Diff drop
Discussion in 'Suspension' started by Jebell4747, Apr 2, 2019.
  1. Apr 2, 2019 at 9:04 PM
    Jebell4747
    Jebell4747 [OP] New Member
    2018 Tundra TSS
    Some of you know I’m having a time with the shop that done my lift. ( I know I should have just done it myself but I don’t have time). Here’s the pics of the diff drop they installed. Driver side sitting good but the pass side is not sitting right. Anyone know what is causing this? Any ideas on how I can correct this?
  2. Apr 3, 2019 at 2:45 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Have you backed it out then retightened it yet? Was it misthreaded? Any debris blocking it? I see small rocks and stuff.
  3. Apr 3, 2019 at 4:33 AM
    Jebell4747
    2018 Tundra TSS
    The small rocks are probably due to driving around since I had the lift put on. I haven’t had time to check it out myself but I’ve had it back at the shop about 3 times and they keep saying nothings wrong, some sit like that. I know that’s BS. Just asking around to see if anyone has ran into something like this. Personally I think they tried to pull the diff up by the bolt instead of trying jack it back up.
  4. Apr 3, 2019 at 4:40 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    You might want to get a second opinion from another shop.
    Blueknights75, 15whtrd and Black Wolf like this.
  5. Apr 3, 2019 at 4:47 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Looks like something is slightly bent and not seated properly. Looks like the arm is bent slightly back and to the left. Unless it’s the truck angle.
    15whtrd likes this.
  6. Apr 3, 2019 at 4:52 AM
    Jebell4747
    2018 Tundra TSS
    I have an appt with another shop on the 18th. Hoping someone has ran into this before and can give advice. I sure don’t want to have to tear that entire side down
    Fishman57[QUOTED] likes this.
  7. Apr 3, 2019 at 4:54 AM
    Jebell4747
    2018 Tundra TSS
    Lord I hope not lol I only have 11,000 miles on the truck
  8. Apr 3, 2019 at 5:15 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Is this a crack or extra rubber?
    dcsleeper408, Jerry311SD and 15whtrd like this.
  9. Apr 3, 2019 at 5:20 AM
    Jebell4747
    2018 Tundra TSS
    Just rubber shavings lol
  10. Apr 3, 2019 at 5:23 AM
    15whtrd
    15whtrd Mr. Blonde
    I think it’s funny how they’re telling you, “no no some just sit really stupid like that”! They might as well just tell you, no no it’s supposed to be wrong LMFAO
    dcsleeper408 likes this.
  11. Apr 3, 2019 at 5:25 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Is that shaving or another closer to the bolt be causing the seat issue? If it causing a gap right there then that could be it. Just mentioning everything possible.
    15whtrd likes this.
  12. Apr 3, 2019 at 5:36 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    My diff drop looked like that when I first installed it. I just pulled it out. Then I had my gears done a few months later and re-installed the drop after. It sat much better. The diff seemed to have more range of motion when unbolted for whatever reason. I’ve since just pulled it out again because my RCI skid wouldnt work with my NFab skid with the drop in.
    15whtrd likes this.
  13. Apr 3, 2019 at 6:19 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    It probably had a better range of motion because the bushing was skewed for so long that it kind of wore it out a little, made it more maliable.
    UTTundra[QUOTED] likes this.
  14. Apr 3, 2019 at 6:30 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Yea, on the first install, it wouldn't really "drop". Seemed like the rear mounts were somehow keeping the whole diff in place. Had to pry a bit to get the spacers in. I'm guessing when the gears were done, undoing the rear mounts restored normal range of motion. @Jebell4747 maybe loosening the rear mounts a bit would help get the front seated?
  15. Apr 3, 2019 at 11:14 AM
    15whtrd
    15whtrd Mr. Blonde
    It sounds like the key to getting it done right is loosening all the mounts when installing the diff drop. Then tightening them all up together. Similar to loosening the cam eccentrics on the lower control arm if you’re lifting your truck, then tightening them once the truck is back on the ground so it’s not up in a bind.
    UTTundra[QUOTED] and GAknight like this.
  16. Apr 3, 2019 at 11:48 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I think this^^^^ will be your solution, but I would first check the bolts to see if they were tightened all the way. Check out YT for some how-to vids, and note how best to get a wrench above the cross member to hold the nut in place when tightening the bolt!
