Best oil to use in Tundra w/ 150k miles on it
Discussion in '1st Gen Tundras (2000-2006)' started by PirateSteve, Mar 31, 2019.
  1. Mar 31, 2019 at 12:14 PM
    PirateSteve
    PirateSteve [OP] New Member
    2006 Tundra
    I have a 2006 Tundra w/ 150k miles on it, best brand oil to use... conventional or synthetic? My first Toyota and not sure what's best for it. Thanks for any help! -Steve
  2. Mar 31, 2019 at 12:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Welcome :hattip:
    Be prepared for an all out "I use brand x" responses based on little more than the motor still runs.
    That said, I run the Toyota yzzd3 filter because it's a little big bigger than the other that fits. For oil I have been running Mobil 1 synthetic for the last 9 years, usually the high mileage formula. I dont normally keep it more than 5k miles before changing. I get it at Walmart in the 5 quart jugs for about $28 each.
    A lot of the driving I do is short trips, that isn't great for my oil and it shows when I change it. I think about changing it at around 4k miles just because I'm the type to set my alarm at 5am and hit snooze until 5:45 before waking up.
  3. Mar 31, 2019 at 12:53 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Use what the previous owner was using...seems to have done OK by him.
    Patriot and Rex Kramer like this.
  4. Mar 31, 2019 at 1:17 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Mobil1 from Wallywurrrl for about $25 for 5 quarts here. I just made the switch to Mobil1 Extended Performance Full Synthetic last year and its created a little weeping around some gaskets. I switched to standard Full Synthetic last month and the weeping has slowed. The weeping is like a glaze than it is a drip. Its like the synthetic molecules are perfectly aligned and squeeze through.
    Next change will be to the Mobil1 High Mileage Synthetic.
    Prior, the 02’ was running on Whatever Brand a Shop had ‘Synthetic Blend’. I think the Mobil1 has quieted the engine and the detergent action cleaned out a lot of the sludge based on the last change.
    Hoping the ‘High Mileage’ formula conditions the seals back as advertised.
  5. Mar 31, 2019 at 1:25 PM
    PirateSteve
    2006 Tundra
    Thanks for answering! I was concerned with going from conventional to synthetic or vice versa... because I have no idea what's in there now to be honest. Was looking for a solution that would be ok for either scenario. Bought the truck used so unable to ask what oil was used before. Tuck runs well, want to keep that way of course.
  6. Mar 31, 2019 at 6:32 PM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I also am a Mobil 1 full synthetic high mileage user. It’s what I use in all my vehicles and have for years. It has seemed to work well for me.
    I would go full synthetic if I were you. I’ve heard it said that if full synthetic is used, you don’t want to switch back to conventional. But if conventional is used, it’s fine to begin full synthetic. I’m not an expert by any means, but I believe that is kind of the rule with engine oil.
    If I’m wrong, please somebody chime in! :thumbsup:
    Congrats on the Tundra by the way!
  7. Mar 31, 2019 at 8:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    mobil 1 full synthetic extended performance is all i run in all my vehicles.. my 06 avalon, 01 taco, 06 corolla with 750k on it... its good oil and its cheap at walmart.
    OEM filters because theyre cheap and are really well made
  8. Apr 1, 2019 at 8:16 AM
    TravisT4
    TravisT4 New Member
    Travis
    Hartland WI
    2006 Tundra Double Cab TRD
    Costco always has good prices on Mobil 1 full synthetic so that is what I use for my vehicles. For a filter I usually go with a WIX or the Fram Gold. The cheap Frams are no good but from what I have read the high end ones are pretty good and I really like the bed-liner type coating they put on it, it makes it really easy to get a grip on.
  9. Apr 1, 2019 at 4:44 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Are we the same person?
  10. Apr 1, 2019 at 4:46 PM
    empty_lord
    05 rollover special
    Hmm I do the same shit
    PirateSteve[OP] and Darkness like this.
  11. Apr 1, 2019 at 4:48 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Million mile tundra used the Toyota/Mobil 1 and Denso filters..good enough for him, good enough for you.
  12. Apr 1, 2019 at 4:53 PM
    Fred
    Hand Protectors
    $10 difference in Wally v. Big Gurl from Brasil.
    $25 and $36, respectively.
  13. Apr 1, 2019 at 4:56 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Synthetic, always synthetic. Full synthetic only.
    Personally I use Amsoil in everything that it makes sense. From engine to differential, except for transmission (Mainly due to the Jeep transmission I had previously and the effort it took to move it over.) My current jeep that I bought used I recently moved to Walmart SuperTech as it burns oil and isn't worth the cost of a better oil at this point. More expensive oils will have more detergents and/or anti-wear additives.
    Maybe even more important than the oil is the filter. Always run a quality filter it will help pull the wear particles out of your oil. I run Amsoil or wix depending on the application.
    Edit: bobistheoilguy.com is a great resource
  14. Apr 1, 2019 at 5:12 PM
    Fred
    Hand Protectors
    lc69hunter likes this.
  15. Apr 2, 2019 at 6:05 PM
    JQ3
    JQ3 2005 XSP rwd
    I don’t know if it’s “the best”, but I bought 6 qts of Amazon Basic 10W 30 synthetic blend for $18 along with 6 Toyota oil filters. I believe the filters were $23.
