2014-White SR5/Supercharged
Discussion in '2.5 Gen Builds (2014-2021)' started by white_sherpa, Dec 26, 2018.
  1. Dec 26, 2018 at 5:15 PM
    white_sherpa
    white_sherpa [OP] New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    It's been a while since I posted or updated on a build thread in any forum, as most of my post were over on TT and IG https://www.instagram.com/white_sherpa/ with all my build updates -Thought I would post a few specs off my build, as I've gotten a ton of PM's.
    It’s long past the initial start, but I thought I’d post where it sits now and if anyone had any questions, I’m more than happy to answer them.
    Thanks @TRON for the pre-selected layout :bowdown:
    All modifications are done by me unless noted: welding, electrical, suspension, bolt-ons, etc...
    VEHICLE SPECS:
    -2014 SR5 4x4 CrewMax
    -5.7L Non-FLEX
    PERFORMANCE:
    -Magnuson SC (Installed in 2018 @ 75K mileage) Custom Tune (Dyno Comp)
    -Custom 3" from Dyno Comp
    -aFe Headers
    -PowerStop Z36 Pads all around
    -PowerStop Evolution Rotors all around
    -Stoptech SS Brakelines
    WHEELS/TIRES:
    -Method NV Bronze 17"x8.5-0/4.75"
    -35/12.50R18 Toyo Open Country R/T
    -BORA 3/4"" Wheel Spacers up front
    -454 Removal Bedcage
    SUSPENSION (MID-TRAVEL):
    -Icon 2.5 Coilover Res (non CDC)
    -16" 700lb Eibach Springs
    -Icon Tubular UCA
    -Icon S2 Bypass 2.5
    -PolyBushings Steering Rack Kit
    -Total Chaos Spindle Gussets
    Rear Long-Travel Setup
    -SS Built Bedcage
    -King 3.0 16" Bypass
    -King 2.5 Bumps
    -Strapped
    -Deaver i96HD
    Gears:
    -Nitro 5.29
    RECOVERY GEAR:
    -Pro Eagle 2 Ton Jack
    -Bolt Locks
    -Tow Strap
    -NOCO GB400
    COMMS:
    ICOM
    POWER MANAGEMENT:
    -Switch Pro Power System
    LIGHTING:
    -Baja Designs S8 30" Front bumper mount/Amber Combo/Driver
    -Baja Design Squadron Pros in Fog location
    -Sypder Headlights, with H9 Elite retrofit bulbs
    -Baja Designs S2 Sport x2 chase lights/Amber
    -Rigid Ignite/Rear Auxiliary Lights
    EXTERIOR:
    -Total Chaos Cam Tab Gussets
    -Monstaliner Bedliner/Roll on
    -ARB Dual Onboard air with 2.5 gallon tank
    -Rigid Grille
    -SS Built Custom front bumper and rear high clearance
    -ADV Glass
    INTERIOR:
    -ESP Plastic Rear Seat Storage
    -Icon Gear Shifter
    -Husky Liners Front
    -WeatherTech-Rear
    LIQUIDS:
    -Amsoil 10w40
    -Amsoil 85w140 Front/Rear Diff
    -Amsoil 75w90 Transfer Case
    -Amsoil ATF
    -Amsoil Brake Fluid
    -Amsoil Powder Steering Fluid
    As it sits now
    Prior Change
    B1BBCBA9-21B9-402A-B1CE-2168C69D8936.jpg 515CB9AF-BD97-41B3-8478-EA07EBA00F64.jpg 12E0EEAB-6898-4AFA-991C-8ADB51F6626B.jpg
    The Magnuson Supercharger was a fun install, fairly straightforward, only occurred one issue with a bolt that was incorrect. Total time was about 16hrs for the install
  2. Jan 4, 2019 at 10:43 AM
    white_sherpa
    Phoenix, AZ
    *Update- ARB Dual added to engine compartment, but plumbed to existing tank with air lines
    Here's a write up of the on-board air I'm running. *These are older pictures of the suspension that I was running*
    The biggest challenge I had with mounting the on-board air was routing the wires. There are only a few places you can get away with, running the wires in-front of the bed. I was able to patch through the rear lower left inside panel and make it a clean install. All wires are hidden.
