CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Apr 2, 2019 at 1:23 PM
    #541
    Justincase76
    Justincase76 New Member
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
  2. Apr 2, 2019 at 1:32 PM
    #542
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Since the OP has let his thread temporarily side track to 2nd batteries, connectors, wiring, etc., for those of you that do IT, or know someone that does, UPS's (uninterrupted power supply, not the brown truck we all know and love) are a great source for the Anderson connectors.
    We junk probably 20-30 UPS's a year and each one of them is good for a pair of Anderson connectors. I keep a stash of half a dozen or so in my desk, cuz, ya never know.
    smslavin[OP] likes this.
  3. Apr 2, 2019 at 1:37 PM
    #543
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    ahhhh. head spinning.
    if i use 8g wire, i need a 50a powerpole connector. if i cut off the cigarette lighter plug from the dometic cable, that wire is no where near 8g. so, how do i mate the two up? can i use the 50a connector with a smaller gauge?
  4. Apr 2, 2019 at 1:38 PM
    #544
    smslavin
    Hudson Valley
    Some stuff
    sidetrack all you want. all good by me. :cool: :cheers: :drunk:
  5. Apr 2, 2019 at 1:43 PM
    #545
    smslavin
    Hudson Valley
    Some stuff
    never mind me. just found my answer. dometic power cord with a 50a connector. unfortunately, they are no longer available and it isn't any longer than the one that came with the fridge.
    so, now i'll check with powerwerx and see if they'll make a cable with the 50a connector and 12g wire.
  6. Apr 2, 2019 at 2:22 PM
    #546
    smslavin
    Hudson Valley
    Some stuff
    ok, powerwerx is awesome. will be using them again for sure. ordered a 10' 12g wire with a sb50 connector as well as a 40' 8g wire with a matching sb50 connector. over at wit's end, i found a flush mount bracket for a sb50 connector which i'll put into the panel i'm making.
    Taco-Blender likes this.
  7. Apr 2, 2019 at 3:00 PM
    #547
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    That's a whole lot of 8g wire...... but you can keep the extra 20 - 25 feet. Good luck on the project!
    smslavin[QUOTED][OP] likes this.
  8. Apr 2, 2019 at 5:02 PM
    #548
    smslavin
    Hudson Valley
    Some stuff
    yea, probably too much. but, knowing me, i'd order 20' and come up short by 1. so, i'd rather be safe than kicking myself.
    3mxdivr[QUOTED] likes this.
  9. Apr 3, 2019 at 5:41 AM
    #549
    Stig
    Stig New Member
    That will be perfect, similar to what I did.
  10. Apr 3, 2019 at 7:50 AM
    #550
    smslavin
    Hudson Valley
    Some stuff
    after a few days of digging around, i finally found some aluminum (5052) sheets. metal supermarkets down the road is going to cut me two pieces (in case i screw one up) of the size that i need for the panel i mocked up with cardboard. all i will have to do is cut out the mounting holes and paint it.
    i'll mount it with two bolts into the bed rail and a couple of angle brackets onto the decked drawers. should be pretty solid.
    Justincase76 and Taco-Blender like this.
  11. Apr 3, 2019 at 10:00 AM
    #551
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Awesome build! If you need another kid let me know, I come with the added skills of being able to wipe my own ass :crapstorm:
    Civiceg94 and smslavin[OP] like this.
  12. Apr 3, 2019 at 10:02 AM
    #552
    smslavin
    Hudson Valley
    Some stuff
    oh. bonus. :cool:
  13. Apr 3, 2019 at 1:14 PM
    #553
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Check these guys out
    http://absolute-wits-end.com/electrical/
  14. Apr 3, 2019 at 2:21 PM
    #554
    Justincase76
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
    smslavin[OP] and Bailey[QUOTED] like this.
  15. Apr 4, 2019 at 3:34 PM
    #555
    smslavin
    Hudson Valley
    Some stuff
    so, we’ll call this a partial check off...
    the cutout on the left matches the heat sink for the solar controller. just need to drill the holes for the mounting screws. the two holes at the top will bolt to the bed rail. we’ll see how stable that is. if it needs more, i’ll use an angle bracket or two into the top of the drawers.
