  1. Mar 29, 2019 at 5:10 PM
    #5461
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Kmc krüe
    I wish mine were 17x9 instead of 16x8
  2. Mar 29, 2019 at 5:10 PM
    #5462
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Got a deal I couldn’t pass up on these Cooper STT Pros. 295/70/17s. (33.57”)
  3. Mar 29, 2019 at 5:19 PM
    #5463
    Casper421
    In the woods
    06 DC
    Looks bad ass! I’ll patiently wait for your review of the pros.
    Have you always had that love tap on the rear passenger door or was that from a recent trip?
    Rheywood456[QUOTED] and lsaami like this.
  4. Mar 29, 2019 at 5:27 PM
    #5464
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    I remember that truck, loved the way it looked at a distance, I'd be happy with the color, not the texture. If I were to turn away from the DARK side, it would be either olive or some a khaki/desert sand color.
    Darkness[QUOTED] likes this.
  5. Mar 29, 2019 at 5:39 PM
    #5465
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I’ve had that for about a year. We slid down a hill into a tree... used to be much worse but we push it out as much as possible.
  6. Mar 29, 2019 at 5:44 PM
    #5466
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Heck ya! :cheers: Got a deal on these preowned and I love the wheels.
  7. Mar 29, 2019 at 5:47 PM
    #5467
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Needed to do a better photo that shows how nicely these tires fill the wheel well!
  8. Mar 29, 2019 at 6:54 PM
    #5468
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Driver side cam seal done. Starting on passenger side today.
    Valve covers are lookin great
  9. Mar 29, 2019 at 9:31 PM
    #5469
    empty_lord
    05 rollover special
    Well pumps in, new pulleys are in, driver side is complete. Passenger side is apart, going to take the front cap to work and run it through the parts washer (pass side was leaking really bad).. starting to slowly get done
    NUDRAT, Darkness, hammeron and 8 others like this.
  10. Mar 30, 2019 at 11:33 AM
    #5470
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    Got the parts in to fix the truck. Ebc rotors and green stuff pads as well as some blue painted oem calipers. I didn't need calipers but mine are rusted so why not? The truck should be on all 4 tires Monday.
  11. Mar 30, 2019 at 11:46 AM
    #5471
    because_wumbo-truck
    Jon
    Houston, Texas
    your converting the rear to disc brakes?! Nice.
  12. Mar 30, 2019 at 12:13 PM
    #5472
    Outbound
    Aaron
    Northern Alberta
    Did an oil change today. Noticed a red fluid on my steering rack. Traced it back to here.
    What is this, why is it leaking, should I be worried?
    NUDRAT likes this.
  13. Mar 30, 2019 at 12:16 PM
    #5473
    Professional Hand Model
    Fred
    Hand Protectors
    You have the red coolant?
    Outbound likes this.
  14. Mar 30, 2019 at 12:21 PM
    #5474
    Swalters
    Sam
    Arizona
    No, fixing this mess
    Jerry311SD likes this.
  15. Mar 30, 2019 at 12:23 PM
    #5475
    Outbound
    Aaron
    Northern Alberta
    EDIT: Yes, I have red coolant. That wire going into the connection where it's leaking from is my block heater cord. I'm guessing that the seal around the block heater connection is kaput. I'll have to drain all the coolant to replace it I think.
    Lovely. Another thing to the to do list. It's not my day today. Starting to think I should buy a newer Tundra so I don't have to spend my weekends doing maintenance. LOL
  16. Mar 30, 2019 at 1:14 PM
    #5476
    widget08
    widget08 New Member
    05 Tundra 4WD TRD Off-Road, 05 Sequoia LTD
    None, yet.
    Had my 05 detailed yesterday and I did my headlights today.142EEF46-EB80-4378-BB83-48752BEB387D.jpg2C697CA8-0144-4857-BAD9-71F91B9FC059.jpg
    speedtre, NUDRAT, Jerry311SD and 2 others like this.
  17. Mar 30, 2019 at 1:21 PM
    #5477
  18. Mar 30, 2019 at 1:30 PM
    #5478
    Outbound
    Aaron
    Northern Alberta
    1st Gen is the Best Gen right?
