Grinding Noise in Reverse-Please Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by mrflyinghigh, Apr 3, 2019.
  1. Apr 3, 2019 at 11:54 PM
    mrflyinghigh
    mrflyinghigh [OP] New Member
    Jared
    2018 Blazing Blue Tundra Platinum
    I am having an issue where I am getting a loud grinding/catching noise. It almost sounds like my tire is catching on plastic but that is not the case and have verified that there is no contact between the tire and wheel well anywhere. This is only happening when I am moving in reverse with the tires turned almost all the way to the right. It does not make this noise when I turn the wheel the opposite direction. As soon as I straighten it out, about 1/4 of a turn, it goes away. I do have Bilstein 5100’s to level the truck out, and aftermarket wheels with 33” tires. I have had them on there for 5,000 miles with no issue until now. I do not believe this to be the CV because, then it should happen when going forward too right? Maybe I am wrong, but I am open to suggestions.
    Thank you for the help!
  2. Apr 4, 2019 at 2:52 AM
    koditten
    Kirk
    Midland of the Mitten
    Jack up the truck, crank the wheel, turn the tire by hand. If it makes noise, then you have narrowed down the issue. Report back what you find.
  3. Apr 4, 2019 at 9:55 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    33 inch tire leveled out is awfully close to the front flap with the wheels turned. It could be that you get a very minor touch at that angle moving forward and don’t notice or hear it because the wheel is moving away from it. In the opposite direction, the tire will catch it and push against the grain, so-to-speak, and it will be very noticeable. It’s a long shot, but that’s how I ended up heating and bending mine. I am sure you will figure it out.
  4. Apr 4, 2019 at 10:01 AM
    Probably rubbing that front mud flap In front of tire
    15whtrd likes this.
  5. Apr 4, 2019 at 10:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you verify there's no contact WHILE the truck is moving in reverse? I'm gonna bet it's rubbing on plastic.
    15whtrd likes this.
  6. Apr 4, 2019 at 10:23 AM
    mrflyinghigh
    Jared
    No I have not had anyone back up while I’m outside looking. But it’s so weird it’s only happening in reverse, and only turned to one side.
  7. Apr 4, 2019 at 10:28 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, that happens. And if it's barely rubbing, you can't tell when the truck isn't moving. It'll only rub when it's moving in reverse.
    NewImprovedRon likes this.
  8. Apr 4, 2019 at 10:29 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And if it's rubbing in Full lock, make sure you're not rubbing on the corner of the skid plate if you have one.
  9. Apr 4, 2019 at 10:34 AM
    15whtrd
    15whtrd Mr. Blonde
    I’d like to add, if it didn’t used to rub until recently it is also possible that your alignment got out of whack, or they didn’t tighten the LCA bolts enough.
