Ball Mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by daven, Mar 28, 2019.
  1. Mar 28, 2019 at 11:13 AM
    daven
    daven [OP] New Member
    2019 Tundra Double Cab Limited
    Any recommendations on a good ball mount for 2019 DC? Thanks, D.
  2. Mar 28, 2019 at 4:21 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    is your truck lifted? what are you towing?
  3. Mar 28, 2019 at 4:46 PM
    What type of ball are referring to?
  4. Mar 28, 2019 at 4:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    I bought this one from B&W. Awesome hitch, but a little pricey compared to a fixed dropped ball mount.
  5. Mar 28, 2019 at 4:57 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s nice!
  6. Mar 28, 2019 at 5:04 PM
    AZTundra
    Paul
    Phoenix, AZ
    I got it from Amazon last March for around $220. Three different size balls, adjustable, stow position, etc. Only complaint is the 3 pins they use.....2 for the height adjustment and 1 for rotating the ball. The pins use clips to secure them and there is nothing stopping someone from stealing the pins. I ordered 3 extra pins just in case, but have not needed them yet. As long as you use a locking main pin on the receiver no one can steal the hitch, but the pins are my worry, not that they would do someone any good, but ya never know.
    Here are the specs:
    • Fits standard 2" receiver hitch
    • Drop of 5 inches / Rise position is 5-1/2"
    • Eliminates the need for multiple ball mounts
    • Equipped with 2" ball and 2-5/16" ball
    • 10,000 gross trailer weight rating / 1,000 tongue weight rating
    15whtrd[QUOTED] likes this.
  7. Mar 29, 2019 at 5:42 AM
    daven
    I'm just looking for something general purpose,nothing fancy, or something I have top worry about being stolen. No lift on the truck, 20" wheels.
  8. Mar 29, 2019 at 6:14 AM
    15whtrd
    15whtrd Mr. Blonde
    You’re going to want to figure out the drop or rise you need so that your trailer sits level.
    Depending on the tongue weight and how much it’s going to make your truck squat needs to be a factor. You could just pick up a simple Reese hitch or something along those lines. Make sure the rating on it exceeds the trailer weight as well as the ball you’re going to use.
    You could get a 1” to 2” drop hitch and possibly even need to flip it over to get a rise for your trailer.
  9. Mar 29, 2019 at 6:23 AM
    neirbot
    neirbot New Member
  10. Mar 29, 2019 at 11:01 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
  11. Mar 29, 2019 at 11:07 AM
    TheBeast
    TheBeast The Beach
    yeah CURT makes good stuff.
  12. Mar 30, 2019 at 8:13 PM
    ToyLC
    ToyLC New Member
    I’ve got this one as well, it’s good to go.
    Capt J-Rod and AZTundra[QUOTED] like this.
  13. Mar 31, 2019 at 10:06 AM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I've got the B&W as well. Buy once, cry once. It has been awesome. I don't leave it in unless I'm towing. It would be pretty easy for someone to help themselves.
  14. Mar 31, 2019 at 1:47 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Gen y hitch, awesome product, USA made and customer service is top notch. Plus they have a lot of accessories you can add to it like a weight distribution kit if you tow a camper.
    https://genyhitch.com/
  15. Apr 25, 2019 at 8:12 PM
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
    Stumbled across these that are designed to replace the pins with keyed alike ones
    https://infiniterule.com/collections/2-2-5-tow-and-stow/products/61701
    AZTundra[QUOTED] likes this.
  16. Apr 25, 2019 at 8:18 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks! That's EXACTLY what I was looking for. Have you used these yourself? I'm going to measure the pins and make sure they will work. If they measure up correctly I'm going to order a set real soon!
  17. Apr 25, 2019 at 8:27 PM
    BeachTundra19
    Zak
    None Yet
    No I have not tried these or in fact had the opportunity to tow with my truck yet. Friday will be one week since I got it. Those say they are specifically for B&W hitches.
  18. Apr 25, 2019 at 8:32 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Just got a Reese 3” drop from Wally World to use on Sunday. Cost me $25. Typically I only have a hitch cover installed. For locking hitch pin I use this from Amazon. Long enough for the tundra hitch receiver. My old locking pin was just a hair too short.
    Motormic Trailer Hitch Lock Pin... https://www.amazon.com/dp/B07GB17XD7?ref=ppx_pop_mob_ap_share
  19. Apr 25, 2019 at 8:33 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Also if you get a longer locking hitch pin and get some rattle, I goto autozone and buy a little pack of thick O-rings. Slide a couple on either side to soften the blow.
  20. Apr 25, 2019 at 9:01 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, I did see they where they specifically mentioned fitting B&W, so there shouldn't be any issues.
  21. Apr 26, 2019 at 11:33 AM
    BeachTundra19
    Zak
    None Yet
    Right. If you do decide to get them let me know how they work out.
  22. Apr 26, 2019 at 11:41 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I just bought that same lock. Great quality.
  23. Apr 26, 2019 at 12:15 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I picked up these class iv mount and ball from Amazon. I had a couple class 3 but plan to rent a trailer and bobcat that pushes over 7000lb so this gives me more capacity than my class three and didn't break the bank. They have different drops if you plan to lift a bit.
    Just something to consider if want a cheaper option that covers more capacity than class 3
    https://www.google.com/url?sa=t&sou...FjAEegQIAxAC&usg=AOvVaw3440zhgi_Fqx7H0qSiB4NN
    https://www.ruralking.com/curt-ball...MIz-fP9Lru4QIVA0SGCh1fEwjPEAQYAiABEgLfYPD_BwE