    IF it's not tightened, try that first...without going crazy and stripping it.
    (***I'm assuming you went with a quality kit that came with some grade 8/ hardened bolts???)
    IF it's already tight, then try to loosen and retighten the mounting bolts.
    Get a good jack. Loosen all the mounts. Back the bolts out slightly where the diff spacers are. Loosen the rear mounts, then re-tighten...starting with the bolts with spacers, then back and forth with the rears, evenly.
    Good luck! :thumbsup:
    UTTundra and 15whtrd[QUOTED] like this.
  17. Apr 3, 2019 at 12:40 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    @Jebell4747
    Another question and thot....
    What size lift do you have?? (sorry if I missed it somewhere).
    Just judging by the pics, doesn't seem like anything to high??
    IMO, a diff drop is not needed for anything under 3" lift. Even then, if you have OEM suspension, a 3/4" spacer is enough. For 3-5ish" lifts, I'd def recommend doing the drop. Also, with any aftermarket suspension (coilovers, uca's) you might be better using a 1" spacer, which is what it looks like you currently have.
  18. Apr 3, 2019 at 12:46 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    What the hell am I looking at? :anonymous:
  19. Apr 3, 2019 at 6:49 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Well welcome to the party. Diff arm not seating properly when tightened fully.
    BTBAKER[QUOTED] and 15whtrd like this.
  20. Apr 3, 2019 at 7:25 PM
    Jebell4747
    2018 Tundra TSS
    Thanks guys. I have another shop that’s going to take a look but it’s going to be the 18th before they can check it. I was going to take off and donut myself but I can’t get off until 27th..
  21. Apr 4, 2019 at 12:54 PM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    That looks like more than 1" to me. I just did this on my '19 Platinum with a 3" lift up front and my 1" spacers sit square on the diff. Can you measure the spacer to see how thick it is? My guess is that if it's thicker it just won't sit square.
  22. Apr 4, 2019 at 2:52 PM
    Jebell4747
    2018 Tundra TSS
    It’s 1”. Measureb last night. I had the same thought.
  23. Apr 5, 2019 at 6:19 PM
    Jebell4747
    2018 Tundra TSS
    Well I took off work tomorrow and plan on tearing into it. I’m going to jack it up, loosen the UCA, sway bar/ diff drop and let the truck down and retighten the bolts. I’m almost 100-% positive it’s happening with the spring compresses just a little. I’m open to any advice !
  24. Apr 5, 2019 at 6:27 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Loosen the rear bolt if it doesn’t sit right. I watched a couple videos because I still need to do mine. It’s on hold though because I had back surgery. But a few guys had to loosen that rear bolt to get the spacers to tighten correctly.
    15whtrd likes this.
  25. Apr 5, 2019 at 6:36 PM
    Jebell4747
    2018 Tundra TSS
    Thanks!!!! I’m not sure if that’s causing my popping sound coming from the same side but I’m gonna find out that too lol
  26. Apr 6, 2019 at 6:28 AM
    Jebell4747
    2018 Tundra TSS
    Well I think I found my “popping “ also. The pass diff drop moved about 1/4” with the jack under if before the truck did. Bolt is tight as hell though. I know the bushing will give some but not 1/4”.
  27. Apr 6, 2019 at 7:00 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Think they cross threaded the bolt in there?
  28. Apr 6, 2019 at 7:10 AM
    Jebell4747
    2018 Tundra TSS
    It doesnt look like it but I still had weight on the truck so the bolt might have been in a bind. I’m about to put it on jack stands and drop the diff. I hope they didn’t because there’s no where to get another bolt around here
  29. Apr 6, 2019 at 7:17 AM
    Squatting Pigeon
    Holden
    North Texas
    Yeah hopefully they didn't cross thread it and just hit it with the impact...
    Fingers crossed it loosens up when you get the wait off of 'er!
  30. Apr 6, 2019 at 8:54 AM
    Jebell4747
    2018 Tundra TSS
    Guys should there be a large flat washer on the bottom of these diff bolts? I think that’s why the bolts are tight and it’s still sagging. They didn’t put the large flat washers back on and the bushings are being mashed.