    The tank was mounted to the right of the gas tank towards the front of the bed. While it did take me a bit to figure out the best location for the 400C (#Viair) compressor, I ended up mounting it to the inside of the chassis/parallel to the rear tire. Compressor fit well and ran the air outlet hose to the right of the bed.
    The Viair Compressors is configured through my Swith-Pros module.
  3. Jan 26, 2019 at 5:00 PM
    white_sherpa
    Phoenix, AZ
    Added the @sdhq_offroad chase rack. I opted to run the chase rack with a single configuration at the moment, as I wanted a bit more space if I needed to haul some stuff around and mounted the pro eagle jack along with fuel jug to the modular rack. The added weight helps the rear settle down a bit, and smooths out the ride. I ended up keeping the metal raw and powder coated it clear to protect from rust.
    040Tundra and Luckydog like this.
  4. Jan 26, 2019 at 5:03 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Whoa who is this guy?
  5. Jan 26, 2019 at 5:07 PM
    white_sherpa
    Phoenix, AZ
    Spooky
    Erichudgins and PLC721[QUOTED] like this.
  6. Jan 28, 2019 at 8:32 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    :wave: damn that layout does look good :cool:
    white_sherpa[OP] and Erichudgins like this.
  7. Feb 21, 2019 at 2:56 PM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Not sure why I'm just finding this, but I've always been in love with your truck.
    white_sherpa[OP] likes this.
  8. Feb 21, 2019 at 8:29 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  9. Mar 5, 2019 at 6:45 PM
    white_sherpa
    Phoenix, AZ
    I love your truck too @KevinK :) we both have good taste!!
    KevinK[QUOTED] likes this.
  10. Mar 5, 2019 at 6:54 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Very nice truck! And white :yes:
  11. Mar 5, 2019 at 6:58 PM
    white_sherpa
    Phoenix, AZ
    Ended up getting my SC re-mapped locally in Scottsdale, AZ that does custom tuning both on FFV, Non-FFV along with NA Tundra's. They are a reputable shop and partner with Magnuson SC.
    I purchased the SC with a Bully Dog tune and was happy for the most part, however after the new ecu flash, it was apparent the BD tune was running the old lady a bit rich and under power. I'm even more happy that the AF mixture were optimized and increased good amount of power both in mid and high curve.
    The good thing about the new flash, it's specific to the truck, so whether you have intake, headers, exhaust it can be calibrated for those mods and run optimal. Glad I was able to work with a few local people (Jeff and Ben) that referred me to Dyno Comp in Scottsdale. Richard does great work and very reputable and knowledgeable individual.
    Current Engine Mods:
    Magnuson SC
    Custom Tune- Non/FFV 91 octane
    Custom 3" Exhaust with Headers
    Here are the numbers/Vid:
    AE2748D2-2C46-4768-A54F-C1B6997B08FB.jpg 9E9186E4-2C2F-46A5-B92A-94B24A631A35.jpg
    GAknight, Midway, TRON and 4 others like this.
  12. Mar 7, 2019 at 6:45 PM
    JTS2019TUNDRA
    JTS2019TUNDRA New Member
    Jamie
    2019 MGM Tundra Crewmax TRD Sport 4x4
    Stock
  13. Mar 23, 2019 at 10:30 PM
    khens12
    khens12 New Member
    Kevin
    2018 Tundra SR5 Off-Road 4x4
    - Icon Billet UCA - King 2.5 Coilovers - King 2.0 “Shorty” Bumpstops
    Great build brother. Can you throw up some pictures of your chase light mounting and how you wired it? I’m trying to figure out the best path to my sPod source block in the engine bay.
