Robin Electronics Bed Light Recommendationn
Discussion in '2.5 Gen Tundras (2014-2021)' started by driverwannabe, Apr 7, 2019.
  1. Apr 7, 2019 at 5:43 PM
    driverwannabe
    driverwannabe [OP] New Member
    i did the install of these lights this weekend, and they are perfect!
    https://www.amazon.com/gp/product/B075Z4QRBX/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    I have a crewmax with a factory plastic liner and Bakflip F1 cover. The instructions for the lights say to use drill bits to enlarge holes in the metal bed walls so that the connectors for the four lights can pass through the walls, then run all the wiring under the truck.
    I went another direction, just running the wire to the battery through the cutout on the front left of the bed, and ran all the wiring to the lights between the bed and the liner. Some zip ties cinch up the lights to to liner in the four corners.
    There are no switches or need to remember anything with these lights. One touch to any of the four lights turns them all on. They shut off themselves off if forgotten in one hour, or when the truck is started.
    The wiring is OEM quality and the lights are LED bright and waterproof.
    The pictures on the link are better than any I tried to take.
  2. Feb 20, 2020 at 6:00 AM
    Singhv497
    Singhv497 New Member
    Vikash
    2019 Toyota Tundra Platinum
    Hello there do you know anywhere else these are sold looks like their out of stock on Amazon or they might not even make them anymore.
