 AM
    #1079
    Racingjohndeere55
    No no no no..... they have to be horizontal! :rofl::rofl::rofl:
  30. Apr 14, 2019 at 9:34 AM
    #1080
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    @Pudge
    Hahaha I matched the others in the house so this is the best I’ll do lol
    Pudge and CaptSpaulding like this.