  14. Mar 24, 2019 at 6:39 AM
    white_sherpa
    Phoenix, AZ
    @khens12 Thank you Sir!
    I fabed up 2 post brackets and mounted them to the front bedrail stiffeners. I then routed the wires behind the bed and through the drivers side bottom gourmet that goes into the cab. I split off and grounded the black wire in the rear and ran the power wire drivers side along the bottom door seal through the firewall to my switch-Pro.
    Hope this helps
    467E50A3-8D80-4169-8536-465755658204.jpgD8924889-3642-4CB3-9B2A-1445B2E28227.jpg23139AA6-81B8-4ABF-9096-0A3A25804C19.jpg19E0C887-D7C0-4ACD-9771-5EBCD5CB193E.jpg20352BB8-8BCC-4856-8AD3-18C78829C7A9.jpg
  15. Mar 25, 2019 at 5:18 PM
    white_sherpa
    Phoenix, AZ
    Ended up tearing the front steering rack completely out to replace the bushings with polyurethane. Some have had luck with replacing the bushings without having to take the rack out, I applaud you!
    Mine were rusted and there was no way, I could have done it in the truck. Ended up taking the LCA off, dropped the front diff and removed the rack. Took 2 days and about 6 hours total. It was great having @TRON helping with final install of rack and diff and buttoning things up.
    My recommendation, if anyone wants to tackle the project, dropping the front diff will save time and it’s the only way of getting it out if you have 4 wheel drive unless you can do it in the truck.
    C8AB16C1-3D86-42AA-8362-21D64125D232.jpg 73A6B696-9066-4FD8-A542-BD8C6732A358.jpg C12BDFDB-3478-44D2-A55B-8CB6600BBEAD.jpg 9CFECCC2-7061-4485-8DF3-62AD138BE44D.jpg
    trayday and TRON like this.
  16. Mar 25, 2019 at 8:24 PM
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Glad I could help man! That's an extremely difficult project doing it solo! I am excited to see your "other" new mods coming up :cool:
  17. Mar 27, 2019 at 4:45 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Why are you switching back to the OEM tie rods? Just curious.
    trayday likes this.
  18. Mar 27, 2019 at 12:34 PM
    white_sherpa
    Phoenix, AZ
    @5.7TRDProm - For what I put the truck through I’ve been through 2 sets of heims, not sure the reason they keep failing. Stock at this point is better route for me.
    TRON likes this.
  19. Apr 3, 2019 at 8:24 PM
    white_sherpa
    Phoenix, AZ
    Few changes with the grille. I toyed around with getting rid of the thing because it weights a lot and a bit dated, but I didn’t like the stock look either. So I ended up switching all the lights out to BD, 20” Onx6 and 2 Squadron Pros wide beam. With a bit of fab work I was able to make them fit! Added a rear brace to the Onx to help with weight distribution to keep the load on the cross member support bracket. Also ended up added the FRAC harness and front camera.
    83A7BA2C-E57E-4CB4-A73E-1950D4A0F8DD.jpg 76435FFE-D820-407A-85BA-380B64B093F5.jpg C7C5D380-9265-4234-BC4E-EC1C01F52E6A.jpg 7BAE7A57-0DCE-46FC-8731-662B048088B2.jpg F9807903-D63B-44F0-A0CB-DE5667AF69DC.jpg 99A47B65-C68E-4EE0-A322-A30917147636.jpg
    GAknight, Vizsla, PLC721 and 2 others like this.
  20. Apr 30, 2019 at 12:20 PM
    TheBeast
    TheBeast The Beach
    nice ! are you running 18" or 17"s wheels ?
  21. May 12, 2019 at 7:47 AM
    white_sherpa
    Phoenix, AZ
    Sorry for late response, @TheBeast 17" on 35x12.5 tires
  22. May 23, 2019 at 2:04 PM
    white_sherpa
    Phoenix, AZ
    Finally got around to adding an external trans cooler from Wholesale Transmissions out of Australia. Great product, easy install and holds just over 1/2 quart. Tied it in to the existing trans lines coming off the internal cooler.