  16. Apr 4, 2019 at 5:00 PM
    #556
    DECKEDUSA
    DECKEDUSA New Member Vendor
    That is a sweet slide! Nice addition
    How easy is it to use when the fridge is loaded down with cold ones and otter pops? :cheers:
    DECKED
    www.decked.com
  17. Apr 4, 2019 at 5:31 PM
    #557
    smslavin
    Hudson Valley
    Some stuff
    slide is amazingly easy. haven't tried it loaded yet but it should be just fine. and, otter pops? most definitely.
    DECKEDUSA[QUOTED] likes this.
  18. Apr 5, 2019 at 3:44 PM
    #558
    smslavin
    Hudson Valley
    Some stuff
    well. i guess it’s good that i bought two pieces of aluminum since i just re-made the panel...
    cables from powerwerx arrived today too. quality. need some bolts to mount the solar controller. make the holes for the bed rail bolts. then paint.
  19. Apr 7, 2019 at 11:56 AM
    #559
    smslavin
    Hudson Valley
    Some stuff
    hmm. futzing around with dual battery install using the xfaktr tray.
    853B9A48-F823-495C-B308-36506779183B.jpg 02B5A27E-4F07-40B2-B88F-23099F7FA83C.jpg A3720F7B-7DEA-4951-8885-F446F6C8973D.jpg
    fits two odyssey 34R PC1500 batteries. but, since they’re vertical, it makes connections interesting. factory cables no longer reach so they need modifying. has anyone else on here installed this setup? i’m going to see what i can figure out but i may bite the bullet and have someone else do this one. probably the off grid engineering guys.
    if you have ideas, would love to hear them.
    Black Wolf and JoshuaA like this.
  20. Apr 7, 2019 at 12:10 PM
    #560
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Wow... I'm having a knowledge overload here...
    Black Wolf, TheBeast and smslavin[OP] like this.
  21. Apr 7, 2019 at 12:30 PM
    #561
    smslavin
    Hudson Valley
    Some stuff
    3mxdivr likes this.
  22. Apr 8, 2019 at 8:24 AM
    #562
    smslavin
    Hudson Valley
    Some stuff
    ok, so, here we go. parts ordered for the big 4 upgrade...
    :spending: :bananadead:
    Black Wolf, zcarpenter92 and TheBeast like this.
  23. Apr 12, 2019 at 6:42 AM
    #563
    smslavin
    Hudson Valley
    Some stuff
    brushing up on a few things before a weekend of projects...
    Black Wolf likes this.
  24. Apr 12, 2019 at 8:03 AM
    #564
    3mxdivr
    3mxdivr New Member
    NorCal
    When i did my dual battery setup, it was easier to make my own cables, then you are dealing with less slack and will be easier to tuck in. Most difficult part was laying out different components of the Redarc system on the genesis offroad tray..... Goodluck man, fun times ahead!
  25. Apr 12, 2019 at 8:42 AM
    #565
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    Where did you order the xfactor products? I reached out to them about their compressor mount and I haven't heard anything from them.
  26. Apr 12, 2019 at 12:03 PM
    #566
    smslavin
    Hudson Valley
    Some stuff
    let’s cut some shit...
    and weld a some new shit...
    learning some new tricks from @ColoradoTJ.
    Black Wolf, d0zer, 3mxdivr and 2 others like this.
  27. Apr 12, 2019 at 12:05 PM
    #567
    smslavin
    Hudson Valley
    Some stuff
    unfortunately, i think he’s out of commission. not sure what happened since he also disappeared from this site.
  28. Apr 12, 2019 at 2:00 PM
    #568
    So. Many. Shocks.
    Rich man problems:eek:
    988AE14C-9812-4FB2-B8C1-33665AC7FC54.jpg C0E9F566-A9DC-4961-A238-5A692B262477.jpg
  29. Apr 12, 2019 at 2:21 PM
    #569
    smslavin
    Hudson Valley
    Some stuff
    just about halfway...
    Black Wolf, TheBeast and T-Rex266 like this.
  30. Apr 12, 2019 at 2:58 PM
    #570
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Who did you use for your secondary shock hoops?
