New to me Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by TravisT4, Mar 26, 2019.
  1. Apr 3, 2019 at 4:46 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I’ve thought about them, but because I tow and haul to max payloads sometimes decided they are a dangerous item in my case. They look cool for sure. I think the minimum spacer is 1.25” on ours. You may need new longer lugs bolts(on the back?) as OEM ones are different lengths in the front vs back. This allows your nuts to get up on the threads better after spacer install.
  2. Apr 3, 2019 at 5:07 PM
    TravisT4
    TravisT4 [OP] New Member
    Travis
    Hartland WI
    2006 Tundra Double Cab TRD
    I will not be towing more than about 3000 pounds with this truck which will be very rare and for short distances. I do not want to have to cut the factory studs at all, so I was hoping I could get a size that would allow this. That is weird they are different lengths front and back, any idea why?
  3. Apr 3, 2019 at 5:11 PM
    Fred
    Hand Protectors
    Not sure but I think you would have to install loner ones on the back. I read this on here on at another site. Someone please confirm.
  4. Apr 3, 2019 at 6:07 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I can confirm, you don’t need longer studs if running 1 inch or thicker spacers. I’m running wheel spacers on my 2006 tundra and I have not had any problems. I used medium duty thread locker when installing the spacers to the vehicle. I ordered mine off eBay and made sure they were hub centric with a 106 hub bore and made out of 6061 aluminum. I also used ET Style open ended lug nuts for more thread engagement. Here are the parts I used/recommend:
    https://www.ebay.com/itm/4-Pc-Toyot...741294?hash=item419a8c02ee:g:cGUAAOSwEIFZzWYI
    https://www.ebay.com/itm/Lug-Nuts-O...:USPSPriorityMailSmallFlatRateBox!77072!US!-1
    Dannydirtyfingers likes this.
  5. Apr 3, 2019 at 6:21 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Forgot to mention, I’m using the 1.5 inch spacers. It was by mistake really, because I initially ordered 1.25 but received 1.5. Anyways, I cleared things up with the seller and ended up keeping and liking the 1.5 inch:thumbsup:
  6. Apr 3, 2019 at 7:28 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Beauty of a truck and a steal of a deal. Welcome from WA
    Nice name to ;)
  7. Apr 3, 2019 at 7:35 PM
    Need to know stuff
    Not trying to show off or anything ;) but this is my truck with 1.5 inch spacers and 285/75/r17 with around the same offset rims as stock.
    Just trying to make shure u go bigger :)
  8. Apr 3, 2019 at 7:38 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Gotta pic from the side? OEM Wheels?
  9. Apr 3, 2019 at 7:44 PM
    Need to know stuff
    Aftermarket Craigslist wheels
    I measured the offset (just with a tape measure) when I got them compared to stock and they were pretty close
    Not entirely the look i wanted with the chromies. But I'm rocking it for now
    Also i redneck trimmed my buMper with a sawazal, i plan on going tube buMper soon, just to lazy to run a hour down to the closest steel yard :)
  10. Apr 4, 2019 at 9:33 AM
    TravisT4
    Travis
    Hartland WI
    Im really liking the stance with the 1.5 in spacers. Im definitely going to have to get some of those, I might go with a 1.25 to keep the tires just in line with the fender flares.
    revtune likes this.
  11. Apr 7, 2019 at 5:51 PM
    TravisT4
    Travis
    Hartland WI
    I got the truck lifted this weekend, it is 2.5 in in the front and 1.5 in the back. I also did a diff drop and the brake valve relocation thing. I am really happy with how it looks. I still have to get an alignment done Im guessing but to the naked eye the alignment looks good.
  12. Apr 7, 2019 at 5:54 PM
    Tempest
    Tempest You feel lucky??!!
    2015 Limited TRD
    Welcome from AZ! :tumbleweed:
  13. Apr 7, 2019 at 6:26 PM
    Need to know stuff
    Beautiful, keep us updated, especially if your getting bigger tires :)
  14. Apr 8, 2019 at 7:47 AM
    TravisT4
    Travis
    Hartland WI
    I have been looking at craigslist to see if I can find a good deal on a set maybe with some different rims because I noticed the chrome is starting to peel in places on the stock wheels. When I was doing the diff drop I had the remove the skid plate and because it was so rusty that I didn't put it back on. Anyone know where I can pick up a skid plate for relatively cheap?
  15. Jul 25, 2020 at 10:54 AM
    BikeRagsTony
    BikeRagsTony New Member
    Cedar Rapids, Iowa
    2006 Tundra Limited
    Would you be willing to share what products you ended up getting for your lift? That's what I'm looking to do with mine and I'm just starting on research. I saw mentions of towing capacity can be affected. Is there a drastic reduction in towing with the setup you have?
  16. Jul 25, 2020 at 11:49 AM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Ya. you got a pretty good deal from what I see. Way to be.
  17. Jul 25, 2020 at 6:19 PM
    bokch0y
    bokch0y I'm a sucker for DirtySOHC's
    Truck looks sweet!!! Welcome from Canada.
  18. Jul 26, 2020 at 6:55 AM
  19. Jul 26, 2020 at 6:59 AM
    Nice looking truck. I've been running 1.25" wheel spacers for 13 or so years with no issues. Have towed at the truck's limit numerous times without issues. I have hub centric ones, keep em properly torqued. Inspect at each tire rotation.
  20. Jul 26, 2020 at 7:38 AM
    #50
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Welcome from True NorCal, where trucks that nice never go up for sale, and certainly not for that good of a price! If you are like most of us, you will fall in love with your Tundra. Great group here and they know their stuff!
