Skid Plate Conundrum - Enjoy and be Kind
Discussion in 'General Tundra Discussion' started by Trooper2, Apr 9, 2019.
  1. Apr 9, 2019 at 2:05 PM
    Trooper2
    Trooper2 [OP] Premium Lone Star Member / SSEM #13
    JR
    Houston, TX (Suburban South)
    My Dumb-Assery for the year I wanted to share:
    Well I sure was proud of myself; finally going to get my newly modified stock front skid plate re-installed. Referencing other members front skid plate cutout pics, I measured several times, cutting a nice square hole in my front skid plate to access the oil filter in the future without removing it. I spent some time filing the new edges; sand blasted at work, primered, sanded, and then applied a nice coat of matte black. Even trimmed the hole with some auto door edge trim to avoid sharp edges in the future. I ordered some new mounting hardware because I only had like three screws holding it in before. Finally after about a year of it not being in place it was time to reinstall and be proud of what I accomplished. In addition, get it out of my garage! I also posted a pic or two on here showing off my handy work.
    Pulled the Tundra up on ramps. I got my creeper on wheels out. Sockets needed 10 & 13mm, check. I put some grease on the new bolts and chased the threads on the fixed nuts underneath. Grabbed the skid plate to install, rolled underneath and started to lift into place. I could see the new Aluminum canister filter through the new hole; I was going to have plenty of access to it in the future. In all this excitement, something did not seem quite right, the mounting holes were not lining up as needed. I rolled out for a second sat up to look at the plate, rolled back under to find where the hooks on the plate engage the frame underneath. As I look at the skid plate again, it needed to be rotated 180, but that cannot be right. If I rotate it, the new hole will not be under the oil filter. Then it hit me, excitement turned to crap, sure enough, I had cut the access hole on the wrong side of the plate!!! BAAAAHHH!!!
    :annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed:
    :frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty:
    New Conundrum: Not wanting to buy another skid plate; either relocate the Oil filter, which I could not find any mod to do so or cut another hole in the skid plate. I now have a multi-hole skid plate, two matching square holes cut into it; one to access the oil filter and one to let the engine breath better I guess, or possibly drain any unwanted liquids better. I could also look at it as being more balanced and lighter, sure to help with the MPG’s.
    The skid plate is surprisingly still rigid, does not feel weakened at all. It should be fine for my mostly Pavement needs, maybe a dirt road on occasion. I really want it on there to fasten the front shroud to it, instead of just letting it hang.
    It is silly crazy how easy it is/was to measure/mark/cut the plate on the wrong side thinking it is right.
    Laugh at myself often. It's never the end of the world. I am sure there is a "Wrong Hole" joke in there somewhere..... LOL
    Measure twice or more, cut once, & MAKE SURE ORIENTATION IS CORRECT FIRST!
    New pic - one of a kind Tundra front Skid Plate:
  2. Apr 9, 2019 at 4:42 PM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    Humility is a virtue. At least it's symmetrical now. ;)
  3. Apr 9, 2019 at 5:16 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    You stole the words right out of my mouth. You have a rare, genuine double opening skid plate. Never seen before. This should go for big $$$ eventually. In all seriousness ...stuff happens. I am pretty sure you can find one at a junkyard and redo it. Or just keep that one.
    Trooper2[QUOTED][OP] likes this.
  4. Apr 9, 2019 at 5:18 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    It looks like worried robot or maybe Kyle from Southpark
  5. Apr 9, 2019 at 5:40 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    I'm up near DFW. I'd give you my skid plate since it's just taking up room in my garage. Maybe someday you'll be up this way or vice versa.
  6. Apr 10, 2019 at 1:42 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Wrong side or not, that's great looking work:thumbsup:. I'd like to copy your Edge Trim idea but my 'door' doesn't have enough room/tolerance to make it work.:oops:
  7. Apr 10, 2019 at 3:12 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    I could see myself doing that !! When I first did my oil change on my 15 Taco went under took out the the pug to drain the engine. Nope I drain the trans instead . I said to myself why is the oil BLUE
    . Stupid stupid !! On my behalf the the trans plug and the engine plug are very close together.
    Black Wolf, Trooper2[OP] and Sunnier like this.
  8. Apr 10, 2019 at 3:24 AM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Wow! I thought I was the only one who did stuff like that! Maybe we’re long lost brothers!
