Eibach fixed 3inch vs billy 6112s
Discussion in 'Suspension' started by Crewmax34, Mar 29, 2019.
  1. Mar 29, 2019 at 7:40 AM
    Crewmax34
    Crewmax34 [OP] New Member
    what would be the best choice for a daily driver? Obviously there is a difference in amount of lift up front but was just trying to get some ideas from others. If I went with the billy 6112s I would get the entire assembly spring and all set to the top setting and the eibach would be at 3 inches of front lift.
  2. Mar 29, 2019 at 7:47 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No experience with the Eibach. But I love my 6112s for daily driving. Very comfortable and controlled in my opinion. The 6112s are certainly more heavy duty than the Eibachs too with a 2.6” vs Eibach 2” shock body and a 7/8” piston rod vs Eibach 5/8”.
    Broncobroke and equin like this.
  3. Mar 29, 2019 at 8:07 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Would you say the 5100's are about the same as the Ebachs? Or with the combination of the new spring makes Ebachs better?
  4. Mar 29, 2019 at 9:48 AM
    Danman34
    Danman34 New Member
    Danny
    I would say the Eibach with the new spring will give you a better ride. Ride starts to diminish on 5100s from Adding more preload as you go up in settings.
  5. Mar 29, 2019 at 11:42 AM
    Crewmax34
    Danman34 are your 6112s on the top setting and what is your set up ie rear lift tires and wheels
  6. Mar 29, 2019 at 12:25 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    ive heard that the Toytech/Eibachs are rebranded 5100's with Eibach coils. never seen anything definitive but i guess @Toytec Lifts could chime in.
  7. Mar 29, 2019 at 12:51 PM
    Danman34
    Danman34 New Member
    Danny
    1.9”. Actually sitting at 2.25” higher. 5160s rear with 1” on toytec shackle with new poly leaf bushings. I have exactly 1” of rake. Currently on stock wheels and tires but will be going with 285/60/20 soon with a +20 wheel.
  8. Mar 29, 2019 at 12:52 PM
    Danman34
    Danman34 New Member
    Danny
    Pictures.
    TokerJoker likes this.
  9. Mar 29, 2019 at 12:55 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    This for sure...well said.
    Danman34[QUOTED] likes this.
