Turn Signal outage?
Discussion in 'Lighting' started by apwisher, Apr 1, 2019.
  1. Apr 1, 2019 at 8:15 AM
    apwisher
    apwisher [OP] New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    The other day I was driving home and got the rapid flash on my left turn signal, so I figured I had a blown bulb. Got home, checked it and yes, front left not working. went inside ordered new bulbs. Next day I go out and now the turn signals all work. Any Ideas?
    I have after market headlights (which use the factory socket and bulb) and I did some wiring at the left rear for canopy and backup camera. None of those operations used the turn signal wires. It hasn't happened since.
  2. Apr 1, 2019 at 8:54 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I have had this issue on and off. Mine is the pins in the harness right at the light. Mine are currently working after playing with the wires but I have not found a permanent fix.
  3. Apr 1, 2019 at 10:04 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've had instances where the bulb stops working, then you hit a bump and the filaments make contact again and work for sometimes days or sometimes months.