    It also fits with the heat exchanger for those with SC, so no issues there. Those running an upper light-bar behind the grille, will not be able to installs the cooler as it will not fit (no room).
    So far the temps have avg about 15-20 degrees lower then before.
    The only obstacle I had was my BD light bar behind my grille, have about 1/8 room between the cooler and bar
    78CC83EF-E0D3-48B4-A03C-39D5528C654F.jpg AF71C4A4-6261-403B-B236-180358C2D712.jpg 85817D2C-911A-4738-928B-6C2E5C56CED9.jpg 79E8A860-7CBB-4891-8A6B-5F1EF60C3221.jpg 0E58F077-22EE-45F1-B092-B137E1B9CB9B.jpg 46952635-DF1D-48F0-8BAA-02D43E85B07E.jpg
    J&ATundra, GAknight, T-Rex266 and 2 others like this.
  23. Aug 18, 2019 at 6:26 PM
    white_sherpa
    Phoenix, AZ
    Over the past few days I got around to installing the 65Watt Icom 2300H radio along with running the antenna wire from the bed and external speaker under the drivers seat. Overall the install went well, about 6 hours total. I chose to go with Icom, based off them being made in Japan and good reviews from others I've come across.
    The Icom tucked nicely within the console, in general its a good spot for mounting and running the wires underneath the carpet for a clean install. I ended up making a bracket for the antenna and mounted it to the bed rails, using the T Slot brackets. Shout out to John and Beau for the radio help!!!!
    Figured I can now use my hand held as spares :)
    Parts List:
    Radio:
    https://www.amazon.com/gp/product/B008I6LK4I/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Speaker
    https://www.amazon.com/gp/product/B009TNAGDA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Coax Cable
    https://www.amazon.com/gp/product/B00XCZMUQC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Antenna
    https://www.amazon.com/gp/product/B00794WAX0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Antenna Bracket
    https://www.amazon.com/gp/product/B00LMH1L5S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    DEA3A734-3BF2-4BD2-B14F-F6634D1A45A9.jpg 759A31D9-2123-4CD5-A76C-A89BE2B36F43.jpg CEB286FD-1BA2-41A2-B612-479D0995FF78.jpg 07707B96-66EB-4102-B464-334BC653D87D.jpg 3992DEA1-5D30-4721-80A3-9E0D92CA4D23.jpg 0574DD90-5203-4858-80D0-E5B71187715E.jpg 0B76E310-CF6B-43DE-B463-2E8DC1B4AB04.jpg B8268801-02C6-4BA0-B0BB-CA5D53D4C187.jpg
    GAknight, Flyinryank and GiantsFanDan like this.
  24. Nov 17, 2019 at 2:02 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Wow just wow!
  25. Nov 18, 2019 at 5:58 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I’d like to see that rear ss bumper and maybe how that exhaust sits
  26. Dec 5, 2019 at 2:35 PM
    white_sherpa
    Phoenix, AZ
    Sorry not on here much.....
    66740520-5F63-4468-9AB1-7765CA6A11D2.jpg 586778E0-DE2B-4AB0-9704-5249A2F75A63.jpg
    Trdwillie14 likes this.
  27. Dec 6, 2019 at 8:39 PM
    Lainhairr
    Lainhairr “Life’s a garden.. dig it” - JD
    Zach
    Northern Ohio
    SR5 TRD Off Road Tundra
    How are you liking those head lights? I have been peepin those for a couple weeks now and still havent pulled the trigger yet.
  28. Dec 7, 2019 at 12:34 PM
    white_sherpa
    Phoenix, AZ
    You need to swap the bulbs out for HID as they come with halogen bulbs. I used Morimoto H9 bulbs for them and they are good output now.
  29. Dec 30, 2019 at 5:13 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    sub'd. which trans line did you tie into for the external cooler?
