Anyone running a Rough Country 6" lift on 3rd gen?
Discussion in 'Suspension' started by HotRod65, Apr 6, 2019.
  1. Apr 6, 2019 at 6:37 PM
    HotRod65
    HotRod65 [OP] New Member
    Do you get a lot of outside tire wear?
    The reason I ask is because my procomp lift really wears out my front tires. The procomp lift and some others have you cut the tierods because their knuckle's steering arm is moved in to create wheel clearance. I am trying to find some knuckles that will correct this. It looks like the RC lift doesn't require you to cut the tierods or install shorter ones so it shouldn't affect the ackerman angle. Just wanted to check with anyone who has the RC 6 inch lift.
  2. Apr 6, 2019 at 6:40 PM
  3. Apr 6, 2019 at 6:40 PM
  4. Apr 6, 2019 at 6:45 PM
  5. Apr 6, 2019 at 6:48 PM
    6" RC lift, wheels 20x9 Fuel Mavericks +20 on 35*12.50*20 stock UCA's
    No wear on mine I have lifetime alignment with Firestone and did road force balance, trying to save for SPC adjustable UCA, but no wear on tires
    BTBAKER and Prostar 190 like this.
  6. Apr 6, 2019 at 6:50 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    At this time no I don’t. I have about 2,000 miles on lift and tires. But I will double check mine tomorrow.
    Prostar 190 likes this.
  7. Apr 6, 2019 at 6:50 PM
    Mine is a 2nd gen no wear on mine.
    jeremyd and DM 2018 Tundra like this.
  8. Apr 6, 2019 at 6:52 PM
    DM 2018 Tundra
    2018 Limted Tundra
  9. Apr 6, 2019 at 6:57 PM
    You 4wd? If so, this kit requires cutting of rear crossmember at both ends, my self and couple other members have the older lift kit version that didn't have our RCM cut at all, the newer kit does as per their instructions
    DM 2018 Tundra likes this.
  10. Apr 6, 2019 at 6:57 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Sorry about that so you have a PC lift. Far as I know for other folks with RC lift no issues with the tires. This has come from the place I had my lift put and the dealer that sells lift Tundra. That’s one reason I didn’t go with PC. The place that did the aliment also states the PC was bad about the outside of the tires dip and wear crazy. Good luck
  11. Apr 6, 2019 at 7:04 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have been running a ProComp stage 1 for the last 5 years. No outside tire wear. 2 days ago, I removed the Procomp spacers and replaced with a Rough Country N3 strut utilizing the OEM coil. Alignment shows fine and drives smooth and normal.
    DM 2018 Tundra and Prostar 190 like this.
  12. Apr 6, 2019 at 7:08 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    And of course, might as well show off my ride again ! Lol
    toyofan87, Bones2012, Pinay and 4 others like this.
  13. Apr 6, 2019 at 7:19 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Dude love that red! Ur ride is sharp!
    jeremyd likes this.
  14. Apr 6, 2019 at 7:34 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    @HotRod65 Are you running stage 1 or stage 2 ?
  15. Apr 7, 2019 at 6:13 AM
    Mnorris1206
    08 tundra
    Have had my 6" rc lift for 3 yrs. Have done 3 alignments. didn't need them but I keep changing things so it has been needed after changes but I have great tread wear on my tires.
    Prostar 190 and DM 2018 Tundra like this.
  16. Apr 7, 2019 at 6:05 PM
    HotRod65
    I have a stage 1.
  17. Apr 7, 2019 at 6:31 PM
    Like looking at that truck.
    jeremyd[QUOTED] likes this.
  18. Apr 7, 2019 at 6:34 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Roger that, I ran the stage one with a spacer for almost 5 years with no outside tire wear. I’m thinking maybe your bushings might be worn. Hope that helps.
  19. Apr 7, 2019 at 6:37 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Thanks Bryan, yours is one my favorites also !
  20. Apr 7, 2019 at 6:52 PM
    Thank you Sir.:hattip:
