What's the best air compressor for off-road use
Discussion in '2.5 Gen Tundras (2014-2021)' started by vanthesupreme, Mar 27, 2019.
  1. Mar 27, 2019 at 12:50 PM
    vanthesupreme
    vanthesupreme [OP] I'm Batman
    OKlahoma
    2014 Tundra
  2. Mar 27, 2019 at 12:57 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    FWIW
    I ran the beefier version of the Viair (450P) on my Raptor... and it was a pile of junk. When it worked, it took a day and half to air up my 35s from 15psi to 35. When it worked. More often, it wouldn't and/or shut off due to overheating. You get to stand there and wait a half hour for it to cool down and hope it comes back.
    I say hope because mine died one day, forcing me to burn a ton of rubber off my tires on the pavement as I limped 10 miles to a gas station. I later took it apart to try and fix it (we rebuild pumps at my shop), and found it looks like they use about the cheapest parts internally they could find, and the seals might as well be non existent. Will not buy one again. (To be fair, ambient was 90deg in the desert, which is where I wheel 99% of the time. Heat is murder on these things).
    No experience with the Smittybuilt; the experience with the Viair was enough.
    You asked about the "best". Viair and the like are not the "best". Not by a mile. Its a CO2 tank or ARB 100% duty cycle compressor for me from now on.
    Edit: By the way, make sure you understand "duty cycle" as it applies to these. The Viair you listed is rated at 33%. Roughly speaking, this means within a 10 minute window, you can expect to use it for 3 minutes, and wait for it to cool down for 7. The Smittybuilt doesn't even list duty cycle in the conventional way, which would make me think its rated even less.
  3. Mar 27, 2019 at 1:11 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Iv been very happy with my 400p from Viair,
    Their customer service sucks though.
    I'll probably make the switch to a bullydog pump end of the year.
    Marty McFly likes this.
  4. Mar 28, 2019 at 6:11 AM
    epicxcrider
    epicxcrider New Member
    Eastside Seattle
  5. Mar 28, 2019 at 6:51 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    I have the Viair 300p and have used it several times without issue.:confused:
  6. Mar 28, 2019 at 6:54 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I have the smittybilt one posted above. Love it, waiting on bracket to come so I can mount it under the hood. Came with a nice carrying case to hold everything too.
  7. Mar 28, 2019 at 10:13 AM
    tbell18
    tbell18 New Member
    Thomas Bell
    2019 Tundra TRD Pro
    I've got the high performance arb compressor on my Tacoma and I've had great luck with it so far.
    Ronster and IndianaGeologist like this.
  8. Mar 28, 2019 at 10:19 AM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
  9. Mar 28, 2019 at 10:41 AM
    Marty McFly
    Morty McBoonJug
    I also have a Viair 450 100% duty cycle. It’s not the fastest, but i haven’t had any issues. If I had the money, I’d get a C02 but they are pricey.
  10. Mar 28, 2019 at 10:57 AM
    timsp8
    NY
    I have a smittybilt 5.65 Cfm. Used it for my truck and wife’s car back to back and it didnt give out. Have had it for years and no issue. Puts out a lot of air.
    What bracket did you get?
  11. Mar 28, 2019 at 11:55 AM
    Berdine
    Frank
    Binghamton, NY
    Just ordered a sharkbite motorsports one
  12. Mar 28, 2019 at 2:52 PM
    timsp8
    NY
    And the smittybilt fit? I just emailed them yesterday about one. Figured you would need a lower profile one like the arb.
  13. Mar 28, 2019 at 3:55 PM
    Berdine
    Frank
    Binghamton, NY
    Haven't got it yet. The smittybilt is bigger, and mounting point wider. Went with the dual mount
  14. Mar 30, 2019 at 8:31 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
  15. Mar 31, 2019 at 3:26 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    I have a Viair 300P. Bulletproof so far.
  16. Apr 5, 2019 at 10:13 AM
    vanthesupreme
    OKlahoma
    2014 Tundra
  17. Apr 5, 2019 at 11:43 AM
    epicxcrider
    Eastside Seattle
    I had one of these before my Viair. It worked fine but eventually I wore it out. I hated the air chuck and it was loud AF and got really hot which is what kills these things. Oh, the power cable melted once from normal use but the company sent a replacement.
    The Viair is much higher quality. If this is for convenience or occasional use I think the masterflow is fine and was actually faster than the 450p. For regular wheeling or expedition use I would not depend on the masterflow.
  18. Apr 14, 2019 at 6:44 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Anyone seen the one that NSV just put out? Or am I late to the party in seeing that? Popped up on my IG as an ad. Looks like it goes under the rear passenger seat. Wanna say it was sub $400.
  19. Apr 14, 2019 at 7:29 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    I've used the Viair 300P for a few years and have no complaints. I just use it a couple times a year when I air up after a week on the beach, so it hasn't worked very hard. Its filled up the 275s on my Tundra and my wife's Jeep and saved me a long wait at the public compressor without fail. I'd buy one again.
  20. Apr 15, 2019 at 8:15 AM
    Cement
    Cement ...
    FWIW I used my ARB twin this past weekend to fill two trucks from 15ish to 35 and 45 respectively and the thing didn't miss a beat. We were done in maybe 15 mins total? My buddy was so impressed (her being used to a Viair) she's got one on her wish list now.
  21. Apr 15, 2019 at 8:51 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
  22. Apr 15, 2019 at 1:32 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
  23. Apr 9, 2021 at 1:41 PM
    markneustedt
    markneustedt New Member
    Mark
    California
    2020 Toyota Tundra
    Thanks for this post Cement! I think this compressor Viair (450P) is quite expensive. Obviously, if you ask me, Smittybilt (5.65CFM) won't be worse, it'll be even better even for less money.
  24. Apr 9, 2021 at 1:44 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    BlueRibbon4x4 and AggiePhil like this.
  25. Apr 9, 2021 at 2:03 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  26. Apr 9, 2021 at 2:12 PM
    AggiePhil
    College Station, TX
    PowerTank CO2 tank.
  27. Apr 9, 2021 at 3:08 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  28. Apr 9, 2021 at 3:41 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
  29. Apr 9, 2021 at 4:27 PM
    Kelvin
    Kelvin New Member
    My 450P can fill up four 35’s from the same starting psi without issue and without breaks other than moving to a new tire :notsure:
    That thing is probably barely fit to fill up the tire on a Prius.
    If you’re going with 35’s like most do, you’ll need a bigger compressor. You don’t want to be sitting in the sun waiting 30 minutes for an inadequate compressor to get you up to 30 psi. Also if it overheats that’s going to be more waiting.
    Remember the phrase “buy once cry once”.
  30. Apr 9, 2021 at 4:58 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Understood. And fair enough. However, being a chinese product, I would likely cry twice. For higher prices, I'd rather buy American, what's a good one? I haven't been able to find one.
    xuy and NewImprovedRon like this.
