How to remove dry wax spots on plastic
Discussion in 'Detailing' started by T-Rex266, Oct 1, 2016.
  1. Oct 1, 2016 at 12:44 PM
    T-Rex266 [OP] Fuck Cancer Staff Member
    From when I waxed the truck. How do I get this out?
  2. Oct 1, 2016 at 12:54 PM
    Try Dawn soap and plastic bristle detail brush. I just had the same issue with some of my plastic.
    T-Rex266[OP] likes this.
  3. Oct 1, 2016 at 1:00 PM
    boloson
    boloson New Member
    Any automotive surface cleaner should get that off but it doesnt hurt & evetnually will fade out anyways. Try that 303 cleaner stuff
    T-Rex266[OP] and 15whtrd like this.
  4. Oct 1, 2016 at 1:07 PM
    15whtrd
    15whtrd Mr. Blonde
    I used 303 vinyl cleaner. But I've also heard something about peanut butter ha ha Ha .
  5. Oct 1, 2016 at 1:09 PM
    Maybe surface cleaner will work
  6. Oct 1, 2016 at 1:10 PM
    15whtrd[QUOTED] and Backslider like this.
  7. Oct 1, 2016 at 1:34 PM
    Backslider, TheBeast, Law323 and 2 others like this.
  8. Oct 1, 2016 at 1:42 PM
    boloson
    boloson New Member
    ^^ he's right. Only patriot accessories would clean up a truck nicely
  9. Oct 1, 2016 at 5:21 PM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Armor all
  10. Nov 23, 2016 at 4:50 PM
    briarpatch
    briarpatch New Member
    Believe it or not, a pink pencil eraser usually takes that off, although maybe not as well on textured trim. A little APC (I like Megs D101) and a (soft)toothbrush will usually do the trick. When all else fails, McKees makes a product specifically for this issue.
  11. Nov 23, 2016 at 6:59 PM
    joeguam
    joeguam New Member
    JOE
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
  12. Nov 23, 2016 at 7:43 PM
    Soapy water and a brush did the trick!