  16. Apr 2, 2019 at 6:12 PM
    koditten
    Kirk
    Midland of the Mitten
    My 1st Gen went 300k on 5W-30 Walmart oil.
    Changing your oil is more important than the type. Tow alot? Change it more often. Dusty roads? Change it more often.
    Highway driving, change it twice a year.
    Synthetic is good oil, but it's not worth the extra money.
    irhunter likes this.
  17. Apr 2, 2019 at 11:28 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Another oil thread....:rofl:...like someone said use whatever the previous owner was using. It obviously worked well. :thumbsup:
    koditten likes this.
  18. Apr 3, 2019 at 5:27 AM
    Fred
    Hand Protectors
    Key take aways:
    1) Use the proper viscosity as spec’d for the vehicle.
    2) Changing often is better than not enough, or dino vs. syn.
    3) Heavy Service considerations defined as towing, city driving, and extreme high temps driving.
    Filthyphil and JohnLakeman like this.
  19. Apr 3, 2019 at 5:30 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Just top it off if/when it gets low. A little fresh oil is always good. :thumbsup:
  20. Apr 3, 2019 at 6:49 AM
    minter66
    minter66 2007 TSS CrewMax
    Isn't the recommended viscosity like 0W-20?
    Any issues running 5W or 10W?
  21. Apr 3, 2019 at 6:58 AM
    empty_lord
    05 rollover special
    First gen tundras are 5w-30
    2nd gens are mostly 0w-20 or 5w-20
    H1N1777 likes this.
  22. Apr 27, 2021 at 8:53 AM
    Bgkahuna11325
    Bgkahuna11325 New Member
    Gene
    2011 Toyota Tundra SR5 Crewmax
    Noticing some slight valve clatter when the engine was cold, I began using Castrol Magnatec. No more valve clatter and better adhesion to reduce wear. Usually get it at Walmart (5 Quart jugs) for around $20.00. My 2011 Crewmax has 90,000 miles and runs great! Been using Castrol Magnatec since 40,000 miles.
  23. Apr 27, 2021 at 9:08 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    The ol'xoNR61O.jpg oil thread
  24. Apr 27, 2021 at 11:08 AM
  25. Apr 27, 2021 at 11:10 AM
    You posting about other gens in my 1st gen paradise? And for your first post? You'll fit in fine here.
  26. Apr 27, 2021 at 11:42 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My 2002 has 174,000 miles and my 2007 has 299,000 miles, and both of them are treated to non-synthetic oil. I don't know, and don't care what brand it is, but I know it's whatever the dealership uses.
    toyofan87 likes this.
  27. Apr 27, 2021 at 12:34 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Besides bobistheoilguy, I also refer to this:
    https://540ratblog.wordpress.com/
    And pqia.org
    My truck used dealer oil changes until I got it. I finally changed my oil after a few months, using a Toyota d3 filter and Quaker State 5w-20 UD synthetic.
    The standard Mobile 1 5w-30 in the silver bottle/lid is a very good oil. (Better wear numbers at 118k psi than the Extended Protection 88k psi or high mileage 83k psi.)
    I also like the Mobile 1 0w-30 (at 115k psi).
    5w20 Quaker State, ultimate durability synthetic
    121,396 psi
    @100°C = 8.43
    Cold = 3886
    Tbn = 9.16
    5w30 Quaker State, ultimate durability synthetic
    133,125 psi
    @100°C = 10.19
    Cold = 3996
    Tbn = 7.99
    0w20 mobil 1 extended performance syn
    100,229 psi
    @100°C = 8.8
    Cold = 4182
    Tbn = 9.53
    5w30 mobil 1, synthetic
    117,799 psi
    @100°C = 11.0
    Cold = 3937
    Tbn = 9.1
    0w30 mobil 1, AFE synthetic
    115,635psi
    @100°C = 10.07
    Cold = ?
    Tbn = ?
    onesojourner likes this.
  28. Apr 27, 2021 at 2:06 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Have any of you bought the box of mobil1 oil from walmart? It's pretty much like a box of wine. It priced out to basically get 2 quarts free compared to buying jugs.
  29. Apr 27, 2021 at 2:13 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    up to 230k mine had dealer changes then about 50k of VIP.
    I've been running mobile 1 synthetic high mileage (10k) with OEM filter since about 295k changing 5-7k intervals
    GIN•OKUMA likes this.
  30. Apr 27, 2021 at 2:19 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Others have said all there is to say, but in the interest of another visible vote to help:
    Mobil 1 5w30 Full Synthetic High Mileage Extended Performance, silver jug with gold stripe on the label. Wallyworld $24.95 for 5 qt a few days ago. The few dollars difference with cheaper stuff isn't worth my peace of mind.
    It's supposed to be good for 15,000 miles, which is 10,000 more than I was used to, so I aim for 7000-10,000 intervals. I either drive short distances in a city, or dusty dirt roads in the desert. No towing though.
    Toyota YZZD3 filter, I think I saw a 6-pack on Amazon, but in any case pretty cheap.
    Not sure how much my vote counts, though, since I arrived at those decisions by SEARCHING THE FORUM <ahem> searching the forum to see what has already been said on the topic. I don't have any of my own expertise to add.
