2000 tundra tires cupping
Discussion in '1st Gen Tundras (2000-2006)' started by Valler, Apr 4, 2019.
  1. Apr 4, 2019 at 9:55 AM
    Valler
    Valler [OP] New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    So after 8 installed new tires like 2 months ago im now start to see cupping on the front tires, could yall help me figure out what i need to change, im thinking its the struts in front to begin with. And suggests?
  2. Apr 4, 2019 at 10:02 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Fought it on a F150. First I tried shocks. No help. Eventually I discover the lower ball joints were shot. Who would have thunk it at 40k. Of course it was a Ford. Best part was I called a Ford service manager and he says "you are lucky to make it to 40k most go bad at 25k". It was at that moment that I decided I was never buying another Ford truck. I was trying to remember what I responded with. I think it was "you have to be f%*king kidding me".
  3. Apr 4, 2019 at 10:05 AM
    Valler
    Ramon
    Thanks im thinking of buying the kit for the the front end from 1a comes with everything for the front end suspension except the struts but the kit cheap then struts
  4. Apr 4, 2019 at 10:34 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    have you gotten an alignment recently?
  5. Apr 4, 2019 at 10:42 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Tire pressure could be too low.
  6. Apr 4, 2019 at 11:28 AM
    Valler
    Ramon
    Had alignment done when i bought the tires
  7. Apr 4, 2019 at 11:33 AM
    15whtrd
    15whtrd Mr. Blonde
    As others said the suspension components like ball joints can come into play. Are you rotating at the proper mileage. I do about every 5000 miles when I change my oil. Were your old tires cupping? If not, it’s possible they botched your alignment. Where did you have it done? Some places just suck. I went to an off-road shop who specialized in alignment. I had to pay good money for it but it was done right.
    Valler[QUOTED][OP] likes this.
  8. Apr 4, 2019 at 11:33 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The trouble with cupping is it can be caused by different things, and I think once it is present on a tire the wear pattern just continues even if you fix the cause.
    I had it before, thought it was shocks and rebuilt them. Changed lower ball joints too, it still kept going. I think it could have been lower arm bushings all along but not sure. I've replaced everything on my front end now and got new tires and alignment so hopefully it's gone now.
    :rolleyes:
    Valler[OP] and 15whtrd like this.
  9. Apr 4, 2019 at 11:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I think a lot of people forget about the lower a arm bushings. Seems like the alignment shop will pull everything into spec, but then it’s kind of a bullshit spec because the bushings are shot.
    Valler[OP] likes this.
  10. Apr 4, 2019 at 3:08 PM
    Professional Hand Model
    Fred
    Hand Protectors
    My tired worn front end messed up some new tires a few years ago. You could see right away on the new tires the wear pattern was starting out bad.
    Just had the front end rebuilt and the new tires wear pattern looks even. Same brand/size Michelins.
    Not sure what to say as it could be a number things making your tires cup.
  11. Apr 5, 2019 at 4:58 AM
    bmf4069 Captain wtf
    The big issue is hair in the face. Or if you flip around it kinda de-masculates you. Oh wait, that's spooning. Cupping? I thought that happens when you dont have enough air in your tires. What if you go over on the psi, more towards the upper range or a bit over?
    Valler[OP] and Darkness like this.
  12. Apr 5, 2019 at 6:20 AM
    Valler
    Ramon
    I will have to try everything in order to see what fixes it, in order to save my new tires,