  9. Apr 10, 2019 at 3:54 AM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    Sweet, now that's extra custom, bet it would go for high $$! Nothing finer than self deprecating humor... bonds one with like minded folks...
    Trooper2[OP] likes this.
  10. Apr 10, 2019 at 4:03 AM
    War Machine
    War Machine SSEM # 5 3MW
    I just have one big hole where a skid plate should be.
  11. Apr 10, 2019 at 4:20 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    We've all been there, done that.
  12. Apr 10, 2019 at 5:14 AM
    Trooper2
    JR
    Thanks, I had remembered seeing yours with the door, really awesome! :thumbsup:
    I am curious how long the Edge trim will last, could see it coming off, especially the horizontal piece up front. It does have some sort of sticky stuff inside, actually heated the trim with a heat gun a bit to help get the glue sticky. We will see.
  13. Apr 10, 2019 at 5:18 AM
    Trooper2
    JR
    Doh! (My Homer voice in my head). That is funny, I am sure it wasn't then. Guessing it made for a little longer day. Thanks for sharing.
    Black Wolf likes this.
  14. Apr 10, 2019 at 5:23 AM
    I trimmed the wrong end of a new door once....:annoyed::boom::frusty::laser:
  15. Apr 10, 2019 at 5:30 AM
    Trooper2
    JR
    It does seem to have a robotic look about it, Transformer like...........
    Or maybe a robotic Kyle, LOL
    JTL[QUOTED] and Black Wolf like this.
  16. Apr 10, 2019 at 5:35 AM
    Trooper2
    JR
    Needed more ventilation anyway, right? LOL
    Thicker Carpet installed in previous house, front door now dragging too much. Went to trim, had to destroy a nice metal sweep on the bottom to trim. Trimmed door, then there was 1/2'" of new light coming through. Only really needed to remove the sweep. :frusty:
  17. Apr 10, 2019 at 5:40 AM
    CMB
    CMB New Member
    Cecil County MD.
    Trooper 2, rsgt and Matt
    Thank you Sir. I have some of the trim with glue inside on my Tundra. Used it around the tailgate and on top of the headlights. Heating it up is about all we can do. I heat it, till it gets almost "squiggly":D I'm thinking it'll hold just fine, mine's been on for several years.
  18. Apr 10, 2019 at 5:59 AM
    That sucks....heh...heh..
  19. Apr 10, 2019 at 6:01 AM
    You could mount it on a pole and put it in the garden to scare critters away.
  20. Apr 10, 2019 at 6:46 AM
    Trooper2
    JR
    A couple Ubolts and it may turn with the wind..... Some real yard art there.
    Also starting to look like a piece of erotic female body armor......:spy:
  21. Apr 10, 2019 at 6:54 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    By that you mean you've simply removed it for good? If so any issues from running without it on the street?
    Thanks,
    B
  22. Apr 10, 2019 at 7:04 AM
    Trooper2
    JR
    Not really for street drivers, is conceivable that some kind of trash could end up there, possbly damaging something, mine has been out a year. on 07 there are 3 places that front shroud bolt to skid plate that end up hanging, not fastened.
  23. Apr 10, 2019 at 7:32 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    How does that buckle work when you use the skid plate for skidding?
    I would think you would shear it off
  24. Apr 10, 2019 at 7:34 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Done that before, hahaha. FYI, Toyota actually calls subject item "splash guard" not skid plate, because it so thin and flimsy that it cannot function as skid plate.
    RitcheyRch and Trooper2[OP] like this.
  25. Apr 10, 2019 at 7:40 AM
    War Machine
    It wasn’t on there when I bought it. Didn’t notice it for a long time. I haven’t had any issues that I’m aware of.
  26. Apr 10, 2019 at 8:14 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    So have I
  27. Apr 10, 2019 at 8:23 AM
    It was a fancy door that was going in my sister's house. Boy was she real pleased....
  28. Apr 10, 2019 at 8:28 AM
    bvia
    bvia New Member
    None
    Excellent!
    B
  29. Apr 10, 2019 at 8:35 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Hook up some rock lights above the skid holes!
  30. Apr 10, 2019 at 8:39 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    TRD Pro look to it. Thanks for sharing.
    Peace. D
