King 2.5 coilovers
Discussion in '1st Gen Tundras (2000-2006)' started by surfride, Apr 1, 2019.
  1. Apr 1, 2019 at 4:57 PM
    surfride
    surfride [OP] New Member
    I was recently installing some king 2.5 coilovers on my 2005 tundra single cab 4WD and broke off one of the top 3 bolts. I am wondering how safe it is to drive with just the two for a limited time and if anyone knows the dimensions so I can get a new one without having to remove the shocks twice.
  2. Apr 1, 2019 at 5:05 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    @surfride
    It's likely the bolts standard production 3/8"-16 x 1.00" Grade 8 hex head bolts. You could take one off the other side and walk it in to your local hardware store to find the correct size.
  3. Apr 1, 2019 at 5:06 PM
    Did you get the stud out of the bolt you broke? If not, shock removal time.
  4. Apr 1, 2019 at 5:07 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't recommend driving on two, you'll likely break another doing that. What I would do is remove one from the other side and take a drive (in another vehicle if possible) to Home Depot or such and match up and buy a replacement.
    TX-TRD1stGEN likes this.
