Horn question
Discussion in '2.5 Gen Tundras (2014-2021)' started by madmatt, Apr 2, 2019.
  1. Apr 2, 2019 at 7:17 PM
    madmatt
    madmatt [OP] New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Hey guys and gals! I have a question, and I ask that if you respond, talk to me like I’m 5 because I do not know anything electrical systems.
    My truck has a dual-horn system like everyone else’s. I decided to upgrade the horn. I installed it today and it was awesome! For about 5 honks when the fuse blew! It turns out that he new horn pulls 20 amps and the original fuse is 10 amps. Obviously I’m not going to just put in a bigger fuse (I’m ignorant, not dumb) so here’s the question. How do I make this work? For now I re-installed the original horns and replaced the 10amp fuse.
  2. Apr 2, 2019 at 7:18 PM
    What horns did you install?
    Hella horns should be installed with a relay.
  3. Apr 2, 2019 at 7:38 PM
    madmatt
    Ocala Florida
    It’s a Marco Tornado
  4. Apr 2, 2019 at 7:52 PM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    A relay will solve problem. Every truck I own gets several added on! Can even keep running your stock horns in addition to new horns for more loudness!
  5. Apr 2, 2019 at 7:58 PM
    dumbassdave
    dumbassdave Member
    Dave
    Bosch type relay: 12v from battery to pin 30. Pin 87 to 12v on horn. 12v from original horn to pin 85 on relay . Pin 86 on relay to ground.
    So, now when you press horn it closes the circuit for new horns.
    landphil likes this.
  6. Apr 2, 2019 at 8:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    dumbassdave[QUOTED] likes this.
  7. Apr 2, 2019 at 8:42 PM
    dumbassdave
    dumbassdave Member
    Dave
    Yes, fuse is needed unless you want a possibility of fire.
  8. Apr 2, 2019 at 8:57 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    And remember not to reverse the wires or when you push the button, your horns will suck not blow:rofl:
    A relay will safely handle the extra amps without melting wires or causing a fire. If you are not comfortable with this wiring job, either a local mechanic or even a car stereo shop should be able to handle this for you at a minimal charge.
  9. Apr 3, 2019 at 3:24 AM
    madmatt
    Ocala Florida
    Thanks. Yeah I can handle that. I may just keep the original horns and add this one then.
    Thanks.
    Racingjohndeere55 likes this.