  19. Mar 30, 2019 at 1:37 PM
    #5479
    because_wumbo-truck
    Jon
    Houston, Texas
    Be[1]st Gen
    BestGen, FirstGenVol, NUDRAT and 6 others like this.
  20. Mar 30, 2019 at 2:30 PM
    #5480
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    What is the story on this?
  21. Mar 30, 2019 at 2:42 PM
    #5481
    Swalters
    Sam
    Arizona
    I was driving 50mph and my wheel flew off. All 6 lug nuts came off at the same time. Either we forgot to torque them down 2 weeks before when we last worked on it or someone tried stealing the wheel.
  22. Mar 30, 2019 at 3:30 PM
    #5482
    empty_lord
    05 rollover special
    Still odd how that happened. Usually loose lugs just sheer the studs off. Yours were amazingly intact
  23. Mar 30, 2019 at 3:38 PM
    #5483
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Removed sway bar, bushings, and end links. The bushings were shot. The end link bushings were virtually non-existent.
    Any suggestions or first hand experience with aftermarket end links? Sway bar bushings? Poly or rubber? Idk if I’ll spring for a Hellwig up front, I will definitely at some point at a Hellwig to the rear though! I’m leaning towards Moog if I go rubber. Or TRW end links if I go poly. And I’m not sure about the poly sway bar bushings. I like the stiffness but don’t want consistent squeaking.
  24. Mar 30, 2019 at 3:41 PM
    #5484
    Swalters
    Sam
    Arizona
    Yep, I don't understand :confused: oh well. It should be fixed soon
  25. Mar 30, 2019 at 3:45 PM
    #5485
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I like the AC Delco Pro better than Moog myself, all the Moog parts I've got in the last 10 years have been crap.
  26. Mar 30, 2019 at 3:45 PM
    #5486
    empty_lord
    05 rollover special
    That’s all that matters. It could be way worse! (I would suggest keeping an eye on that lower ball joint because it got quite the shock when it hit. I’ve seen them fail shortly after stuff like that happens)
  27. Mar 30, 2019 at 3:46 PM
    #5487
    empty_lord
    05 rollover special
    Never had luck with moog in jap cars. But better that stock on chevys!
    00TundraZ likes this.
  28. Mar 30, 2019 at 4:57 PM
    #5488
    Swalters
    Sam
    Arizona
    Lbj has to be replaced. I rode on the rotor and the bolt in the lbj for a few hundred feet. So it's all ground down
  29. Mar 30, 2019 at 5:01 PM
    #5489
    empty_lord
    05 rollover special
    Yea, that’ll do it. Lol
    Swalters[QUOTED] likes this.
  30. Mar 30, 2019 at 5:34 PM
    #5490
    Fred
    Hand Protectors
    Performed three things today on the 02’.
    1) Buffed out the body repair with polish and then put on a coat of wax on that area.
    2) Did a Reverse Flush on the heater core. The 02’ has the OEM ‘heavy duty heater’ and it still had great output. Saw a vid on the core flush and decided to try. About a half quart of coolant drained out that looked normal. I dumped that and then proceeded to flush another half quart till the fluid looked opaque white. The fluid did not look ‘dirty’. It had an opaque white clearness to it. Not see through. Plenty of youtubes on the subject. Suggest Chris ‘Nice Hands’ Fix to watch.
    Man! You can cook an egg on these vents again. I remember it like this when it was brand new. Huge.
    3) Had about 10k on the current fluid and have been reading that the older a vehicle gets that you should reduce your ALL change intervals. Did a double drain and refill of about 6 quarts per cycle. Drained 6. Filled 6. Drive and repeat. Total coolant used was 12 quarts. Peak ‘Longlife’ is on sale for $9.99 a gallon at Auotzone right now. A steal.
    The 02’ specs say the total coolant capacity is 12 quarts. I was only able to drain about 6 quarts at one time via the rad plug on drivers side.
    Can anyone confirm/explain how to drain all 12 quarts out at one time?
