Coasting in Neutral question
Discussion in '2.5 Gen Tundras (2014-2021)' started by GlobalGuy, Apr 1, 2019.
  1. Apr 1, 2019 at 6:06 AM
    GlobalGuy
    GlobalGuy [OP] GlobalGuy
    Frank
    Buffalo, NY
    2018 Silver TRD Double cab
    FYI, I'm not a mechanic and don't play one on tv. I have been coasting in neutral to red lights and putting it in neutral while waiting for red lights to turn green. There has been a pretty good bump in MPG. I'm thinking that in neutral there is no load on the engine which is increasing the MPG. My concern is whether or not this could eventually cause harm to the tranny? I know my brake wear will increase but, my last Tundra I had for 10 years, I only changed the front pads twice, rears...never, they hold up well. I'm going to experiment on my next full tank of gas and will post my findings.
  2. Apr 1, 2019 at 6:17 AM
  3. Apr 1, 2019 at 6:39 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    JohnLakeman and Black Wolf like this.
  4. Apr 1, 2019 at 6:43 AM
    Yep....post your findings.
  5. Apr 1, 2019 at 6:47 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    My driveway is about a quarter mile long and almost all downhill when leaving the house. I coast down in neutral when leaving the house but I don't do it to save gas. I do it because the engine is still in its warm-up period where it's running a little fast, and I don't need the engine pushing me down the hill. Out on the public roads, I never do it. It won't save you gas.
    Now at long red lights, I have done it. I don't know if it's saving me gas or not, but sitting there at a light sometimes you can tell the engine is under load. Pop it into neutral and it will no longer sound that way. I figure doing that now and then can't hurt.
  6. Apr 1, 2019 at 7:17 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Try down-shifting the transmission to slow down, that cuts fuel entirely.
    Black Wolf and Samoan Thor like this.
  7. Apr 1, 2019 at 7:20 AM
    That's what I do. I'd never use neutral. Never even occurred to me to ever do it.
  8. Apr 1, 2019 at 7:24 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I found significantly increased fuel economy when I stopped obeying red lights and stop signs. Plus I reach my destination faster.
    :quickdraw:#thuglife
    I would have some concerns over the wear on the converter and the shock load from going neutral to drive when the light becomes green, if not at a stop.
    Celt, rsgt, Wrongside and 7 others like this.
  9. Apr 1, 2019 at 7:39 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  10. Apr 1, 2019 at 7:44 AM
    YEP
  11. Apr 1, 2019 at 7:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You see/read the damnedest things on the internet. o_O
    If I remember my old driver handbook correctly, it's against the law to coast your vehicle in neutral in Texas. But that law was probably written back in the day of Model As, REAL four on the floor, and flathead four under the hood too. :D
    Black Wolf likes this.
  12. Apr 1, 2019 at 8:20 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Wouldn’t coast far in TX anyway. Lol
    bvia, plumber802, Ostrich and 2 others like this.
  13. Apr 1, 2019 at 8:23 AM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    When I got my Tundra, I found that rules of the road were more "suggestions" to me. Plus my tires do say "Dick" on them (I have Dick Cepek tires), so my wife says it fits my new driving style... :benchpress:
  14. Apr 1, 2019 at 8:31 AM
    JohnLakeman
    Many Texans don't even know that the tail bone of the Rockies (Franklin Mountains) is in far west Texas. You can coast quite a few miles coming off the peak on Woodrow Bean Transmountain Road. Plus, there's enough hills near me to make my Tundra dither about what gear it wants to select. :D
  15. Apr 1, 2019 at 9:12 AM
    TXMiamiFan
    Jose
    Yep, manual transmission for sure. Also apply the e-brake so I can rest both feets at a red light.
  16. Apr 1, 2019 at 9:18 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    Ram does this now with the etorque
  17. Apr 1, 2019 at 9:18 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    one time I filled mine up drove it home and parked it for a week while I was away for work. so far that's yielded the highest mpg,
    If you are severe clear I guess it doesn't hurt, however if you need to perform an evasive maneuver you may just find yourself in neutral and having to add shifting to the situation.
    bvia and JohnLakeman like this.
  18. Apr 1, 2019 at 9:43 AM
    JohnLakeman
    My wife's Insight automatically applies the electric PB every time the car comes to a complete stop. It's a great feature for stop lights at the top of hills. She loves it. Something else to want on the next Tundra generation. :D
  19. Apr 1, 2019 at 10:06 AM
    PA452
    PA452 New Member
    No offense intended, but that's exactly the type of unnecessary gingerbread I don't want on my Tundra.
  20. Apr 1, 2019 at 11:54 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I almost bought a set of them but pictured my buddies saying "he rides on dicks" and went with Mickey Thompson instead
    :militarypress:
    Black Wolf, Ostrich and JohnLakeman like this.
  21. Apr 1, 2019 at 12:06 PM
    So do a lot of Ford models.
  22. Apr 1, 2019 at 12:08 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't mind picking up a Ford model or two.
  23. Apr 1, 2019 at 12:09 PM
    Grumpy Uncle
    Pat
    CO
    I just bat wing it!!!
    Black Wolf, Bear, 15whtrd and 2 others like this.
  24. Apr 1, 2019 at 12:16 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The goat! He did the goat! :rofl:
  25. Apr 1, 2019 at 12:18 PM
    Grumpy Uncle
    Pat
    CO
    The goat is to be used for shifting!!:D:D
  26. Apr 1, 2019 at 1:07 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I’ll pop it in ‘N’ when stopped at a long light. RPM goes up from 550 up to 700 on the shift from ‘D’ to ‘N’ (at a dead stop).
    RPM’s go up 150, but the strain on the transmission goes down.
    Shifting on a coast is not worth it around here.
    15whtrd likes this.
  27. Apr 1, 2019 at 1:19 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah if I’m sitting idle long enough, I’ll pop it in neutral. Kind of something I picked up from driving a manual along with automatic transmissions in old carbureted cars.
  28. Apr 1, 2019 at 1:25 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  29. Apr 1, 2019 at 1:27 PM
    15whtrd
    15whtrd Mr. Blonde
  30. Apr 1, 2019 at 1:30 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    DAMMMIT !! now I'll always think of that. if it makes you feel any better, Cepek is owned my Mickey Thompson..
    Darkness[QUOTED] and JohnLakeman like this.
