need someone with fab skills...
Discussion in 'General Tundra Discussion' started by smslavin, Mar 28, 2019.
  1. Mar 28, 2019 at 2:42 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i need to make a mounting plate. not sure how to do this on my own. here's what i need.
    the decked drawers pose a problem. molle panels from rago and victory won't fit. this is about 10.5" tall and i need to fit the solar controller and blue sea deck panel. i'm thinking 2 bolts to tie it to the bed rail. for the bottom, i could probably get by with a small angle bracket in the middle to tie it to the deck. better option would probably by to fold the bottom behind and have a 1/4" lip that i could use to anchor the whole thing.
    this isn't difficult but i don't know what i need to make it happen. so, either i convince one of you to make it for me or, one of you tells me what i need to get it done. i'll be a happy camper either way.
  2. Mar 28, 2019 at 3:06 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    And here I was reading the title of this thread thinking, "Hell yeah, my skills are SO fabulous! How can I help?" You meant actual skills.
    Sunnier, rons23 and smslavin[OP] like this.
  3. Mar 28, 2019 at 3:25 PM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    1/8 or 3/16 aluminum should work and it would be light weight.
    smslavin[OP] likes this.
  4. Mar 28, 2019 at 3:47 PM
    smslavin
    Hudson Valley
    Some stuff
    great but you have to consider me the village idiot. where would i find that? home depot? what do i need to cut it? to finish it?
  5. Mar 28, 2019 at 3:51 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  6. Mar 28, 2019 at 3:58 PM
    smslavin
    Hudson Valley
    Some stuff
    like these?
    or these?
  7. Mar 28, 2019 at 4:01 PM
    CrunchTimeHD
    Louis
    Easton Pa
    Home depot, lowes, tractor supply. To bend it you can score a line with a cut off wheel about an inch up and that will help with bending it. Then drill holes where you want the screws or bolts. And for cutting the holes in it drill a hole in each corner of your cutout, and then use a jigsaw or sawzall to go from hole to hole and It will give it a clean rounded look.
  8. Mar 28, 2019 at 4:02 PM
    TXMiamiFan
    Jose
    Maybe more like this
    Not sure. It's a risk you're gonna have to take.
    TheBeast, joonbug, jewsNbrews and 2 others like this.
  9. Mar 28, 2019 at 4:03 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, i figured it would be something like that or this...
  10. Mar 28, 2019 at 4:06 PM
    smslavin
    Hudson Valley
    Some stuff
    :cheers:
  11. Mar 28, 2019 at 4:22 PM
    ACE Hardware is another good source, at least my local one is at Hoffman Heights off Peoria Sean. They always have a small selection of various sizes and lengths of flat steel, "aluminnion". What's good about ACE I can take a picture or drawing and my local ACE folks always seem to know what I want or need.
  12. Mar 28, 2019 at 4:26 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, i try to use them over home depot when i can. usually go to the one on colfax near quebec. or i hit the true value at colfax and monaco. everyone at either one is super helpful.
  13. Mar 28, 2019 at 4:44 PM
    Yeah, ACE on the Fax is good. The one at Hoffman Heights has been owned by the same family since the 60's. Their fastener aisles will blow you away. You can buy 1 of what you want or 100. Seriously you should go over to the Hoffman Heights ACE for at least a look see and take your drawings. Some very knowledgeable folks there, (old).
    smslavin[QUOTED][OP] likes this.
  14. Mar 28, 2019 at 4:50 PM
    smslavin
    Hudson Valley
    Some stuff
    the old guys are the best ones...
